Old 03-22-2012, 07:22 PM   #1
2012SS
2012SS's Avatar
Drives: 2012 V.R. Camaro SS, '67 Camaro
Do you really NEED the tunnel brace?
Installing my flowmaster outlaw kit and can't get enough clearance on the tunnel brace to put it on. I was using 1/2" bolts as spacers when I had my AMT on but I guess flowmaster can't seem to get a consistent production line going. So....do I even need the brace, and if so, anybody know what size bolts it uses so I can get some longer ones.....not enough thread left to add more spacing on current bolts
2012 Camaro SS Victory Red, CAI intake, Flowmaster Outlaw Catbackhttp://i5.photobucket.com/albums/y186/69hotrod/5ecc4bef.jpg
2012SS is offline   Reply With Quote
Old 03-22-2012, 07:25 PM   #2
Juiced1
Juiced1's Avatar
Drives: 2012 2SS CAMARO 45th
I'd stop by ace hardware and find some longer bolts/bigger spacers. Better to have something then nothing. You can also look into a Stainless Works or ARH tunnel brace that add more room for bigger exhaust systems.
GET MORE POWER PER DOLLAR!!!
We carry all the hottest brands for your Gen5 and Gen6 Camaros! Get awesome deals on Corsa, SLP, ARH, SW, Whipple, Kooks, Procharger, CAI, K&N, Rtoto-Fab and much more! Call us for your CAMARO5 discount today!
224-63-JUICE OR INFO@JUICEDMOTORSPORTS.COM
Juiced1 is offline   Reply With Quote
Old 03-22-2012, 07:25 PM   #3
The Stig
knows 2 facts about ducks
The Stig's Avatar
Yes. Can't help you with the bolt size though. Why not just take one to home depot. They usually have those things that let you check what size bolt you have.
Click to view my build thread
Old 03-22-2012, 07:26 PM   #4
Cal 20112SS
Drives: 2011 2SS/RS
Elite Engineering's tunnel brace. Problem solved.......
Cal 20112SS is offline   Reply With Quote
Old 03-22-2012, 07:35 PM   #5
Smirnoff
Smirnoff's Avatar
Drives: Camaro SS
"Don't leave home without it".....
11.90's w/headers, CAI, custom tune, slicks/skinnys, shifter & 100+ Ethyl.
Smirnoff is offline   Reply With Quote
Old 03-22-2012, 07:36 PM   #6
2012SS
2012SS's Avatar
Yea eventually I'd like to get a nice one. So if answer is yes I need it, then is it ok to drive it to the hardware store to get longer bolts?
Old 03-22-2012, 08:08 PM   #7
2012SS
2012SS's Avatar
Oh....also, any suggestions on some heat resistant tape or padding I can put on a small section that is about 1/16" away from part of the car? It would be easier to put something to absorb vibration when it touches on a sharp turn than to readjust the whole exhaust (which wouldn't do much anyways)
Old 03-22-2012, 08:28 PM   #8
The Stig
The Stig's Avatar
yes. Just don't get side swiped - seriously. the tunnel brace protects the frame during side impacts.
to your second question, I don't know of anything that's that heat resistant and can muffle vibrations.
Old 03-22-2012, 08:37 PM   #9
MikeOD
Drives: 2010 M6 2SS
The tunnel brace does not affect normal operation of the car...has no bearing on it. It's a side impact thing. If you're hit broadside, it is there to help keep the structure of the car together around you.
2010 Camaro SS M6. Heads/Cam/Intake/Headers/Exhaust/Suspension
MikeOD is offline   Reply With Quote
Old 03-22-2012, 08:57 PM   #10
2012SS
2012SS's Avatar
Thanks for the help and info guys. Bolts are 10MM-1.5 so I got some 50MM length and 1/2" nylon spacers and as for the tape stuff, I'm thinking a few layers of that muffler patching stuff should help for now
Old 03-22-2012, 09:23 PM   #11
jcollins91106
jcollins91106's Avatar
Drives: 2010 2ss m6
you can drive it no worries...just dont get broadsided
2010 2ss M6, TSP 1 7/8 Long Tube headers,dual electric cutouts, 3" pipes all the way back to magnaflows. elite engineering catch can, custom painted engine cover,CAI cold air intake, apex cold air racescoop, jannety racing 470 hp kit, custom JRE hot rough idle blower cam, jannety racing dyno tuned. pfadt lowering springs, lsr short throw shifter, custom sub setup,sony 7" indash nav, interior stiching dye, 20% tint all around, HAVOC spoiler, tail light black out, chevy emblem black out, seibon BBII carbon fiber hood,Front and rear bowtie blackouts. 461 rwhp and not done yet!
jcollins91106 is offline   Reply With Quote
Old 03-23-2012, 12:01 AM   #12
2012SS
2012SS's Avatar
If I get broadsided I think I got more problems than my exhaust rattling lol. But it's all fixed. Got the brace spaced away from the exhaust and metal zip-tied the slack out of the exhaust hangar to pull it away from the car. Sounds awesome. Don't know why I didn't just go with the Outlaw in the first place
Old 03-23-2012, 06:35 PM   #13
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
I beg to differ. The brace offers stability/rigidity across the tunnel, which is a weak point in the undercarriage. Yes it helps in side impact but it also keeps the undercarriage from flexing during normal cornering. There are several people that run without it so there's no worries in damaging anything from driving without it but if you're in tune with your car, you can feel the difference between having one or not.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 03-23-2012, 06:36 PM   #14
axis
Search Ninja
axis's Avatar
I actually put another hangar on the drivers side pipe that pulled up both sides enough to not hit.
Halltech CF 102 fed
Billet Aluminum Tunnel Brace southerncarparts Suspension / Chassis / Brakes 36 01-08-2018 09:27 AM
Running without tunnel brace BullF-16 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 23 08-30-2011 10:45 AM
Spohn Extreme Duty Tunnel Brace Released SpohnPerformance Wheels and Tires Talk Sponsored by The Tire Rack 1 10-18-2009 08:43 PM
BMR Fabrication Launches New Product - 2010 Camaro Driveshaft Tunnel Brace (DTB004) BMR Suspension Suspension / Chassis / Brakes 30 10-12-2009 09:15 AM
BMR Fabrication Launches New Product - 2010 Camaro Driveshaft Tunnel Brace (DTB004) BMR Suspension Suspension / Chassis / Brakes 0 09-30-2009 03:03 AM
