Old 03-26-2012, 07:55 PM   #85
jtmiller92
Drives: 2011 1SS Camaro
Total Fail to call this a 1LE.
Shouldnt have any of this garbage.
AVAILABLE RS APPEARANCE PACKAGE
Equip your 1LE with HID headlamps (including halo rings), a body color roof ditch molding, and a body color shark fin antenna for a clean exterior appearance and unique RS badging.
AVAILABLE SUNROOF
With 1LE’s available power sunroof.
SUEDED MICROFIBER-WRAPPED FLAT-BOTTOM STEERING WHEEL
This flat-bottom steering wheel (borrowed from ZL1) provides room for heel/toe operation and makes getting in and out of 1LE easier. This wheel, accented with stone color stitching, makes the car feel more nimble and connects the driver more directly to the car.
SUEDED MICROFIBER-WRAPPED SHIFT KNOB
Borrowed from ZL1, the 1LE shift knob looks as good as it feels, wrapped in sueded microfiber and accented with stone color stitching. The 1LE also shares ZL1’s GM-designed short throw shifter, which has a 5.1:1 ratio — the new standard for Camaro.
AVAILABLE PREMIUM AUDIO SYSTEM
(Included on 2SS models) Enjoy premium performance sound with the Boston Acoustics® premium nine-speaker sound system.
AVAILABLE REAR VISION PACKAGE
(Included on 2SS models) Help see items behind the vehicle with the Rear Vision Camera, displayed on the 7-inch color touch radio screen.
1992 Camaro RS, 416ci LS3, T56, Moser 9"
jtmiller92 is offline   Reply With Quote
Old 03-26-2012, 07:55 PM   #86
cam99
cam99's Avatar
Drives: 2012 ZL1
Originally Posted by Kmorpheus View Post
Genisses is getting a 429 hp direct injection plant. Add a 300 dollar tune and anything short of a supercharged SS will only be seeing taillights from that 4 door luxury sports car
You sure about that
2012 CTF ZL1-stock
2012 ZL1 (sold)
JRE 75rwhp kit
catless
ported lsa TB
11.04 @ 128.35
on hoosier drs and skinnies
@ PRP with 1100DA
cam99 is offline   Reply With Quote
Old 03-26-2012, 07:57 PM   #87
vafinest25
vafinest25's Avatar
Drives: 2010 2SS/RS "Orange Crush"
I hope the touch screen can be retrofitted to the 2010 2ss
I am here: http://tapatalk.com/map.php?ze4ha4
" When your ready to quite, your 1/2 way there"
" Drive It Like You Stole It "
[SIGPIC][/SIGPIC
vafinest25 is offline   Reply With Quote
Old 03-26-2012, 08:20 PM   #88
MattMellish
MattMellish's Avatar
Drives: 2011 Camaro 2SS RS
This may be a dumb question but if it is called a 1LE will there be a upgraded version called the 2LE? :P
Oh yeah, this is what badass looks like, guess how it feels!!
MattMellish is offline   Reply With Quote
Old 03-26-2012, 08:32 PM   #89
RJTV6A
Drives: 69 Camaro I6 no prob,11 V6 big prob
Originally Posted by DMVG8 View Post
It has magnetic ride control too right? I would trade my G8 for 1
Sent from my DROID2 using Tapatalk
Mag ride and Vert would do it for me. But I thought the original 1LE was a stripped down lightweight
RJTV6A is offline   Reply With Quote
Old 03-26-2012, 08:33 PM   #90
49ersXXIX
Take me back to 1994
49ersXXIX's Avatar
Drives: 2010 CAMARO 2SS/RS SUMMIT WHITE
say what? i was looking to get an ss in a few months, but i guess i will wait for the 1LE..... hell yeah!!!
