BORLA
Old 03-26-2012, 07:25 PM   #1
Ject
aka Patrick
Ject's Avatar
Drives: '10 Camaro 2SS '04 Silverado
Send a message via Yahoo to Ject
Correct ARP Crank Pulley Bolt?
I was curious if I bought the correct ARP bolt.
I am doing the under drive pulley and I bought an ARP 234-2503 bolt kit (comes with a washer).
Can anyone confirm this is correct as it only has about 1.5" of actual thread.
Thanks!
Current Modifications: Your average Bolt-ons & Suspension Upgrades
GForce Engineering: 9" Rear End, Strange Pro Iron Case w/Moser Nodular 3.70:1 Detroit locker, 3.5" Solid Drive Shaft
Ject is offline   Reply With Quote
Old 03-26-2012, 10:16 PM   #2
Ject
aka Patrick
Ject's Avatar
Originally Posted by The LSX Dr. View Post
Yes that is the correct bolt.
Thanks
Old 03-27-2012, 03:38 PM   #3
caper
Drives: 2010 IOM 2ss/RS
I bought a used pulley, is the bolt that came with able to b used again, or is this a one time use item.
caper is offline   Reply With Quote
Old 03-27-2012, 03:40 PM   #4
Ject
aka Patrick
Ject's Avatar
One time only bolt, that much I do know.
Old 03-27-2012, 03:42 PM   #5
Fast Motorsports
Drives: Camaro
The stock bolt is a 1 time use bolt. They are no more than 5 bucks as well new. The ARP is a reusable bolt.
Fast Motorsports is offline   Reply With Quote
Old 03-28-2012, 12:24 AM   #6
caper
25.00. where?
Old 03-28-2012, 12:28 AM   #7
STL_G8GT
Drives: 2009 Pontiac G8 GT
25.00. where?
Scoggins Dickey hooked it up for me...
2009 PBM G8 GT
Pat G Non-DoD Cam, ARP Bits, DSteck/Shane Tuned, Magnacharger Chrome 2300 1:1, RCR Ported/Polished TB, Blower, & L92 Heads w/ LS3 intake valves, Comp Cams Trunion Upgrade Kit, ARH 1 7/8 catted to Hooker Maxflows, RotoFab, CTS-V PWM 1:1 fuel system, ID850 injectors
Mike Norris Motorsports Catchcan, AEM 30-4100, JHP Boost/Fuel Gauge Pod
TSW Nurburgring Matte Gray 18" w/Nitto 555 & 555R, Satin Black SS Brembo Fronts, BMR Trailing Arms, Pedders Sway Bars, Whiteline Bushings
STL_G8GT is offline   Reply With Quote
DIY : Install underdrive pulley on 2010 Camaro SS Nine Ball Camaro DIY & HOW-TO instructions & discussions 34 09-30-2013 09:25 PM
Crank pulley removal ULTRAZLS1 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 14 05-19-2010 03:37 AM
In need of a stock crank pulley litle88 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 2 04-15-2010 09:50 PM
Crank Pulley singing on V6 kellyjrt 5th Gen Camaro SS LS LT General Discussions 7 12-07-2009 02:22 PM
For those that are having to pull the crank pulley off. ThunderSS Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 19 11-06-2009 03:53 PM
