HURST
Old 03-26-2012, 06:18 AM   #1
mickymaro69
mickymaro69's Avatar
Drives: ls3
gears
will 3.73 gears make a noticable diff on an ls3?
mickymaro69 is offline   Reply With Quote
Old 03-26-2012, 06:35 AM   #2
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
It is definitely noticeable. When equipped with the manual transmission (M6) the SS comes with a 3.45 rear end and cruises at just over 1600 RPM at 70 MPH. By upgrading the factory 3.45s in the stock M6 equipped Camaro SS to the 3.73s you will realize an equivalent torque gain of approximately 10% or 42 lb.-ft. of torque and cruise at 1750 RPM at 70 MPH.
Old 03-26-2012, 07:06 AM   #3
POWERFREAK
I.AM.
POWERFREAK's Avatar
Drives: 2010 2SS/RS/M6
With the ls3, if you're gonna do it, go with 3.90 or 4.10
NY5thgen.com
POWERFREAK is offline   Reply With Quote
Old 03-26-2012, 07:37 AM   #4
allmotor
movin' down the motorway
allmotor's Avatar
Drives: Summiit White 2SS/RS/M6
just upgraded to LPE 3:91's. So much fun...
417 stroker - Florida Speed and Power
allmotor is offline   Reply With Quote
Old 03-26-2012, 08:12 AM   #5
flht99b
flht99b's Avatar
Drives: 2010 Camaro 2SS/RS RJT
I have AAM 3.70's behind my very mild LS3. Car should have come with 3.70's from factory or as an option in my opinion. 80mph is 2K rpms.
Ed M.
RJT 2SS/RS, AAM 3.70's, MTI Sway Bars, Shifter & SS brake lines, ZLI calipers & rotors, BMR Trailing & Toe Arms, full rear cradle & diff bushings, Pedders XA's, Camber/Toe eccentrics, Radius arm inserts, ZL1 Brembo Brake pads, GTO clutch reservoir, LS9 cam, Comp Cam valve springs, Melling 10296 oil pump, CR 5 timing chain, LS2 damper, CAI Cold Air Induction, ARH LT headers w/HF cats, GMPP touring axle back, Elite Engineering Catch Can, Forgeline 20x9.5 & 20x11 DS3 wheels w/Vredestein 275/40/20 & 315/35/20 tires, '11 Convertible spoiler, Lloyd "SS" Floor Mats, GM Camaro Trunk Mat
flht99b is offline   Reply With Quote
Old 03-26-2012, 09:13 AM   #6
Mdipinto
Drives: 2010 2SS Camaro silver black stripe
Just for curiosity, if you wanted to upgrade the rear gear, but you want to keep the same RPM when going in the highway, how hard would it be to open up the transmission and change the gears in there?
I want to put a 3.9 or a 4.1 rear gear, but I want to keep the car with the good MPG it makes... I was thinking how hard and expensive would it be to change the size of the 4th, 5th and 6th gear...
(as of right now I use 1-3 for fun and just acceleration, 4 for driving in the city, 5 for driving on a higher speed limit still in the city, like 35mph, and 6 for highway)
AIRAID cold air intake, Borla headers long tubes stainless steel, MBPR Performance Cat back X-pipes,custom cam from Virginia Speed, CNC Ported Heads from TEA, Heritage grill
Mdipinto is offline   Reply With Quote
Old 03-26-2012, 09:24 AM   #7
POWERFREAK
I.AM.
POWERFREAK's Avatar
assuming you have an LS3....my experience with 4.10's...my mpg around town actually got slightly better because there's no more "motor lugging" and it's more "driveable" (clutch works better). And, on the highway at 70mpg in 6th, rpms are only 2000, plus, you can actually use 6th, and not have to downshift to pass anyone....so really you're not gonna take a big hit w/ mpg. 5th and 6th gear in the tr6060 are already soooo overdriven, I wouldn't worry about that (and the $$ it would take to change would pay for a lot of gas).
NY5thgen.com
Old 03-26-2012, 09:26 AM   #8
flht99b
flht99b's Avatar
I do not believe there are different ratio gears available for the Tremec 6060. Even if they were, it would be very costly. The 3.70's and 3.91's keep your highway rpm down to a reasonable level which helps gas mileage. My car with 3.70's got 24.6mpg going to MTI's event at Roebling road last year, 420+ miles one way at speeds between 55mph and 90mph.
Ed M.
Old 03-26-2012, 03:46 PM   #9
Mdipinto
I don't know about how the MPG would be affected on mine, but I'm getting 27.5 MPG when going 60mph on 6th, and if I go 45 or 50 on 6th I get up to 33MPG. When I keep at 1.1KRPM it doesn't bog, but doesn't have much acceleration, but is enough to just cruise and save gas.
