HeadlightArmor
Old 03-22-2012, 08:24 PM   #1
Ledzepx
Ledzepx's Avatar
Drives: 2010 2SS Camaro 6sp.
clutch spring issue
Not sure if there is a topic about this but here it goes.
My clutch pedal is low until I use my foot to bring it up every time the car sits a few hours. I check the spring and the bushings, seem fine so does the spring. The clutch doesn't slip just the pedal is low at times when it sits for a while. Is there a fix to this problem?
Living the dream!
www.rsconversions.com
Ledzepx is offline   Reply With Quote
Old 03-22-2012, 09:12 PM   #2
toml_pa
ʇuɐıʌǝp lɐıɔos
toml_pa's Avatar
Drives: 2011 2SS/RS LS3/M6
Search for "clutch pedal sticking". Then stay up all night reading about it.
Way too many mods and way too much money. Wouldn't have it any other way.
toml_pa is offline   Reply With Quote
Old 03-23-2012, 06:47 AM   #3
Smirnoff
Smirnoff's Avatar
Drives: Camaro SS
LPE has a spring you can install to assist with the pedal return.....
11.90's w/headers, CAI, tune, & some high-test (no bling).
Smirnoff is offline   Reply With Quote
Old 03-23-2012, 09:49 AM   #4
justa25thTA
justa25thTA's Avatar
Drives: 2011 Camaro SS/RS LS3
have you ever changed the fluid?
Yeah, I'll get around to it...
justa25thTA is offline   Reply With Quote
Old 03-23-2012, 12:07 PM   #5
thasleeper
thasleeper's Avatar
Drives: 2010 Camaro 2 SS/RS\ CYBER GREY
Is there a time line you want to change the fluid?
thasleeper is offline   Reply With Quote
Old 03-23-2012, 11:18 PM   #6
Ledzepx
Ledzepx's Avatar
Gonna order this. Fluid was changed. Funny how nothing was wrong and when they instsalled the new shifter "GM dealership" been having this problem. The shifter rod came apart and was under warranty. So they replaced with a new one and thats when I started having the pedal stick. Returned a week later and they put new fluid in and it was fine for a day. Im thinking that there design of the return spring isn't that great. They should have kept the older 1967-1969 design. Just a spring pulling up the pedal. Seems that the spring pushes the pedal up on the new camaro.
Living the dream!
Old 03-24-2012, 06:57 AM   #7
toml_pa
ʇuɐıʌǝp lɐıɔos
toml_pa's Avatar
You can also get a 6" spring at Tractor Supply for $3.50, drill a small hole at the top of your clutch pedal and attach the other end the same place the LPE spring does. This is what I did.
Clutch Pedal Spring Rage V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 5 01-09-2012 07:43 PM
lowering spring advice dshep214 Suspension / Brakes / Chassis 29 11-21-2011 11:04 AM
Clutch Problem phenixdragon Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 20 08-22-2010 10:51 AM
BMR Lowering Springs - How It's Made BMR Suspension Suspension / Brakes / Chassis 40 06-22-2010 10:32 AM
Odd clutch and shifting issue for me. armysig Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 1 02-22-2010 11:36 AM
