Caryle Racing
Old 03-21-2012, 04:35 PM   #1
Mdejes3
Mdejes3's Avatar
Drives: 2012 VR SS Vert w/ CGM stripes
Hurst caused 2nd gear grind
Removing of the non factory Hurst short throw shifter in my '12 ss vert was the decision I have made! NO more grinding no more miss shifts. And it feels much more solid and feels like it belongs. If anyone has installed the hurst shifter and had been getting grinding than immediately take it out.imo
Mdejes3 is offline   Reply With Quote
Old 03-21-2012, 04:38 PM   #2
Badger
Badger's Avatar
Drives: 2010 ABM SS #14 of 2,027
"One of the ordinary modes, by which tyrants accomplish their purposes without resistance, is, by disarming the people, and making it an offense to keep arms."
-- Constitutional scholar and Supreme Court Justice Joseph Story, 1840
Badger is offline   Reply With Quote
Old 03-21-2012, 07:25 PM   #3
koj
koj's Avatar
Drives: 2006 Pontiac GTO
Now I'm a little confused. I thought the second gear grind was always there and the shorter throws just enhanced the grind because of faster shifting. Also did you miss gears a lot with the hurst?
koj is offline   Reply With Quote
Old 03-21-2012, 07:29 PM   #4
motorhead
Drives: POS MOPAR
I really don't understand what you're trying to say or what you did to fix it. Confused.
Old 03-21-2012, 07:52 PM   #5
jsherm007
Always drop the top
jsherm007's Avatar
Drives: 2014 Stingray Vert 2LT z51
I think he put it back to stock
jsherm007 is offline   Reply With Quote
Old 03-21-2012, 07:57 PM   #6
motorhead
Drives: POS MOPAR
OOOOOH Okay.
Old 03-21-2012, 08:20 PM   #7
Russell James
Russell James's Avatar
Drives: Camaros
Exactly why I ordered my '12 with the base shifter. The last thing the Tremec likes is faster shifts from a shorter throw. And really, the base shifter is a pretty short throw already. Anyone that doesn't think so, never drove anything from the 60s/70s where the shifts were a full arm reach. I had a Chevelle with an M22 Rock Crusher, it was like violently rowing a boat.
The ones I've driven with the Hurst, if I try to shift fast... too notchy and grindy for my taste. I've got use to the base shifter that is smoother.
Russell James is online now   Reply With Quote
Old 03-21-2012, 08:26 PM   #8
Partick
Partick's Avatar
Drives: 2010 Camaro 2SS
WOT shifts using my aftermarket Hurst shifter without any problems sine August 09
Partick is offline   Reply With Quote
Old 03-21-2012, 09:16 PM   #9
pistolgripcopo1
pistolgripcopo1
pistolgripcopo1's Avatar
Drives: 2010 SS Camaro Carbon fiber gray
The way the Hurst is put together with the shift lever connected to the upper stick attachment with two littel hex screws, Problems waiting to happen, Like grinding, wobbel from left two right. flimzy.
pistolgripcopo1 is offline   Reply With Quote
Old 03-21-2012, 09:31 PM   #10
techinny
techinny's Avatar
Drives: '12 Silverado 1500, '05 GMC 2500HD
The factory shift lever is connected to the upper stick by moulded rubber. That is better than metal to metal held together with two bolts? They both work, but neither have anything to do with gears grinding or wobble.
Had: 2010 SS/RS M6 Hurst STS, Noweeds
techinny is offline   Reply With Quote
Old 03-22-2012, 07:41 AM   #11
Mdejes3
Mdejes3's Avatar
Sorry for the confusion, I created a post a while back listing my constant grinding and mis shifts with the hurst shorty in my SS. After removing the shifter I replaced it back to stock and you can immediately tell the difference. The hurst did feel very flimsy IMO and just felt cheap. In conclusion maybe it only happens in the convertibles but I deffinitely don't recommend this mod.
Old 03-22-2012, 07:46 AM   #12
IROCanSS
Drives: 89 IROC 350
I love my Hurst. Been in since August 2009 as well. Not flimsy and cheap at all. I do gat a grind from time to time but 10 times out of 10, its my fault... not the tranny or shifters.
I am glad youre happy with the OEM shifter, I think it was spongy and I had way more missed shifts in the month I had the OEM than I have since. Different strokes for different folks I suppose.
Old 03-22-2012, 07:47 AM   #13
Mdejes3
Mdejes3's Avatar
Sorry for not clarifying I have put the oem hurst back in *
Old 03-22-2012, 07:47 AM   #14
ZED SLED
ZED SLED's Avatar
Drives: 2017 Mosaic Bk ZL1 M6
Smoked tail lights/ZL1-1LE 3rd brake
Rotofab cai
Richmond Gear Camaro gears RichmondGear V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 85 01-19-2015 11:43 AM
AY6 (V6 M6) aftermarket 1st to 2nd gear synchro and blocker ring to fix grind probee773 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 13 11-18-2011 07:58 PM
2010 1st - 2nd grind sixd8z V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 2 09-14-2011 08:22 AM
V6 Manual Transmission 2nd Gear Grind - CALL GM !! cb4dude Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 1 08-12-2011 01:21 PM
SS M6 2nd/3rd Gear Grind Issue MiSTER USA - California 0 06-20-2011 02:53 AM
