Cold Air Inductions
Old 03-25-2012, 09:39 PM   #1
Oft
Drives: Black 2011 2/SS
Hurst shifter problem!!
Has anyone had issues with hurst shifter not fully engaging a gear? Every so often when I shift into second (only second) it seems to have about a 1/4" where it goes into a "Sweet spot" and the gear will engage. It doesn't do it all the which is the weird part any help would be great btw it's after market...
Thanks!
Oft is offline   Reply With Quote
Old 03-25-2012, 10:39 PM   #2
Xyient911
Xyient911's Avatar
Drives: 2014 AGM 2SS/1LE
I'd like to know this too, been happening to me sometimes
Xyient911 is offline   Reply With Quote
Old 03-25-2012, 10:44 PM   #3
The Stig
knows 2 facts about ducks
The Stig's Avatar
So would you say that you have grinding going into 2nd gear? Because that is a well documented problem on here
Click to view my build thread
Old 03-25-2012, 11:08 PM   #4
njmike
njmike's Avatar
Drives: Inferno orange Vert
I have the same problem My father has owned a 08 and 10 z06 and they both did it too
njmike is offline   Reply With Quote
Old 03-25-2012, 11:23 PM   #5
v6sonoma
v6sonoma's Avatar
Drives: 2010 SS RS
Most likely the trans and not the shifter.
9/26/09 Took delivery!
Old 03-26-2012, 11:19 PM   #6
Oft
Thanks for all the feed back... Really wish there was a solution!!
Old 03-26-2012, 11:21 PM   #7
Nessal
Drives: Exige, Miata, Ghia
Which hurst? The factory or aftermarket? I have the aftermarket and don't have this problem. It goes into every gear with a very distinctive "click".
Nessal is offline   Reply With Quote
Old 03-27-2012, 06:29 AM   #8
Soundplus
Drives: 2012 Silver Ice SS2 RS
well I have the factory one and I have not had an issue .. knock on wood.. I would venture a guess and say it is an alignment issue upon installation..
Soundplus is offline   Reply With Quote
Old 03-27-2012, 09:34 AM   #9
pistolgripcopo1
pistolgripcopo1
pistolgripcopo1's Avatar
Drives: 2010 SS Camaro Carbon fiber gray
Here we go! It could be the fact that the shift lever, is connected to the upper shift attachment with two littel hex screws. Check to see if they might have vibrated loose.
pistolgripcopo1 is offline   Reply With Quote
Old 03-28-2012, 11:27 AM   #10
montej23
montej23's Avatar
Drives: 2011 VR Camaro
I have this problem and what i did was tighten the bolts to the shifter and used loctite BLUE where it seals the bolts alot better and i havent had a issue yet. Will put it under more stress today i imagine when i get on it today.
montej23 is offline   Reply With Quote
Old 03-28-2012, 04:32 PM   #11
Oft
Ya I checked the lever and its not loose, but im wondering about this "alignment issue upon installation".. Your talking about sound plus?? I originally had the shifter installed by Fast Lane here in Houston but, they apparently didnt use loctite when they installed it BC the two screws that hold the shifter in place from the bottom fell out!! But I reinstalled using YouTube lol.. I did have this problem before the screws fell out but im wondering how to check its aligned properly??
HURST | 2010+ Camaro Short Shifter Billet/Plus 2 | Easy Install V8 & V6 Compatible! AutoAgenda Transmission / Driveline 126 03-23-2014 01:04 AM
Installed a Hurst Shifter in my 2LT (No Pics) ToyotaCamaro Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 45 02-28-2011 01:05 PM
Pic's of Aftermarket Shift Knob on Stock shifter stalk jammer174 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 3 12-04-2010 09:49 PM
2010 Camaro Hurst shifter GmPartsDirect.com Transmission / Driveline 0 05-10-2010 05:55 PM
Dumb question (sorry in advance) Hurst Shifter 2Muchmark 5th Gen Camaro SS LS LT General Discussions 0 04-16-2009 05:52 PM
