Old 03-26-2012, 11:43 PM   #1
PewterPredator
Drives: 2000 WS6 Trans Am & 2010 SS Camaro
LSX 454 Build: NEED HELP!
Okay, i have a 2010 2SS Camaro 6-speed car.. I recently purchased a LSX 454 through GM, when i purchased the motor i asked about a clutch.. They recommended the LSA clutch, i purchased the clutch and flywheel.. I went to put the motor in my car today and when i would get the motor and transmission lined up i would have around a 3/4 in gap, My bad judgement thinking the clutch "would" work on the car i started bell housing bolts, started tightening the bolt in sequence so i didn't crack the bell housing, i suddenly herd a pop.. Looked down and there was so much tension on the motor it cracked the side of the block on the passenger side.. I pulled the motor back out and measured the factory clutch and there is about 3/4's of inch in the center which was what i was lacking with getting the motor in the first time.. Has anyone had any problems with trying to get a LSA clutch to work? Pictures below of what im talking about with the 3/4in... Thanks for your help, i hope the warranty i purchased through GM with the motor will cover what happend..
1st picture: Stock LS3 Clutch
2nd picture: LSA clutch
The difference is pretty obvious...
Billy
2002 Z28 Camaro
"Silver Streak" - UNDER CONSTRUCTION
2010 SS Camaro
GM LSX 454 - ARH - Hotchkis - Katech - Centerforce - GM Performance Parts - SLP
Tuned by KK Performance *SOLD*
PewterPredator is offline   Reply With Quote
Old 03-27-2012, 02:12 AM   #2
jeremywilson18
jeremywilson18's Avatar
Drives: 2011 Inferno Orange 2SS RS(LSX 454)
Send a message via MSN to jeremywilson18
I used an aftermarket clutch and flywheel, it's custom and the shop ordered it so I don't know what the size is. Hope you can figure it out, you will love the motor
jeremywilson18 is offline   Reply With Quote
Old 03-27-2012, 02:20 AM   #3
jeremywilson18
oh and usually the LSX shares parts with the LS7 so I wouldn't be surprised if it should be the LS7 clutch insted
Old 03-27-2012, 06:59 AM   #4
Rockit_z28
www.1baddogracing.com
Rockit_z28's Avatar
Drives: 2010 IOM 2SS/RS Auto
PM "NC-V" - I am sure Kyle can help you.
2010 Camaro 2SS/RS L99 IOM - 812RWHP 665RWTQ (9.82@139)
Built and Tuned by Heintz Racing
Go: DSS 9", RPM Level X 4L65E, Carlyle Racing 15" Conversion, ECS Paxton Novi 1500, Meth, Squash Fuel, ID850, Gall Racing Forged LS3, A.I. Ported Heads, HR Custom Cam, BMR Susp
Show: Custom Painted Stripes/Badges (Orange Pearl over White), Z/TA Spoiler, VFN Hood, Weld Wheels
http://www.HeintzRacing.com
http://www.youtube.com/user/1baddogracing
Rockit_z28 is offline   Reply With Quote
Old 03-27-2012, 09:31 AM   #5
Fiftydriver
Fiftydriver's Avatar
Drives: 2010 Camaro 2SSRS RJT L99
Was your block spoiled?????
That sucks to be that close and then have to pull it out again.
Fiftydriver
2010 SSRS, RJTC, L99, Maggie 2300 SC, 3.4" pulley, Roto-Fab CAI, Dynatech Supermaxx LT headers, Dynatech High Flow cats, Corsa Cat back exhaust, Dual Elite Engineering catch can, MSD wires and Jannetty custom tune, JRE custom diff w/ posi mod, 3.91 LPE gears, Pfaht trailing arms, Pfaht trailing arm and Diff bushings, drop springs and sport sway bars front and back, Fesler dual guage pillar pod w/ AM Cobalt Boost and A/F guages.
More to come!!
Fiftydriver is offline   Reply With Quote
Old 03-27-2012, 09:51 AM   #6
willhe64
willhe64's Avatar
Drives: 2012 45th Vert, 2011 4x4, 9sec Vega
Did you use a pilot shaft to line up the clutch first?
willhe64 is offline   Reply With Quote
Old 03-27-2012, 10:44 AM   #7
Russell James
Russell James's Avatar
Drives: Camaros
Did you use the correct pilot bearing? There is two different ones. Depending on how far the input shaft sticks out beyond the trans bellhousing.
