Old 03-22-2012, 01:35 PM   #1
turbo222
Drives: 2010 Summit White Camaro 1SS
Looking for an aggresive cam setup thats just under the G6X3
Hey guys!
I have been bouncing around the idea of going with the G6X3 cam but I kinda didnít want to run the biggest badest cam out there. This car will NOT be a daily driver once the cam install is done.
Iím pretty set on going through a local tuner here in socal, because i like to be close to mine. So I will probably go with either a custom grind or bring a kit to him.
So I was wondering what cam specs/cam kits you would recommend for a stage just under the G6X3, I know LG doesnít release specs on their cams so it might be hard to give me actual specs.
So far the only cam I think that falls in that category just under the G6X3 in power level is the Vengeance stage lll cam (231/243 .614/.6.24, 115+3) Iím assuming this because it makes just a little less in power then the G6X3. ANY OTHERS?
So any recommendation on cams that are still aggressive but not the biggest and badest welcome!! Thanks guys! (specís preferred)
Engine: 402whp & 394TQ Hp-tuned, Kooks 1 7/8" catted headers, 3" Kooks Cat-back Exhaust, Roto-fab Intake (Summit white), Skip shift Eliminator.
Exterior: Blacked-out Tail lights / Reverse lights / Side Markers / F & R Bowties, Stealth turn signal bulbs, AAC Blue Dome and Footwell lights.
Wheels/Tires/Suspension: ForgedStar F14 Rims (semi gloss) 20x9.5 & 20x11, Nitto NT05's 275/40/20 & 315/35/20, Pfadt Lowering Springs.
ICE: Audison LRx 5.1k Amp, 2 Hertz Hi-Energy 250w Componet Speakers, 2 Bravox Audio CF 260w Coaxial speakers, 12" Hertz Hi-Energy 1200W Subwoofer, ******** Box and Amp Rack.
turbo222 is offline   Reply With Quote
Old 03-22-2012, 02:07 PM   #2
Bad70supreme
Bad70supreme's Avatar
Drives: 2010 aqua blue SS/RS M6
I would call cartek, they have the badest stock cube N/A 6 speed out there! I am shure they can get you what you want, biggest does not mean fastest, the hole thing has to work together or its just a over cammed pig!
10.91 at 122 H/C stock block N/A
Bad70supreme is offline   Reply With Quote
Old 03-22-2012, 06:16 PM   #3
Zyklon-SS
Zyklon-SS's Avatar
Drives: 2010 2SS LS3
You should put the Night fury cam from Lethal Racing in your list, It sounds badass and makes good power too!
Zyklon-SS is offline   Reply With Quote
Old 03-22-2012, 06:24 PM   #4
blk5genss
blk5genss's Avatar
Drives: 2010 Camaro 1SS/RS
TSP 229-236 or 231-236 they both make great power!! I also like the LPE GT9 cam!!
TSP Cam 231/236 112 LSA,TSP UD,Fast 102 w/Ported TB,AirAid CAI,1 7/8 catted Stainless Power LT,3 IN MBRP 3 in Exhaust/180*,Spohn LTA's,Toe Links, Drag Bar,Diff bushings,Hurst shifter,Hendrix/DSS 1400HP Axles,Nitto NT555R's,Lethal Performance Custon Tune 480 RWHP 454 RWTQ!! Best run so far is 11.94@121 LPE 3.91's Coming soon NW 102, and DSS DS, then car should be complete!!!
blk5genss is offline   Reply With Quote
Old 03-22-2012, 06:33 PM   #5
InfernoSS454
InfernoSS454's Avatar
Drives: 2010 camaro ss
+1 for night fury cam from lethal racing
InfernoSS454 is offline   Reply With Quote
Old 03-22-2012, 07:19 PM   #6
Cal 20112SS
Drives: 2011 2SS/RS
Whatever cam this guy is running
Cal 20112SS is offline   Reply With Quote
Old 03-22-2012, 07:35 PM   #7
Zyklon-SS
Zyklon-SS's Avatar
Old 03-22-2012, 08:41 PM   #8
ULTRAZLS1
ULTRAZLS1's Avatar
Drives: 14 Silverado LTZ Z71, 16 Camaro SS
The cam in that car is likely even bigger than the g6x3.
According to them they had to fly cut. Which is not required on the g6x3.
From the looks of it so far the g6x3 and carteks large cammed cars are indeed the fastest on the track. None of the smaller cammed cars have even came close so far.
One will run into problems with a large cam if they dont run enough compression...this will make them even lazier down low. LG recommends in the neighborhood of 11.5.1 compression on the g6x3 h/c builds.
