Old 03-26-2012, 05:57 PM   #1
dekan513
chevy pride
dekan513's Avatar
Drives: 2ss/rs
weight issuses and what im thinking
ok i race motocross almost all my life and i remember honda dropped like8 lbs from changing their bolts heads to the next smaller size and a diff material if i end up makin my car a drag car i may end up doing that and see what u would loose i bet it would be alot over the car just wondering if anyone done something like this.
check out ky speeds fb page https://www.facebook.com/kyspeed
dekan513 is offline   Reply With Quote
Old 03-26-2012, 07:41 PM   #2
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
As my late best friend, Donald Polk, always said, "ounces make pounds".
The problem is that you have to shed a crap load of ounces to make a difference on this pig. Also, when you're trying to make the most HP from an engine, going smaller isn't always the best idea. On body parts, you'd be fine but on engine parts, you need the strongest you can get your hands on. Unfortunately, stronger and lighter rarely go together.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 03-26-2012, 08:17 PM   #3
InfernoSS454
InfernoSS454's Avatar
Drives: 2010 camaro ss
Add more torque. Look knot carbon fiber body parts.
InfernoSS454 is offline   Reply With Quote
Old 03-26-2012, 08:19 PM   #4
Fiftydriver
Fiftydriver's Avatar
Drives: 2010 Camaro 2SSRS RJT L99
Even a lightweight GenV camaro will be heavier then most mustangs so the real answer is to take advantge of the potential of the engine to flat out HP you down the track. Good suspension mods, solid drivetrain and alot of power.
Nothing wrong with cutting weight but you would have to get REALLY extreme to get car weights down significantly.
I would never compromise on engine componants just to save weight personally but then again, I am not a racer. My car is just a strong street ride.
Fiftydriver
2010 SSRS, RJTC, L99, Maggie 2300 SC, 3.4" pulley, Roto-Fab CAI, Dynatech Supermaxx LT headers, Dynatech High Flow cats, Corsa Cat back exhaust, Dual Elite Engineering catch can, MSD wires and Jannetty custom tune, JRE custom diff w/ posi mod, 3.91 LPE gears, Pfaht trailing arms, Pfaht trailing arm and Diff bushings, drop springs and sport sway bars front and back, Fesler dual guage pillar pod w/ AM Cobalt Boost and A/F guages.
More to come!!
Fiftydriver is offline   Reply With Quote
Old 03-26-2012, 08:21 PM   #5
Fiftydriver
Gears do make a world of difference in these cars. MY 3.9 LPEs make this car feel around 1000 lbs lighter then with stock gears. May also have something to do with the supercharger as well!!!
Fiftydriver
More to come!!
Old 03-26-2012, 08:22 PM   #6
InfernoSS454
Yea I don't think gm put the right gears for this car considering the weight.
Old 03-27-2012, 12:30 PM   #7
Inferno Orange 2SS-RS
US Army Retired
Inferno Orange 2SS-RS's Avatar
Drives: IOM 2SS-RS - A6 (L99)
You could try something like this...
SMKIN SS
Inferno Orange 2SS-RS is offline   Reply With Quote
Old 03-27-2012, 03:49 PM   #8
dekan513
chevy pride
dekan513's Avatar
Drives: 2ss/rs
im only thinking of doing this if i go full race mode , but i bet u could cut 50 to 100 lbs doing stuff like that on a car and 100 is around a 1/10
Old 03-27-2012, 07:54 PM   #9
Three of Swords
Three of Swords's Avatar
Drives: 2011 IBM 1SS/RS L99
If you haven't seen it yet, check out this thread on weight reduction:
http://www.camaro5.com/forums/showthread.php?t=178832
Three of Swords is offline   Reply With Quote