49ersXXIX is offline   Reply With Quote
Old 03-26-2012, 08:36 PM   #91
garcmol
garcmol's Avatar
Some 1LE reading for you
What The 1LE consisted of: (Categorized & Year By Year)
In 1988, the secret showroom stock racing 1LE option (option level 0 IROC-Z) was first available; however, only 4 were produced. Then in 1989, the option became more well-known as 111 were produced that year. The package was obtained by ordering the following:
Level 1 IROC-Z with 5.0 TPI engine (LB9) with 5 speed or 5.7 TPI engine (L98) with 4-speed automatic. These Camaro's had 145 mph speedometers and 5500 rpm redline tachs. Optional axle ratio (G92) (305/3.45, 350/3.27) and its required options G80 Limited-Slip rear axle
Package consisted of (G92 Was Ordered With A/C) [Street Vehicle]:
engine oil cooler 4-wheel disc brakes Performance exhaust system (N10) (dual catalytic converters) Tires P245/50 ZR16 Goodyear Gatorback
Note:
G92 ordered WITH A/C was classifieds as a Street vehicle.
G92 ordered WITHOUT A/C was classifieds as Race series.
Package consisted of (G92 Ordered Without A/C) [Race Vehicle]:
Aluminum driveshaft (JG1) (part # 10085375) G80 Differential with limited slip with 3.42 posi rear G92 Rear axle performance package Big front brakes adapted from the Corvette Larger (11.86 inch) front rotors (part # 18016035) Larger front spindles (part #'s 18016737 / 18016738) PBR front, dual-piston aluminum calipers (part #'s 10132827 / 10132828) Special swinging fuel pickup in gas tank and special 18 gallon baffled fuel tank for fuel pickup down to .5 gallon reserve to prevent fuel starvation in hard cornering specific front and rear shock absorbers Lower control arms (part # 10164151) Special deflected disc shocks Air conditioning delete (C41) (standard heater) (weight savings and better air flow to the radiator) Fog lamp delete (to release the air intake located behind) T-Tops delete Power accessories delete Aluminum spare wheel with smaller spare tire (N64) A Few RARE ones came with special 16" x 8" light alloy mesh wheels (XWL)
[edit]Yearly Information on the 1LE Option:
1988
Chevrolet built 4 "1LE" 1988 Camaro's for the SCC A Showroom Stock racing series. The reason only 4, virtually unknown to most Camaro racer-types at the time.
1989
Chevrolet built 111 "1LE" 1989 Camaro's for the SCC A Showroom Stock racing series. But 1LE wasn't ordered like other RPOs. Ordering the RPO G80 Limited-slip rear axle & G92 performance axle with an IROC-Z Coupe triggered the 1LE RPO. Here's how it worked: When G92 was ordered, it forced several other options including engine oil cooler, 4-wheel disc brakes, dual converter exhaust and P245/50ZR16 tires. A 1989 Camaro with G92 had to have either the 350ci (RPO B2L) engine with 4-speed automatic transmission, or the 305ci (RPO LB9) with 5-speed manual. These Camaro's had 145 mph speedometers and 5500 rpm redline tachs. If RPO G92 was ordered with air condition ing, the cars were built as street vehicles. If air conditioning was not ordered, Chevrolet added 1LE equipment for the race series. This included aluminum drive shaft, big front brakes adapted from the Corvette, fuel tank baffles, specific front and rear shock absorbers, and different jounce bumpers. Also, fog lamps were deleted for weight savings and better air flow to the radiator.
1990
Chevrolet built 62 "1LE" Z28 Coupes for the SCCA Showroom Stock racing series with RPO G80 Limited-slip rear axle & G92 RPO G92 performance axle triggering the build. RPO G92 required one of two engine combinations, the 305ci LB9 V8 with 5-speed manual, or the 350ci B2L V8 with 4-speed automatic transmission. When ordered with air conditioning, RPO G92 included engine oil cooler, 4-wheel disc brakes, and dual-converter exhaust. When ordered without air conditioning, RPO G92 added heavy-duty front brakes adapted from the Corvette, aluminum driveshaft and spare wheel, special shocks and fuel pickup, and gas tank baffle. Fog lamps, normally included with IROC models, were deleted for weight savings and better air flow to the radiator. Option cost for RPO G92 equipment with air conditioning was $466.00. The cost when air conditioning wasn't ordered was $675.00.