Black 2016 1SS A8 NPP
Drag Pack, CAI, Headers, Mamo Ported MSD Intake, Pray Ported TB, Shrader RSD, E85
Best ET- 10.85
Best Trap- 125.39
ULTRAZLS1 is offline   Reply With Quote
Old 03-22-2012, 08:48 PM   #9
JANNETTYRACING
PRESIDENT CALIBRATOR JRE
JANNETTYRACING's Avatar
Drives: YELLOW 2013 ZL1 AUTO
Originally Posted by turbo222 View Post
Hey guys!
Technical information, Parts Sales, Professional Installation, and Custom Dyno Tuning.
Please vist our web sites for all your performance needs!
Ted Jannetty
Jannetty Racing Ent Inc.
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
tedj@jannettyracing.com
www.jannettyracing.com
www.turboaddictionparts.com
Performance Parts
JANNETTYRACING is online now   Reply With Quote
Old 03-22-2012, 08:49 PM   #10
ULTRAZLS1
ULTRAZLS1's Avatar
Hey guys!
I have been bouncing around the idea of going with the G6X3 cam but I kinda didn’t want to run the biggest badest cam out there. This car will NOT be a daily driver once the cam install is done.
I’m pretty set on going through a local tuner here in socal, because i like to be close to mine. So I will probably go with either a custom grind or bring a kit to him.
So I was wondering what cam specs/cam kits you would recommend for a stage just under the G6X3, I know LG doesn’t release specs on their cams so it might be hard to give me actual specs.
So far the only cam I think that falls in that category just under the G6X3 in power level is the Vengeance stage lll cam (231/243 .614/.6.24, 115+3) I’m assuming this because it makes just a little less in power then the G6X3. ANY OTHERS?
So any recommendation on cams that are still aggressive but not the biggest and badest welcome!! Thanks guys! (spec’s preferred)
I would go with the TSP 231/236. That cam was my second choice under the g6x3.
Very drive-able and makes ~480rwhp.
My third choice would be the JRE 470hp cam.
Best ET- 10.85
Best Trap- 125.39
Old 03-22-2012, 09:19 PM   #11
blk5genss
blk5genss's Avatar
I love the 231-236 cam, turns heads everywhere I go and just flat out performs!! I've seen them make from 470-500 and 480/454 with 1 3/4 inch headers is great!! I can't wait to see 490/460 with the 1 7/8 stainless power!! Plus I'm hoping the 3.91's make the car feel that much torquier and put me in the powerband sooner!!
Old 03-22-2012, 10:16 PM   #12
Tampa Tuning
Drives: TAMPA TUNING FACEBOOK & INSTAGRAM
Couple things.
Your idle tone will change with the A/C active
Do not choose your cam based on how it sounds. Have your tuner make it sound like you want it.
You dont have to go supersize to get good performance.
The larger cam you install, the more you lose off the line and the larger stall you'd need.......and budget for gears to re-coop that light to light fun.
I like the LG cams. I like the 231/236 TSP cam. Id go with the 231/236 on a 112 LSA. You'll still go real fast. You'll have a little lower number on your dyno sheet ( about 10-15 less), and have slightly better drivability.
Add a FAST 102. No additional stress on the valve springs, no low end driving issues, and gain the RWHP you lost with the smaller cam.
A couple years ago, a 23x cam used to be huge. Now its like the norm.
www.TampaTuning.com
Tampa Tuning is offline   Reply With Quote
Old 03-22-2012, 10:18 PM   #13
jcollins91106
jcollins91106's Avatar
Drives: 2010 2ss m6
jre 470 cam
2010 2ss M6, TSP 1 7/8 Long Tube headers,dual electric cutouts, 3" pipes all the way back to magnaflows. elite engineering catch can, custom painted engine cover,CAI cold air intake, apex cold air racescoop, jannety racing 470 hp kit, custom JRE hot rough idle blower cam, jannety racing dyno tuned. pfadt lowering springs, lsr short throw shifter, custom sub setup,sony 7" indash nav, interior stiching dye, 20% tint all around, HAVOC spoiler, tail light black out, chevy emblem black out, seibon BBII carbon fiber hood,Front and rear bowtie blackouts. 461 rwhp and not done yet!
jcollins91106 is offline   Reply With Quote
Old 03-23-2012, 12:03 AM   #14
BLACK10
BLACK10's Avatar
Thanks guys! Yes the Night Fury is a hell of a cam
Official 1/4 Mile (V8) 2010+ Camaro Fast List Merc Dragstrip and Launch Techniques Discussion 3448 01-15-2018 12:30 AM
Cam basics CamaroSpike23 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 76 11-25-2015 12:42 PM
My Camaro went home to Oshawa to die...... Huggerorange73 5th Gen Camaro SS LS LT General Discussions 753 08-30-2011 03:40 PM
ECS Big Blower Cam - Results are in with a solid 51 RWHP gain robertway Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 13 02-21-2011 10:38 PM
