Jason 98 TA
View Poll Results: stealth cams
Livernois 1C:................................218/229 .600"/.600" 117.5 16 55.17%
Thunderracing CheaTR:..................214/230 .601"/.575" 117 3 10.34%
Thunderracing CheaTR v.3:.............219/230 .607"/.604" 117 7 24.14%
LateModelRacecraft Stealth Cam:.....no specs found (can anyone post them?) 2 6.90%
Other:.........................................ple ase explain your vote 2 6.90%
Multiple Choice Poll. Voters: 29. You may not vote on this poll
Old 03-23-2012, 06:17 PM   #1
mike.nite
mike.nite's Avatar
Drives: 2011 2SS L99, 2010 LT RS
Help me pick my Stealth Cam
After a lot of reading and comparing I located the cams above as some of the most stealthy sounding cams. Don't get me wrong: I love the lope of a cammed car but for this project it is very important that the car sounds as stock as possible. The most important points are:
- No lope. The car should not sound camed.
- Gains under the curve. To me the lower and mid powerband is most important.
Based on the specs above and your experience - which cam sounds the most stealthy? And which one shows the best gains in the lower and mid powerband?
P.S: I decided to ditch the following Cams. Although they are very nice cams with good reputation they have at least one criterion which doesn't fit my needs.
- LS9 Cam...........................(Although the idle is as stealthy as it can get - the gains are just to small)
- Lingenfelter GT11..............(First this was my favorite cam - but the lifts just seems to extreme)
- LG Motorsports G6XE.........(To less information - no soundclips available)
- JRE Smooth Idle Cam.........(Nice Cam and the support from Ted is outstanding. However after listening to some
............................................youtube clips I realised that there is still some lope)
mike.nite is offline   Reply With Quote
Old 03-23-2012, 07:49 PM   #2
Bad70supreme
Bad70supreme's Avatar
Drives: 2010 aqua blue SS/RS M6
Your going to tell it's not stock even with those cams but not very noticeable. Why no lope?
10.91 at 122 H/C stock block N/A
Bad70supreme is offline   Reply With Quote
Old 03-23-2012, 07:53 PM   #3
mlee
www.CamaroFest.org
mlee's Avatar
Drives: 2017 A10 ZL1
Get the best Cam for hp/tq and have your tuner take care of the lope...
Old 03-23-2012, 09:55 PM   #4
mike.nite
mike.nite's Avatar
Not shure how much of the lope a tuner is able to eliminate.
Thatswhy I searched for cams with the least lope (LSA > 116)
Old 03-23-2012, 10:12 PM   #5
mlee
www.CamaroFest.org
mlee's Avatar
Absolutely a good tuner can smooth it out very nicely. Check with Ted Jannetty and you maybe able to get a cam + tune to go with it.
Old 03-24-2012, 07:18 AM   #6
Smirnoff
Smirnoff's Avatar
Drives: Camaro SS
Crane has a specific cam in what you are seeking.....also if you are looking for stealthy noise, an exhaust upgrade is your best bet!
11.90's w/headers, CAI, custom tune, slicks/skinnys, shifter & 100+ Ethyl.
Smirnoff is offline   Reply With Quote
Old 03-24-2012, 10:27 AM   #7
mike.nite
mike.nite's Avatar
Smirnoff thanks for the suggestions. Which crane cam do you mean? Can't find in their website.
Regarding the exhaust upgrade: I'm planning to either install a borla touring or a magnaflow street catback to keep things quiet.
Old 03-24-2012, 12:24 PM   #8
gotroost
gotroost's Avatar
Drives: IOM 2SS RS
Are you trying to build a sleeper? Lope is a good part of the fun with a cam!
Mods: JRE 470 cam kit, Dynatech long tubes/hi-flo cats, SLP underdrive pulley, CAI intake/ADM scoop, Pfadt Stage 2 suspension, Hotchkiss strut tower brace, Proven Wicked tow hook and end links, DBA rotors, Melling oil pump, Katech timing chain/LS2 damper, some bloody knuckles, still in progress...
gotroost is offline   Reply With Quote
Old 03-24-2012, 12:29 PM   #9
mikeSS
mikeSS's Avatar
Drives: 2015 c7
i have heard the 1C in person. doesn't really lope but still sits at idle loud. probably with a quiet exhaust you would be good. i am guessing the other cams are similar to this one.
Old 03-24-2012, 12:49 PM   #10
mike.nite
mike.nite's Avatar
Yes Sir.
Mike - Have you heard the 1C in a G8 or a Camaro? I heard it in a G8 and it's definately one of the most stealthy sounding cams I ever heard.
Old 03-24-2012, 02:02 PM   #11
mikeSS
mikeSS's Avatar
Drives: 2015 c7
Yes Sir.
in a camaro at the shop. ya like i said it didn't have much lope. he said it was there stage one cam. so i am guessing its the 1C.
Old 03-24-2012, 06:48 PM   #12
mike.nite
mike.nite's Avatar
But if you tune out as much lope as possible to change the sound of the cam - don't you work against its nature and sacrifice performance?
Old 03-24-2012, 10:21 PM   #13
VADER SS L99
VADER SS L99's Avatar
Drives: 2013 A6 GT 5.0
I have heard that CheaTR cam on a 4th gen LS1 and couldnt believe how stock sounding it was. It might of had stock manifolds though as I cant remember for certain. Cant comment on the others though. Have you considered the LS9 cam along with some 1.8 or 1.85 roller rockers? The gains might be as much as the others with that setup. Only drawback is that it would end up costing you more because of the rockers.
Old 03-25-2012, 03:51 PM   #14
mike.nite
mike.nite's Avatar
Vader - thanks for chiming in!
Good to hear some real life feedback about the CheaTR cam. Still wait for some answers from Thunder Racing ...
On the other hand Livernois is great when it comes to customer service and communication - they where a big help!
As for the LS9 with 1.8 rockers I'm quite not shure. It's definately an interesting alternative but if I got this right 1.8 rockers will increase the lifts. If this wouldn't matter I'd choose the GT11 as well into my top 4.
Cam basics CamaroSpike23 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 76 11-25-2015 12:42 PM
Need a stealth cam mike.nite Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 47 03-08-2012 06:36 PM
ECS Big Blower Cam - Results are in with a solid 51 RWHP gain robertway Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 13 02-21-2011 10:38 PM
ECS Big Blower Cam installed - full how-to write-up coming robertway Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 24 02-11-2011 11:25 PM
LS7 Cam For Sale $100 + sh PRICE DROP + 4x 3 bolt cam sprocket for sale PICS ADDED! CAMAR0 V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment 0 01-04-2011 01:17 PM
