Cold Air Inductions
Old 03-26-2012, 12:56 AM   #1
blackflag
blackflag's Avatar
Drives: 2012 2SS 45th
Controlling Coolant temp- Thermostat swap or fan tune
I have noticed that my coolant temp is real constanst at 190 when regular driving (bone stock).
But I noticed at the dragstrip, it heats up quick and even gets around 220 leaving the line in mid 80 degree weather.
I'd like to make some changed to keep my coolant temps more stable. I haven't pulled the stock tune and looked at it yet to see when the fans turn on. But its higher than what I want.
What effects would I see to changing the thermostat to something lower? Could I better control heat with just a 160 or 170 thermostat, or do I really need to add/upgrade fans or change the fan tune?
Or could I run a switch to the fan hot side and turn them on when I want manually?
Thanks for the ideas!
Josh
#1 2012 NMCA/LSX Challenge Series
2012 2SS 45th A6
Thanks to our Sponsors:
coldairinductions.com (Cold Air Inductions)
loughengines.com (Mike Lough Race Engines)
granatellimotorsports.com (Granatelli Motorsports)
blackflag is offline   Reply With Quote
Old 03-26-2012, 01:04 AM   #2
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
Get a 160 degree thermostat and get the computer tuned for the fans to come on earlier. Problem solved.
SUX2BU is offline   Reply With Quote
Old 03-26-2012, 01:11 AM   #3
blackflag
blackflag's Avatar
Ordering a 160 thermostat tomorrow. I'm just not wanting to "tune the car" and void the warranty. Have had my laptop and EFILive sitting in the truck since I got it, but have fought the urge to play with the tune just yet.
Maybe just the thermostat will help keep the temps down some since it will be circulating 30 degrees cooler than stock. Guess I will have to find out.
2012 2SS 45th A6
Old 03-26-2012, 01:23 AM   #4
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
Just swapping thermostat won't help much. You would have to wire in a switch to the fans if you don't want to tune.
The reason for this is that stock fan settings are 221 degrees for low speed fans and 228 for high speed fans.
Old 03-26-2012, 01:29 AM   #5
blackflag
blackflag's Avatar
Well that explains it!! haha.. Sounds like I got some wiring to do
2012 2SS 45th A6
Old 03-26-2012, 06:51 AM   #6
Padre
Only drives on Sundays
Padre's Avatar
Drives: '16 2SS A8 NPP MRC NGray
That would be an interesting mod (changing it with resistors).
I solved the problem with a Meziere Electric Water Pump, a 160* stat, and a fan tune. But I had (when stock) basically the same problems you do.
Padre
OLD HOTNESS: The "Heretic": '11 2SS/RS L99 A6 Black/Inferno. Build Journal, Videos
D1SC GT9 JBA-LT = 720/680 | 10.330 @ 133.61, 1.546 sixty... Camaro King at ECS V, Darlington.
NEW HOTNESS: '16 2SS A8 NPP MRC. Bone Stock, 1/8th: 8.051 @ 89.44, 1.919
Padre is offline   Reply With Quote
220 degrees, heat soak, thermostat
g5cr cai system anybody install or looking at one "pics" camarossrs2150 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 41 07-14-2011 09:26 PM
Hot air Intakes -By Kenne bell ADM PERFORMANCE Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 66 02-08-2011 09:33 PM
Fan problems after replacing thermostat topgun1 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 11 07-27-2010 08:26 PM
List of Intakes that will work with the TVS-2300 MagnaCharger JJ2010 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 26 03-19-2010 03:11 AM
AirAid Cold Air Intake anyone? FLYNNZL1 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 12 01-01-2010 10:05 PM
