| Garage / Tools Discussions Discussions about garage setups and general tools discussions. |
Thread Tools |
![]() Drives: Camaro ZL1 Join Date: Feb 2012
ZL1 Portable Lift
Hello all,
Does anyone have any experience with a portable single post column lift like the one listed at http://www.naautoequipment.com/MSC-6...lumn-lift.html I am considering such a lift for getting up under the ZL1 for cleaning and service etc. The low clearance is a concern however this lift appears to be able to roll under the car, rather than have the car have to drive over the frame. good idea or bad idea, I would like to hear your thoughts Thanks. Last edited by camarocam; 03-27-2012 at 02:07 AM. |
![]() Drives: 2011 denali hd2500 Join Date: Sep 2011
It will be too high to go under. you will need to drive on boards to make it work. The only hoist that seem to work good with any of these types of cars are twin post and even then they too are to high to go under the car.
ground clearance
So far the only reference I've seen to ground clearance, was a measurement of the clearance for the front splitter, which was 5.5". the belly of the car should be a little higher 6-6.5". Plus, the ZL1 comes with spring spacer blocks for trailer loading, that could be used to get the lift underneath.
#4 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2013 Triple Black ZL1 Vert M6 ECF Join Date: Mar 2011
![]() Drives: GTO Join Date: Mar 2012
#6 |
Not really, if you had a 2nd person, there should be enough play in the suspension that you could lift at the wheel well to get the spacer in.
#7 |
Drives: xxx Join Date: Oct 2011
Keep in mind that the single and double post lifts need to be anchored in concrete strong enough not to crumble. I do not know the certification or validation process, but check that requirement out carefully.
#8 | |
![]() Drives: 71 Camaro SS Join Date: May 2011
This lift does not need to be anchored to the floor! In fact, it can be moved with a car on it. I just recently needed to reposition the lift to allow me to lift a Sierra 3500 Denali in the garage. |
#9 |
COTW 12/5/11
Drives: 2010 Camaro 2SSRS IOM Join Date: May 2009
My buddy has a 2 post and I have to run Pumpkin up on 2" blocks to use it. Pumpkin is 1.5" lowered. Ground clearance could be an issue.
#10 |
![]() Drives: 01 Trans Am WS6 Join Date: Feb 2012
I have a set of race ramps that are just for getting the car up high enough to use a side post lift or a jack under the car. They may be a little expensive but they work great and they never move regardless of the surface. I think they are called roll ups but I'm not positive
#11 |
Big Papi
any one have this lift? was thinking about getting one. http://www.bestbuyautoequipment.com/...nmarmaxjax.htm
| Thread Tools | |
| Some info for ZL1 owners | R6P | Camaro ZL1 Forum - ZL1 Specific Topics | 60 | 04-30-2013 06:11 PM |
| More Camaro ZL1 info!!! | MS3DALE | Camaro ZL1 Forum - ZL1 Specific Topics | 94 | 06-24-2012 09:44 AM |
| Spied: Camaro ZL1 Track Package / High Performance Package In Testing?! | Tran | Camaro ZL1 Forum - ZL1 Specific Topics | 321 | 10-21-2011 09:08 PM |
| ZL1 vs Corvette- Why do people insist this doesnt exist? Impacts on pricing/perf? | Arachnyd | Camaro ZL1 Forum - ZL1 Specific Topics | 60 | 09-19-2011 04:13 PM |