1991
Chevrolet built 478 Z28 Coupes with "1LE" equipment for 1991. The exact amount of true 1LE's is not known this year as a majority of the 478 units were "B4C" Special Service (or Police package) RS Camaros which had the 1LE front brakes (1LE brakes were a mid year option on the 91 B4C as it was quickly realized that the standard front brakes were not suitable for police use -thus some B4C's got the 1LE brakes and some did not). As in 1989 and 1990, Ordering the RPO G80 Limited-slip rear axle & G92 RPO G92 triggered the build. RPO G92 required one of two engine combinations, the 305ci LB9 V8 with 5-speed manual, or the 350ci B2L V8 with 4-speed automatic transmission. When ordered with air conditioning, RPO G92 ($466) included engine oil cooler, 4-wheel disc brakes (except for a brief period when 4-wheel discs were deleted with a $287 credit), and dual-converter exhaust. When ordered without air condi*tioning, RPO G92 ($675) added heavy-duty front brakes, aluminum driveshaft and spare wheel, special shocks and fuel pickup, and gas tank baffle. Fog lamps were deleted for weight savings and improved cooling.
[edit]1992
Chevrolet built 705 Camaro's with "1LE" special performance components equipment for 1992. Of the 705 units, 589 of these were the "B4C" Special Service (or Police package) cars which all included the 1LE front brakes. Content was different in the B4C as air conditioning was standard and the aluminum driveshaft, spare tire and other heavy duty suspension components were not included. In reality there were only 116 1LE "race prep" cars produced. As in 1989, 1990, and 1991, Ordering the RPO G80 Limited-slip rear axle & G92 RPO 1LE was triggered by RPO G92. RPO G92 required either the 305ci LB9 V8 with 5-speed manual, or the 350ci B2L V8 with 4-speed automatic transmission. When ordered with air conditioning ($466), RPO G92 included engine oil cooler, 4-wheel disc brakes, and dual-converter exhaust. Without air condition ing ($675), RPO G92 added heavy-duty front brakes, aluminum driveshaft and spare wheel, special shocks and fuel pickup, and gas tank baffle. Fog lamps were deleted for weight savings and better air flow to the radiator. Available for Z28 Coupes only.
1992 should be recognized as the peak of 3rd generation performance with the two models, the B4C Special Service package and the 1LE Race Prep package being the most covetted for collectors as both were produced in relatively low numbers and each had different content. The 1LE was the best handling and lightest package available, although the B4C had most of it's content and was the only way to get the big heavy duty racing brakes along with air conditioning and power windows/locks and mirrors if you wanted them.
[edit]1993
Chevrolet built only 19 Camaro's with "1LE" equipment for 1993. This included larger diameter front and rear stabilizer bars, stiffer shock absorber valving, harder durometer control arm bushings front and rear, power sterring cooler, and radiator baffles for added engine cooling. Air conditioning, power windows/locks or mirrors was not available with 1LE.
[edit]1994
Chevrolet built 135 Z28 Coupes with "1LE" equipment for 1994. Content changes slightly as the rear sway bar for 1LE and Z28 are the same (downsized from previous year) and the new Koni double adjustable shock absorbers becomes available as factory installed content in the 1LE.
[edit]1995
Chevrolet built 106 Z28 Coupes with "1LE" equipment for 1995.
[edit]1996
Chevrolet built 55 Z28 Coupes with "1LE" equipment for 1996. Air conditioning becomes standard in all camaros including the 1LE cars which was previously unavailable. Other power options are still restricted in the ordering process.