Put a straight edge across the bellhousing, how many mm's does the input shaft stick out? The GMPP catalog shows which bearing to use depending on that measurement. And a clutch alignment tool or old pilot shaft must be used to line everything up before tightening the pressure plate as mentioned before.
Count your input shaft splines too. Making sure the clutch assembly has the same splines as
the trans. Or slide it on the trans. Just make sure you don't have a 31 spline clutch and a 26 spline trans.
Old 03-27-2012, 02:44 PM   #8
Russell James
Drives: Camaros
Looking closer at the pics, the splines look the same. So I'd be leaning toward either the wrong pilot bearing, or the clutch assembly wasn't lined up with a spare input shaft or alignment tool.
The input shaft measurement will show which pilot bearing it needs. You could also try a test fit of the trans against the block without the clutch/pressure plate in place. It should slide easily on the dowels right against the block. Should never have to draw it in hard with the bolts. And a test fit of the clutch/pressure plate over the trans input shaft.
Any witness marks on the input shaft or pilot bearing that might be showing something was bottomed out?
Old 03-27-2012, 05:03 PM   #9
willhe64
willhe64's Avatar
And for everyone else. Never ever ever ever use the bell housing bolts to tighten the tranny onto the block. It should slide in by hand an with a little jiggling pop on with zero clearance between bell housing and block. If it doesn't, there is something wrong. Take it back off and check.
Old 03-27-2012, 05:09 PM   #10
MA2010SS
Drives: 2010 Camaro SS
Hope you get it figured out
2010 Camaro SS Whipple SC, CAI Inc Intake, TSP 1 7/8" LT headers no cats, 3" magnaflow exhaust, HPT, RX Catch Can, LSR Toe Rods, LSR Trailing Arms, ALKY Control Meth, McLeod RXT Twin Disc, ZL1 fuel pump, 3.73 ZL1 Differential Kit, BTR PDS Stage 2 Cam, Tuned by SLOWHAWK Performance Bridgewater MA
MA2010SS is offline   Reply With Quote
Old 03-27-2012, 05:56 PM   #11
PewterPredator
Well after doing some research, most of you guys are right... The LSA pilot bearing is completely different than the LS3 pilot bearing, so i got with my buddy today that works at a GM dealer and is working on getting GM to warranty the motor since they said the LSA clutch would work with the LS3 transmission, but bad news is if they do not warranty the motor then looks like im gonna have to get another block, it cracked on the driver side of the block right about the dow pin, unfortunantly the crack does going into the rear main so im assuming the block is trash.. Thanks for all you guys help, will keep updated on the way GM handels the situation!
Billy
2002 Z28 Camaro
2010 SS Camaro
Old 03-27-2012, 06:04 PM   #12
PewterPredator
Quick picture of the crack
2002 Z28 Camaro
2010 SS Camaro
Old 03-27-2012, 06:22 PM   #13
BlackIce1066
Black Ice
BlackIce1066's Avatar
Drives: 2SS/RS Black w/ silver ice stripes
Is there a bearing retainer on the transmission? If so, is that where it hit because I notice a nick on the pressure plate where it looks like it bound on.
BlackIce1066 is offline   Reply With Quote
Old 03-27-2012, 06:49 PM   #14
willhe64
willhe64's Avatar
That picture is all blurry through my tears.
I would look into getting that ear tig welded back on. May be a possibility.
Spotted HTR-SS 454 LSX Camaro by DeNooyer-Redline in NY yesterday... Nightfall 5th Gen Camaro SS LS LT General Discussions 69 07-20-2011 11:02 AM
388 LSX Race Engine Build Paul Huizenga Off-topic Discussions 4 07-18-2011 03:39 PM
Can a V-6 model Fit a 454 lsx? LS376 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 6 06-27-2010 06:58 PM
LSX 416 BUILD! ls7camaro Forced Induction - V8 33 06-15-2010 06:40 PM
LSX 454 factory dealer option danraz98 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 14 05-06-2010 11:36 AM
