Old 03-21-2012, 01:50 PM   #1
Bo White
Bo White's Avatar
Drives: 2010 Summit White 1SS
Check your clutch fluid
Old 03-21-2012, 01:56 PM   #2
BullF-16
USAF retired! Thank God!
BullF-16's Avatar
Drives: 2011 1SS, 1LT red,1LT/RS SGM 98Z28
My car has a little over 7000 miles and i have changed my clutch/brake fluid 4 times already. Crystal clear!
HKE LSX427(Mast blk lbl 305 6bolt LS7heads, PatG231/246 blower cam, RWHP/TQ: 1281/1133 SNL Performance Custom Twin PT6766 BB turbos 4 to 25psi selectable on the Boost Leash controller, Squash dual 400LPH/ID2000s, ALKY 4 gal meth, Autometer AFR/Bst/oilpres/oiltemp/fuelpress gauges, Pedders Justice road crs pkg: All HD bushes, supercar 12kg coil overs, supercar ZL1 sways, camber plates all setup by JusticePete! :Gforce 9" 35spline S-Trac, 1500hp Outlaw axles, 3.5"alum DS, Monster Triple disc; 4xForgeline 19x10.5 4xBridgestone 305/30R19 RE-11, CTS-v calipers/rotors/Cobalt friction XR1/3 pads
BullF-16 is offline   Reply With Quote
Old 03-21-2012, 01:57 PM   #3
Bo White
Bo White's Avatar
Mine will be from now on thats for sure. This is crazy....
Old 03-21-2012, 02:07 PM   #4
Run and Gun
Run and Gun's Avatar
Drives: 2011 1SS/RS , 1966 GTO
I've changed my clutch/brake fluid one time in 6500 miles.
A machine for shrinking time and distance.
Run and Gun is offline   Reply With Quote
Old 03-21-2012, 02:17 PM   #5
BigCarrot
xbox: this is tedious
BigCarrot's Avatar
Drives: 2011 1SS M6 Camaro IOM
Yeah our clutch fluid/system sucks and is part of the problem with shifting at high RPM. Really surprised there hasn't been an aftermarket fix yet. Change your fluid often... :(
Big Carrot's Changes - It's a work in progress
Originally Posted by Fiftydriver View Post
Seems like just yesterday I spent $450 for a Roto Fab CAI!!! What the hell happened.
BigCarrot is offline   Reply With Quote
Old 03-21-2012, 02:17 PM   #6
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: To many to list
I have changed my fluid 20 times in the past 3 years.
Old 03-21-2012, 02:20 PM   #7
Bo White
Bo White's Avatar
Ive changed mine 4 times today and still slightly shadowed in color lol. Still at it.
Old 03-22-2012, 09:32 AM   #8
IndeedSS1
IndeedSS1's Avatar
Drives: 2010 Camaro SS LS3
I had mine changed at 30K miles and while not crystal clear it was pretty clean. Guess I should use the clutch more often.
She is only memory now.
IndeedSS1 is offline   Reply With Quote
Old 03-22-2012, 09:35 AM   #9
IROCanSS
Drives: 89 IROC 350
I seperated the clutch and brake fluid reserviors. I guess I should change out the clutch fluid soon Its not bad but needs done.
Old 03-22-2012, 01:54 PM   #10
Cambull11
Cambull11's Avatar
Drives: 2011 Black 2SS/RS M6
I'm at 28K miles...I bet I should check mine lol
I am here: http://tapatalk.com/map.php?nesork
Cambull11 is offline   Reply With Quote
Old 03-25-2012, 05:59 AM   #11
partymn
partymn's Avatar
Drives: 2014 1ss 1LE
Shame that its not like my old TL1000R sport bike. Hydraulic clutch sucked so I changed it to a cable clutch. Simple fix!
2014 1SS 1LE, bone stock for now.
partymn is offline   Reply With Quote
Old 03-25-2012, 06:05 PM   #12
Bo White
Bo White's Avatar
No doubt, this is my first hydro clutch vehicle. Ive had Mustangs in the past, love the adjustable cable systems.
Understanding Brake Fluid: DOT 3, DOT 4, DOT 5.1 TAG UR IT Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 57 05-28-2016 09:10 AM
How do you check the power steering fluid? LEADfoot927 5th Gen Camaro SS LS LT General Discussions 5 05-22-2015 07:08 PM
V6 Brake advice Cyber Gray Suspension / Brakes / Chassis 70 08-26-2011 05:19 AM
clutch pedal repeatedly stuck, minimal load cab2g Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 2 04-26-2011 09:39 AM
Check Your Rear...Fluid Inspector 17 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 13 08-16-2010 01:12 PM
