Erik@Torq
Camaro V6 LFX Engine, Exhaust, and Bolt-Ons For all LFX related parts
Old 03-22-2012, 06:56 PM   #26
bmorecam
Originally Posted by Abstrak View Post
You got to explain the correction and smoothing to me as I dont understand that at all lol. And I dont see how those numbers would be peak if it bottomed out at 6.5k rpms wouldnt it be higher if the engine was still able to put out power minus the rev limiter?
smoothing basically correct spikes. There's two corrections or "industry standard" used mainly in US. STD and SAE. They are basically preset temperature and condition set by the society of automotive engineers to be able to compare hp/tq numbers correctly. For an example, if you dyno the same LFX in the high elevation, you are going to come out with a completely different number than a LFX dynoed over at the seaside. To make comparisons work accurately, society of automotive engineers created standard and SAE correction factors each defined by preset conditions. I have more info on the first page of dyno sticky up top if you want to know more.
LFX is rated to peak out at 6800 rpm, but I can almost guarantee you that you are not really going to see too much of a difference or any by missing out 300rpm. They say the LLT peak out at 6400 rpm, but usually we crap out around 6k rpm. If it was like 1k rpm short or more than I would say it's possible.
I have to get up with tim and see when we can get in. I will let you know as soon as I know something
Old 03-23-2012, 08:27 AM   #27
fsusmithc2
Emerald Coast Camaros
fsusmithc2's Avatar
Drives: 2012 1LT/RS A6
258rwhp/228tq on a Mustang MD-500 was the baseline for my LFX. Not sure if correction was added or not. I need to get back to the dyno now that I've modded a little and see what I get. If the claims from CAI and Ark are to be believed, I should be up in the 280 range. Then we'll have to think long and hard about a tune...
2012 1LT/RS A6 - 14.11 @ 99mph
Performance: CAI intake w/scoop - Ark N-II cat-back - V-Max ported TB - SOLO HFCs - RX catch can - LSR strut brace
Appearance: Hexis vinyl cf bowties (Headlight Armor) - Oracle ABL interior, grill, and under-hood lighting, P13W plasma DRLs, ghosted sidemarkers - LSR billet strut retainers - 30% tint w/ 5% front strip - Dash plaque and under-hood bowtie by EmblemPros - Custom painted engine and fuse covers - Heritage grill
Originally Posted by Dylan@Adams View Post
Black paint isn't a hobby, its a career. Get used to it
*How to hug your Camaro*
fsusmithc2 is offline   Reply With Quote
Old 03-23-2012, 08:58 AM   #28
bmorecam
Mustang and dd used to be known as a heart breakers dyno. They are known to read lower than it should however, loaded dynos such as mustang and dd are the only one's that can be adjusted to read correctly also. Your number def look low considering you have a intake. The intake alone should be good for about 15 on a stock car, but again, dyno is only a tool to measure comparison. Mustang are ase corrected by default.
Sent from my POS phone using tapatalk.
Old 03-23-2012, 09:02 AM   #29
bmorecam
Fsussmith, can you post up your graph so we can see where LFX power peak out
Old 03-23-2012, 09:08 AM   #30
KMPrenger
KMPrenger's Avatar
Drives: '10 ABM LT/RS, 01 Ford Ranger
You might have missed it Jay, but he said the 258rwhp was before his mods and he intends to go back for another run soon.
258rwhp and 228 TQ sounds spot on for the automatic LFX to me. Sounds like you have a nicely adjusted dyno there!
Shes ALL MINE! - 8/24/2009 2G1FB1EV2A9133373 Custom Magnaflow Exhaust, Vararam intake, MACE Ported Intake Manifold, RX Ported TB, RX "Black Ice" manifold insulator, Trifecta Tune, Mike Norris Catch Can, DRL Harness, Heritage grill, Street Scene lower grill, NLP Spoiler, ZL1 rockers, Switchblade silver interior, Defenderworx sills, and more!
Old 03-23-2012, 09:23 AM   #31
fsusmithc2
fsusmithc2's Avatar
Here you go. My mistake also, the TQ is closer to 227 than 228. Peak HP is right around 6500 and the run was in 3rd gear. KMPrenger is right, this is baseline stock. Haven't gone back yet but aim to soon. The shop (SS Performance, here in Tallahassee) was having a grand opening and offering runs for $50 when they're normally $75 so I jumped on it before I did the mods about a week later.
Old 03-23-2012, 12:01 PM   #32
bmorecam
Thanks fsusmith,
Look like it peaked out right before 6500 rpm. Just as I thought.
and LFX do run alot leaner than the LLT as vince told me before. Looking at smith's graph the AFR is over 13. Maybe GM realized that they didn't need to run so rich with direct injected engines. One of the beauty of DI is that we can get away with less fuel since it spray directly in the combustion chamber. I never understood why the LLT was so rich from factory.
Old 03-23-2012, 12:06 PM   #33
bmorecam
yup I did miss it LOL.
The dyno def does look correctly adjusted. That is one of the beauty of loaded dynos. Adjustment on the fly
Old 03-23-2012, 12:45 PM   #34
fsusmithc2
fsusmithc2's Avatar
Looks like we've got a good shop here in Tally then!
Old 03-23-2012, 05:48 PM   #35
vkerster
Experimential Machinist
Drives: 2012 Camaro 1ls
Have a 2012 camaro with the LFX V-6 and six speed manual and have only bumped the rev limited once at 7200rpms. What gives with your LFX hitting the limiter at 6500?
vkerster is offline   Reply With Quote
Old 03-23-2012, 05:52 PM   #36
vkerster
ABSTRAK, I Have a 2012 camaro with the LFX V-6 and six speed manual and have only bumped the rev limited once at 7200rpms. What gives with your LFX hitting the limiter at 6500?
