JUICEDMOTORSPORTS
Old 03-25-2012, 08:43 PM   #1
masterj1109
masterj1109's Avatar
Drives: 2010 Hennessey HPE 650 Camaro
Service StabiliTrak Message, please help!!
Hello everyone,
So here is my issue:
I haven't driven my HPE 650 camaro for about a week (was comfortable in my garage) and I went to move it today so I could preform some brake work on my DD. When I started my camaro I received the Service StailiTrak message and I am not sure why, I am also scared to drive the car out as it runs horrible and feels like it is on 4 rather than 8 cylinders until I have more info. If anyone has any information on this subject, please let me know!
Thanks
masterj1109 is offline   Reply With Quote
Old 03-25-2012, 08:45 PM   #2
The SwiftChancelor
The SwiftChancelor's Avatar
Drives: SGM, 2011 2SS/RS, L99
Check your spark plugs. Similar thing happened to me.
K&N air intake, Solo w/Jpipes axleback, SP 1 7/8 LT headers
The SwiftChancelor is offline   Reply With Quote
Old 03-25-2012, 09:41 PM   #3
masterj1109
so far 4 plugs down and they all look great, now I have to move to the almost impossible to remove 0 room passenger side
Old 03-25-2012, 09:46 PM   #4
The SwiftChancelor
Also when I had asked this someone suggested looking under the car where some of the wires hang down. They can get to close to your headers and burn which almost happened to me but I caught it before it melted the wires and tied it off with a zip-tie.
Old 03-25-2012, 10:17 PM   #5
masterj1109
I have the mesh case around all of my plug wires between the headers and I dont see any burning marks on them, but i did notice some oil on the further threads away from the spark end, altho it doesn't look like the oil made it very far down on any of the 3
Old 03-25-2012, 10:38 PM   #6
1BADLS3
1BADLS3's Avatar
Drives: Sold: 2011 2SS/RS
If the message flashes for just a brief moment when starting the car and doesn't set a code or constant warning, this is a known issue on 2010-2011 Camaros. If you turn the car to "on" and let the gauges sweep and chime extinguish, and then start the car, you shouldn't get the message. If you do, then there's probably a problem.
1BADLS3 is offline   Reply With Quote
Old 03-25-2012, 10:41 PM   #7
masterj1109
car starts, message stays, runs awful, so far driver side 4 plugs look good, now i need to take some time to check the 4 on the passenger side unless anyone has some other tips or tips on how to best remove these boxed in plugs?
Old 03-25-2012, 10:51 PM   #8
Wakemaker89
Wakemaker89's Avatar
Drives: 2010 Obsidian Lexus IS-F
Send a message via Skype™ to Wakemaker89
Do you have a link to any of the threads? I did a search but all I found were threads of people that had all of their warning lights come on and then the car drove rough because of the melting wires near the headers. I have the flashing Stabilitrak warning occasionally on my '11
Anyone selling a Camaro5 shell or SS with blown motor?
Wakemaker89 is offline   Reply With Quote
Old 03-25-2012, 11:10 PM   #9
1BADLS3
1BADLS3's Avatar
I read it some time ago on this forum. I haven't seen anything about stock wiring melting on headers though. Different issue?
Old 03-26-2012, 08:40 AM   #10
jd10013
Drives: 2012 camaro
sounds like its in limp mode.
jd10013 is offline   Reply With Quote
Old 03-26-2012, 08:47 AM   #11
11TexaSS
11TexaSS's Avatar
Drives: 2011RedJewel, FI
I'd give Hennessey a call maybe they've seen this before.
11TexaSS is offline   Reply With Quote
Old 03-26-2012, 05:26 PM   #12
The SwiftChancelor
I had a loose spark plug I didnt plug in all the way after my header install and it ran like shit. Missing a jerking every time it changed gears. All the service stabilitrac lights were on. I found the loose plug and plugged it in and it ran smooth, no lights.
Old 03-26-2012, 08:26 PM   #13
masterj1109
okay so an update after i limped to get the codes read at a near by auto shop:
Codes Thrown:
P0300
P0202
P0204
P0206
P0208
P0300: This is what I already concluded as it tells me I have a cylinder misfiring
P0202-8: These codes each tell me I have a bad fuel injector for cylinder 2, 4, 6 and 8. I think it has to be another problem as it is way to much a co-wink-e-dink that every fuel injector on one side of the engine goes bad after no signs and a week in the garage after a standard daily outting? I have contacted Hennessey and am waiting for their head tuner to call me back, but in the mean time I would love any additional input to try and solve this issue ASAP
Old 10-31-2014, 12:44 PM   #14
Smoky10
Drives: 2010 Camaro 2SS
Update?
2010 Camaro SS M6
Mods: 231/236 LSA 112, Vararam intake, VMAX throttle body, OBX longtube headers, TSP underdrive pulley, DSS one piece aluminum driveshaft, hurst short throw shifter, 3.91 gears
1968 C-10 Short Bed. 6.0 with LS3 heads, intake, TSP 229/236 cam, TBSS long tubes, and 4L60e with a 3200 stall 4.10 gears
Smoky10 is offline   Reply With Quote
What is the real Service Interval Verio Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 14 12-27-2013 11:44 AM
tpms service message pwrmanpaul66 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 9 05-06-2012 09:20 AM
Onstar....a spy???? please comment dieseldave24v General Automotive + Other Cars Discussion 138 02-23-2012 01:12 PM
Laws Protecting Consumers for Aftermarket Parts strauchpete Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 9 01-17-2010 08:31 AM
Service Stabilitrak? (Launch Control) tommygun6644 5th Gen Camaro SS LS LT General Discussions 7 12-22-2009 11:11 AM
