SDTW Custom Wheels & Tires
Old 03-21-2012, 08:56 PM   #1
ewoolsey
Drives: Victory Red 2011 Camaro SS/RS
Smile Meth Injection on Naturally Aspirated SS
Hey guys I was just wondering what kind HP gains I can expect from meth injection on a naturally aspirated ss. Is it worth it? What kind of kit should I buy? And how much will the tune cost? Right now my only engine mod is a CAI. Any info is appreciated!
ewoolsey is offline   Reply With Quote
Old 03-21-2012, 09:18 PM   #2
Lethal Racing
Lethal Racing's Avatar
Drives: LSx Performance Specialist
Methanol is good for IAT's, but unless you do more mods to the car it will not be worth it. We find it works best going to high compression NA or Supercharged. You have to watch out and not over spray the car thinking that more timing will get you more power. You can have that theory backfire on you when the burnrate of the meth slows down and you no longer gain power, but lose power. If used properly it can be beneficial with the right mods.
Lethal Racing is offline   Reply With Quote
Old 03-21-2012, 09:32 PM   #3
ewoolsey
Thanks for the info! I don't want to go to forced induction though. So should i just not do it?
Old 03-21-2012, 09:38 PM   #4
ewoolsey
can anyone else weigh in?
Old 03-21-2012, 09:44 PM   #5
ny2ss/rs
ny2ss/rs's Avatar
Drives: 2011 black 2ss/rs
I am converting to E85 fuel cooler burn temps = more timing with tune should give me around 20 HP maybe more I will see when the parts come in
ny2ss/rs is offline   Reply With Quote
Old 03-21-2012, 09:46 PM   #6
ewoolsey
That's cool! I'm knot really very familiar with this. Is E85 fuel cooler burn temps a meth injection kit? How does it work? what are my other options?
Old 03-21-2012, 09:50 PM   #7
HufferSS
I Wanna Go Faster!!
HufferSS's Avatar
Drives: 2011 2SS Synergy Green M6
The gains from Meth on a NA would be almost nothing. It's very much targeted at a Forced Induction crowd.
Built by Vengeance Racing
9.31@154.81 mph
Procharger F1-X
RPM Level 7 4L80e + Coan Converter
Hendrix 9" Rear Axle + 3.50 Gear
ARH 2" LTs+3.5" Exhaust
Fore Fuel System, Bogarts + Hoosier Slicks
Pfadt Drag Pack Suspension
My Build Thread | Best Pass To Date
HufferSS is offline   Reply With Quote
Old 03-21-2012, 09:50 PM   #8
Vette TPI
Vette TPI's Avatar
Drives: 1987 Corvette TPI
E85 is a gasoline like when you put in 91 or 93 octane. Except you fill up with E85, although you need a better fuel system for that because it is a higher octane. From what I understand on that topic.
Vette TPI is offline   Reply With Quote
Old 03-21-2012, 10:23 PM   #9
InfernoSS454
InfernoSS454's Avatar
Drives: 2010 camaro ss
U can gain meth on na but do more mods first than just a cai.
InfernoSS454 is offline   Reply With Quote
Old 03-21-2012, 10:36 PM   #10
ewoolsey
what other mods would you recommend inferno?
Old 03-21-2012, 11:25 PM   #11
realcanuk
realcanuk's Avatar
Drives: 2007 Corvette C6 983 RWHP
Here's some good reading for you from a very knowledgeable member of our corvette community.
http://forums.corvetteforum.com/c6-t...lications.html
2007 C6 vert, auto, F55, LT3
LME LS402 , WCCH 245 Heads, Pat G. Custom cam
YSI / 3.0 pulley, ARH 1 7/8 headers, NPP
Dewitts / dual spals, A&A dual pump fuel system.
3.42 polished gears, hardened shafts, Alky control meth, Cartech line lock, ECS axle loops, Trans brace, 6L80 built by me.
ID 1000 injectors, comp rockers, Morel lifters, BT springs, Trend 3/8 pushrods, ATI 10% OD Damper
Circle D Triple Disc stall
1009 RWHP @ 7000, 817 RWTQ @ 6000, Built & Tuned by Seth at FEDERAL PERFORMANCE
realcanuk is offline   Reply With Quote
Old 03-22-2012, 12:15 PM   #12
texas_boss
texas_boss's Avatar
Drives: 2010 RS/2SS
LSX Dr. I would really like to hear some longterm info on this...How much was MPG improved? Worth the cost? I live in Houston TX so cooler IAT's would be awesome, especially when we have constant 100deg days in the summer.
texas_boss is offline   Reply With Quote
injection, meth, methanol, naturally aspirated
Stock SS Parts – AZ Available edneyens Local Marketplace 5 05-16-2011 08:58 PM
Anyone with an HHR SS or Implala SS caverman 5th Gen Camaro SS LS LT General Discussions 1 02-06-2010 06:45 AM
Camaro LS / LT / RS / SS specs and options! CamaroScotty 5th Gen Camaro SS LS LT General Discussions 119 09-02-2008 10:46 PM