The only reason I care about the MPG is because me living in NC, I have my family in NJ and my girlfriend in FL, driving is way cheaper than flying... and I want to keep that way, so I can drive my car when I'm there.
Ed M.
I was even thinking about looking for a 7 speed manual transmission, so I could have the 4 fun gears, and 3 for the regular driving...
I just did a trip to virginia beach it was 193 miles, and it was mostly 55 and 70mph, quite a bit of stops. I averaged 51MPH, 26.2MPG, and I did have some fun on take offs.
I want to make the car more powerful so I can take to the track and get better times, but it's also my daily driver, so I need to make it economical too...
I drive maybe 1.2 miles to go to work every day, and the same back, and if I get 12 MPG I'm happy, it's just 25mph, then a 35 for maybe 0.1 mile, and a 15mph... (I'm about to buy a scooter to save in gas on going to work)
But I still use the car on drives here and there, and that requires some economical aspect to it, besides the long trips, where driving over 500 miles those 2MPG helps...
Old 03-26-2012, 04:58 PM   #10
Fiftydriver
Fiftydriver's Avatar
Drives: 2010 Camaro 2SSRS RJT L99
I went with LPE 3.90 gears and while my highway RPMs went up a bit, fuel milage was not changed dramatically. I would say less then 1 mpg drop and in my opinion, the feel of the lower gears is WELL worth the milage loss.
Fiftydriver
2010 SSRS, RJTC, L99, Maggie 2300 SC, 3.4" pulley, Roto-Fab CAI, Dynatech Supermaxx LT headers, Dynatech High Flow cats, Corsa Cat back exhaust, Dual Elite Engineering catch can, MSD wires and Jannetty custom tune, JRE custom diff w/ posi mod, 3.91 LPE gears, Pfaht trailing arms, Pfaht trailing arm and Diff bushings, drop springs and sport sway bars front and back, Fesler dual guage pillar pod w/ AM Cobalt Boost and A/F guages.
More to come!!
Fiftydriver is offline   Reply With Quote
Old 03-27-2012, 12:51 AM   #11
blk5genss
blk5genss's Avatar
Drives: 2010 Camaro 1SS/RS
I have a set of 3.91 LPE gears and install kit for 1025 obo shipped!! I'm San Antonio if you are coming this way!!
TSP Cam 231/236 112 LSA,TSP UD,Fast 102 w/Ported TB,AirAid CAI,1 7/8 catted Stainless Power LT,3 IN MBRP 3 in Exhaust/180*,Spohn LTA's,Toe Links, Drag Bar,Diff bushings,Hurst shifter,Hendrix/DSS 1400HP Axles,Nitto NT555R's,Lethal Performance Custon Tune 480 RWHP 454 RWTQ!! Best run so far is 11.94@121 LPE 3.91's Coming soon NW 102, and DSS DS, then car should be complete!!!
blk5genss is offline   Reply With Quote
Old 03-27-2012, 03:01 AM   #12
Mdipinto
Damn... If my girlfriend didn't come to visit last week I would buy it... But I spent 700 on the hotel for a week, and over 400 on stuff to do... Thank god she paid for some the stuff to do and the plane ticket...
But I really wish I could buy it... The price is good, and from what it seems doesn't do much to the mpg...
Old 03-27-2012, 10:38 PM   #13
blk5genss
blk5genss's Avatar
Nope not too much, I was going to install them but instead I traded it in!
Old 07-22-2014, 01:08 AM   #14
Snidely Whiplash
Fight Crime, Drive Armed
Snidely Whiplash's Avatar
Drives: '14 2SS Yelo Maro, HD collection
With that M6, first gear is maxed waaaay to fast because of the 3.01 ratio. 9 to 11 is what I was always told is the total for low gear. The 3.90 or 4.10 is over 12 on the low gear total. Not for me. The 3.73 would be ideal!
Bring back Sunoco 260 to the local station. Some folks STILL drive L-88s and need the good gas.
Snidely Whiplash is offline   Reply With Quote
Official 1/4 Mile (V8) 2010+ Camaro Fast List Merc Dragstrip and Launch Techniques Discussion 3453 02-18-2018 02:39 PM
Rear End Gears 101 danhr V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 82 08-04-2017 12:38 PM
Richmond Gear Camaro gears RichmondGear V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 85 01-19-2015 11:43 AM
Question on my blown Richmond's for the experts Eric Baker V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 28 10-29-2011 10:59 AM
NEW PRODUCT: 2010 Camaro Richmond Gears - 3.73 and 4.10 Ratios tbyrne Transmission / Driveline 9 01-11-2010 11:36 AM