Old 03-23-2012, 06:12 PM   #37
KMPrenger
KMPrenger's Avatar
First off, he didn't hit the rev limiter...he hit the MPH limiter.
2nd...unless they raised the rev limiter in the LFX versus the LLT (which I don't think they did) you didn't hit 7,200 rpm.
Old 03-23-2012, 07:50 PM   #38
bmorecam
He has 18" wheels from factory which limit the speed to 118 I believe. No v6 camaro go pass 7k unless you been tuned to go pass the 7k rev limiter.
Old 03-23-2012, 08:10 PM   #39
butters
It's not the batmobile!
butters's Avatar
Drives: 2012 Camaro LFX
Noob question, where does gm get 323hp from?
Installed: MRT v1.0 | CAI Intake | VMax PTB | 20" euroTEK UO6 | Toyo Proxes ST II 255/295 | Heritage Grill | RKSport Spoiler | RS Headlights + Demon Eye Halos | Showstopper Sidemarkers | 35% Window Tint | Concept BLACK Fender Scripts
Build Journal: 2012 BLACK Build Thread
butters is offline   Reply With Quote
Old 03-23-2012, 08:22 PM   #40
scrming
Red Brick of Vengeance!
scrming's Avatar
Drives: 12 Second Brick
Car specs from the manufacturers are measured at the engines crankshaft... These dyno runs measure the HP at the wheels... there is some HP loss transferring the power from the engine to to the wheels... which is why dynos have lower numbers...
scrming is offline   Reply With Quote
Old 03-23-2012, 10:07 PM   #41
butters
butters's Avatar
Is there any way to measure hp at the crank?
Old 03-24-2012, 08:31 PM   #42
vkerster
Then I have a factory freak because I've had my LFX to 7000rpm's several times and did hit the limiter the only time it bumped 7200. Could the camaros with automatics be set up different than the manual transmission camaros? Mine is a manual...
Old 03-25-2012, 09:17 AM   #43
bmorecam
engine dyno
I believe you can hit 7k rev limit on 1st gear and 2nd gear even if the car was speed limited from the factory because of the 18" tires. I believe it's gears 3-6th where you can't get pass 100 something mph which leave you before 7k rpm. I'm not a 100% since I never had to deal with speed limiter since mine is the RS package. Maybe someone who been through this speed limit thing can confirm, but I'm sure is no different between a LLT and LFX.
Old 03-26-2012, 11:22 AM   #44
vkerster
bmorecam, I believe you misspoke on your last post. 2012 1LS Camaros come stock with 28.5 in.dia. tires.
Old 03-26-2012, 11:26 AM   #45
vkerster
bmorecam, courious, what does the RS package have anything to do with not hitting the speed limiter? (did you mean rev limiter?)
Old 03-26-2012, 11:28 AM   #46
cjt037
boost+v6=me=:)
cjt037's Avatar
Drives: Turbo'd 6er
Theirs a few calculators but why brag about power you don't have.
http://www.camaro5.com/forums/showthread.php?t=185528
435.7 RWHP 405 RWTQ
JUST A LITTLE V6... Try me
cjt037 is offline   Reply With Quote
Old 03-26-2012, 11:35 AM   #47
bmorecam
Every v6 camaro that come from the factory with 18" wheels/tires are limited to 118 MPH. This is because those 18" tires are not rated to go that fast. So due to liability issue they come with a speed limiter. Now if you have 19" or 20" wheels and tires from factory, than you have no speed limiter. RS models come with 20" wheels and tires.
Old 05-15-2012, 06:35 PM   #48
xx_ED_xx
xx_ED_xx's Avatar
Drives: 04 Silverado
Anyone use a dynapack dyno?
xx_ED_xx is offline   Reply With Quote
Old 05-15-2012, 07:07 PM   #49
HopeRidesAlone
HopeRidesAlone's Avatar
Drives: 2010 Camaro Black 2Lt
those numbers arnt too bad here mine from tnt performance dyno day now this was with an LLT with mods in sig. so id be pretty happy with a 250+ base
Injen CAI, ARK DTS Catback Polished Tips, OBX LT Headers, Lowered on Eibach, 3/8 blackiceolator.
HopeRidesAlone is offline   Reply With Quote
Old 05-15-2012, 07:44 PM   #50
montyhp
montyhp's Avatar
Drives: 2011 2LT/RS Red Jewel w/Beige
Originally Posted by INTIMIDAT3R View Post
I like my LFX and the mileage I get.
If I want performance, I'll drive my 2SS/RS.
Sir,
I believe you have more than your fair share. Maybe the government should take one and give it to someone who drives a ford focus.
montyhp is online now   Reply With Quote
MarylandSpeed DYNO TESTED: Diablosport Predator Canned Tune on 2010 SS A6 MarylandSpeed Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 27 05-18-2013 10:01 PM
New dyno run Beauwulf Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 15 07-02-2011 10:02 PM
GTR Presents the 2nd annual Battle of the Brands Dyno Day! Spit Fire California Meets and Events 24 06-06-2011 10:23 AM
333 Ways to get kicked out of Walmart (just funny- do not try this at home) Abygale Off-topic Discussions 47 04-28-2010 01:20 AM
Motorgen LA Invasion Videos (58) and Pics Thread SeanPlunk USA - California 5 05-31-2009 01:23 AM