[edit]1996
[edit]1997
Chevrolet built 48 Z28 Coupes with "1LE" equipment for 1997.
[edit]1998
Chevrolet built 99 Z28 Coupes with "1LE" equipment for 1998. If 99 were built why do the production number say none were built? I know where there is an SS 1LE. According to SLP it is the only one.
[edit]1999
Chevrolet built 74 "1LE" equipped camaros for 1999.Of these 74 units, 66 were Z28 and 8 were SS optioned (one of the SS's was an automatic and would be quite the collectible today!) This is the last year of the 1LE as installed from the factory. SLP adds 1LE as an option in later years but does not include previous content and is not factory installed by GM.
Old 03-26-2012, 08:51 PM   #92
Pappa Joe
Pappa Joe's Avatar
Drives: Charger/TL1000R/Cobalt/ZL1
Originally Posted by papabearcamaro View Post
Agree!!! I just don't get the fascination of black wheels.
I do ....I love blk wheels!
Pappa Joe is offline   Reply With Quote
Old 03-26-2012, 08:54 PM   #93
Chemical
Chemical's Avatar
Drives: 2SS RS
Holy shit! Finally!
Automatic option too??? (traffic guys.... Traffic)
More colors than just red?
Chemical is offline   Reply With Quote
Old 03-26-2012, 09:13 PM   #94
jose1003
jose1003's Avatar
Drives: 2010 Camaro 2SS Cyber Gray
love it
jose1003 is offline   Reply With Quote
Old 03-26-2012, 09:17 PM   #95
hightower
LS3 Black Widow
hightower's Avatar
Drives: 2012 45th 2SS LS3 and 1968 Mustang
THIS IS AWESOME!!!!!!!
hightower is offline   Reply With Quote
Old 03-26-2012, 09:23 PM   #96
OldJedi
Use the Force
OldJedi's Avatar
Drives: 1967 Corvette, 2012 ZL1, 2015 Z51
Send a message via AIM to OldJedi
Originally Posted by MS3DALE View Post
Also,read what is says for the rear-vision package....
"displayed on the 7-inch color touch radio screen"
Good information, but was there any mention of the horsepower or suspension? Slight increase to the 450/460HP range and maybe coil over suspension?
Walk softly, carry a light saber and drive a ZL1!
OldJedi is offline   Reply With Quote
Old 03-26-2012, 09:25 PM   #97
SnoopyAce7
(ʘ‿ʘ)
SnoopyAce7's Avatar
Drives: The one with a roof rack
Originally Posted by BowtieBelle View Post
I think this is our Z-28...
Originally Posted by aSSian View Post
i think a z28 will be available for the 50th anniv...
SnoopyAce7 is offline   Reply With Quote
Old 03-26-2012, 09:27 PM   #98
RJTV6A
garcmol Thanks so much for the great info. I wish I knew the vin number of my buddys 1LE I would give him a hard time because of the manual windows no "T" tops and no A/C. His car was bright yellow and he figured nobody would steel a stripped down Camaro. But he was wrong. He bought it new from Ayers Chevrolet in Dover NJ.
Thanks For the read
1le, 1le camaro, 1le forum, camaro 1le, camaro 1le forum, camaro performance package, camaro track pack, camaro track package, where's our z/28?
FE3 to ZL1 Zway Bar UpgradeZ and ZL1 ZuZpenZion PackageZ JusticePete Suspension / Chassis / Brakes 111 05-08-2013 11:38 PM
Modern Camaro Performance Parts - www.PartsTaxi.com PartsTaxi.com Sponsor Announcements / Giveaways / Contests 0 10-06-2010 05:26 PM
4th Annual GM Performance Parts LSX Shootout!! nmcajeff Dragstrip and Launch Techniques Discussion 3 07-30-2010 01:05 PM
4th Annual GM Performance Parts LSX Shootout!! nmcajeff Off-topic Discussions 0 07-28-2010 09:28 AM
