JDP Motorsports
Old 03-22-2012, 11:16 AM   #1
FresnoStateDogs
FresnoStateDogs's Avatar
Drives: 2012 2SS/RS LS3
Check Engine Light-Please Help
I've put ~8K miles on my Camaro when my check engine line came on yesterday. After reading some threads in this forum I feel there are two possible sources as to why this happened. I called OnStar and they said something about my emissions not being normal.
#1 I have not been using TopTier gas. I've used 87 Arco gas. When I read the owners manual it said it was OK to use 87 but performance would be limited. (I drive nearly 100miles a day) After seeing the Image below I thought to myself, "Oh, S***! Could this be the reason why I have Higher emissions?" California is very strict.
#2 I installed a K&N Tornado CAI about a 1,000 miles ago. The box came with a a slip that said legal in every state EXCEPT by the CA Emissions control. Is the CAI adding enough emissions for the Camaro's computer system to notice? From everything I had read any K&N filter passes smog no matter what. That K&N simply didn't want to pay the fees to CA. Was I misinformed?
I'd appreciate any educated opinions as to why my emissions are causing my check engine light to come on. I'm afraid of taking it to the dealer because if it is the CAI they may void my warranty. That light is quite annoying. Thanks.
FresnoStateDogs is offline   Reply With Quote
Old 03-22-2012, 11:23 AM   #2
BowlingSS
Camaro Owner Since 1987
BowlingSS's Avatar
Drives: 2011 2SS/RS L99 RJT
What was the code?
Bill
2011 Camaro 2SS/RS L99 RJT
CAI, Inc. Cold Air Induction;ADM Scoop
Rx Catch Can;Rx Breather;Roto-Fab Washer Container
VMax Ported RJT Throttle Body
XSPower Headers and XSPower 3" Exhaust System
Elite Engineering Tunnel Brace,
Gorilla Wheel Lock System; Bear Rotors, Hawk HPS
Tinted Windows 35%;EFILive Tune
BowlingSS is offline   Reply With Quote
Old 03-22-2012, 11:25 AM   #3
Elykson
Custom One Off
Elykson's Avatar
Drives: 2010 Chicago Blackhawks Edition #1
Take the cai off, put your stock intake back on. If the cel goes off, you know it's the cai. If not, then take it to the dealer.
Vararam Intake/SLP Loud Mouth II/BBK LT HFC/Magnaflow x-pipe/Pfadt Springs/Black Ice-olator/FE3 suspension/VMAX TB/RX catch can/Trifecta Tune
http://www.camaro5.com/forums/showthread.php?t=129416
Elykson is offline   Reply With Quote
Old 03-22-2012, 11:27 AM   #4
SS King
SS King's Avatar
Drives: a Panty Dropper
check your gas cap did you tighten it all the way the last time you filled up. That will make your light pop on
SS King is offline   Reply With Quote
Old 03-22-2012, 11:28 AM   #5
FresnoStateDogs
Originally Posted by BowlingSS View Post
What was the code?
Bill
I don't believe it came with one considering it's not CA legal. What I believe is the part # is 69-4519tp
Old 03-22-2012, 11:29 AM   #6
FresnoStateDogs
Just checked it, it's tight. Good to know for the future though.
Old 03-22-2012, 11:32 AM   #7
ZuluKilla8
ZuluKilla8's Avatar
Drives: 2010 Camaro 1SS/RS RJT
He ment what check engine code are you popping...call onstar ask for the code or go to a pep boys or somthing they check for free...post the code here or do a search for the code here.
Sent from my iPhizzzone using Tapatalk
2010 Camaro SS LS3 Holley Hi-Ram Manifold,Custom grind boost cam,Vortech V-3,10Rib 3.47 Pully Airfilter Pipe Delete, 10 PSI, TSP LT Headers, Flowmaster Outlaws, Alky Control Meth Kit, PFADT 1.25, ZL1 Fuel Pump, DSS 1000HP axles, Mantic ER2 Clutch, Full BMR rear suspension drag pack upgrade. C6 Vette 18 rims with M/T 305 out back. COPO Hood
Race Proven Motorsports tuned
ZuluKilla8 is offline   Reply With Quote
Old 03-22-2012, 11:36 AM   #8
FresnoStateDogs
I reset my battery so the light is currently off. I'm afraid it will come back on as soon as I drive. If it does I will ask for the code.
Old 03-22-2012, 11:45 AM   #9
FresnoStateDogs
Newb question, but how do I add a signature?
Old 03-22-2012, 11:52 AM   #10
buzzy56
buzzy56
buzzy56's Avatar
Drives: 2ss summit white L99
This
Go to home page .select " user " CP. Look under " settings & options " .select
"edit signature " from there follow instructions.
OLD SCHOOL / NEW SCHOOL COOL
buzzy56 is offline   Reply With Quote
Old 03-22-2012, 11:56 AM   #11
Russell James
Russell James's Avatar
Drives: two 5ths and a 1st
The CAI probably has nothing to do with it.
The only reason CAI's are not emissions legal is they have no carbon absorber pad, and they are not sealed off like the factory airbox.
If you look inside your stock airbox, you'll see an absorbent pad stuck to the side. That is a carbon absorber. Cleans carbon out of the air. Has nothing to do with what comes out the tail pipe, just cleaning the air by removing carbon.
As previously mentioned you'll need to know the codes to figure it out any further.
I would retighten the gas cap and switch to a top tier premium gas. It makes no sense to add a little hp with a CAI and then kill tons of hp with 87 octane.
After it has run through a tank of premium see if the light and code keep coming back. If it does, put the stock intake back on and take it to a dealership.
Old 03-22-2012, 12:01 PM   #12
=Stephens=
=Stephens='s Avatar
Drives: 2011 LS
I know what your problem is, it is the K & N. Because the filter comes pre-oiled, some of the residue from the oil gets on your MAF and this causes the CEL. Go get some MAF cleaner, pull out the MAF and spray it. This will clean the MAF and the problem is resolved. I have the same issue and have to clean mine about every 8,000 miles also. Get a OBD reader and clear off the CEL.
=Stephens= is offline   Reply With Quote
Old 03-22-2012, 12:10 PM   #13
FresnoStateDogs
I'll try the premium gas first then the cleaning the MAF. Thanks guys.
Spiral Ported TB, K&N Typhoon, JBA Performance Cat-back, RX catch can and Oil Breather.
Old 03-22-2012, 12:15 PM   #14
=Stephens=
=Stephens='s Avatar
Drives: 2011 LS
It's not the gas, it's the K & N. If you don't clean it, the problem with not be fixed. The cleaner is like 6 bucks and takes like 1o minutes to pull, spray and replace.
Acronyms? KEEP RT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 20 03-11-2011 08:57 PM
Check Engine Light twnorman Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 3 01-23-2011 07:32 PM
Check Engine Light... Missionboi Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 1 01-08-2011 01:02 AM
LS3 engine specifications Tran Wiki 3 10-06-2010 10:56 PM
P0300 Misfire Code Help black-knight 4th Generation Camaros 4 02-08-2010 01:45 PM
