Old 03-27-2012, 10:01 AM   #1
Bad70supreme
Bad70supreme's Avatar
Drives: 2010 aqua blue SS/RS M6
1LE gears and half shafts?
You guys think we could swap? ( I am hoping )That would be awesome... could be a better budget priced upgrade. Hell at lest the axles would be great, the price for axles is crazy! Also cant believe this will not be the Z 28... this 1LE is the car I figured for that.
10.91 at 122 H/C stock block N/A
Bad70supreme is offline   Reply With Quote
Old 03-27-2012, 10:04 AM   #2
Synner
Drives: not stock
Not a direct swap. Waiting for someone to swap the whole pumpkin and see if it works. Would love to have the 3.73 gears, iron center, bigger axles, and cooler for autocross abuse.
Old 03-27-2012, 10:45 AM   #3
Bad70supreme
The 1LE actually comes with 3.90s but it did not state that it from the ZL1... I am actaully hoping it is the same rear as the SS just with the 3.90s and better axles!
Old 03-30-2012, 03:42 PM   #4
OC.LS3
OC.LS3's Avatar
Drives: '11 SS, M6 Black w/ IOM stripes
I am interested as well, if you could get the ring and pinion straight from the GM parts desk and have them put it in maybe warranty could be maintained
2011 SS/RS with Hurst short throw. New Era OTR intake, Texas Speed 1 7/8" LTs, Magnaflow mufflers, tuned by Haddad: 420hp/421tq
OC.LS3 is offline   Reply With Quote
Old 03-30-2012, 04:00 PM   #5
cbass
Drives: .
The gear ratios in the transmission are different on the 1LE as compared to the SS. I am sure you can put in a 3.91 final drive, but you will not end up with the same gearing as the SS. In the official 2013 thread I did the calculations for the ratios and speeds. So I guess it depends if you want exactly the same gearing or just the 3.91 for all around lower gearing.
cbass is offline   Reply With Quote
Old 03-30-2012, 05:04 PM   #6
urr2slo
urr2slo's Avatar
Drives: 2010 2ss ss/rs abm, 2016 2ss/rs hbm
Its a 3:91 ratio, it uses the same housing as the regular SS so it is interchangable. you computor would also need to be reprogramed for the different gear ratio. If a GM dealer does the install using new GM parts you get to keep your warranty.
Rick @ Midway Chevrolet
URR2SLO - If you're not going fast enough, get out the way......
urr2slo is offline   Reply With Quote
Old 03-30-2012, 06:59 PM   #7
Avalnch
Avalnch's Avatar
Drives: Rally Yellow Camaro+Avalanche
These must be the same American Axle gears that is currently exclusive to LPE. I sure hope the GMPP parts price will be much better. According to various threads, re-program of the speedo won't be required for our LS3s! Woo-Hoo
I sure hope the forum vendors can provide the 1LE gears and axles once they get a part number for them!
Vengeance Kaotik Cam, C.A.I., ARH LT, Pypes Cat Back, ZL1 Shifter+2012LS3VERT bushing, Quantum Brake Ducts, JDP Tow Hook Scorch Yellow Trim Kit, Shark Fin, AAC DRLs+ABLs+SMDs, ZTA Rear Spoiler, R.Y. 1LE Splitter. Pfadt coilovers, camber plates, trailing arms, Pegasus Solid Subframe. Pedders ZL1 barz, radius arm & steering rack bushings. BMR adjustable toe-rods. Hotchkis Max Chassis Brace. ZL1 GMPP Driveline Upgrade. TurnOne P/S pump.
447 HP @ 6180 RPM / 418 TQ @ 5100 RPM
Avalnch is offline   Reply With Quote
Old 03-30-2012, 09:08 PM   #8
Kronix
NJ/SoCal HT5 COTW 3/25/12
Kronix's Avatar
Drives: 2015 Z06/14 C7/08 Z06/07 Tahoe Z71
This is very good news! Rick do you know when the 3.91 gears will be available?
Built by Late Model Racecraft
Fastest C7 in Tri-State 10.13 @ 134mph
7/26/14 Corvette Challenge Raceway Park, E-Town, NJ
Kronix is offline   Reply With Quote
Old 03-30-2012, 09:47 PM   #9
sizzle06
sizzle06's Avatar
Drives: 2011 2SS/RS Victory Red Camaro
I'm also interested in the gears
sizzle06 is offline   Reply With Quote
Old 03-30-2012, 09:59 PM   #10
Kronix
Kronix's Avatar
It looks like Lingenfelter has the 3.91 Ring & Pinion set for $799, they're manufactured by American Axle & they are the makers of the OE stuff for the Camaros....I bet these are the same gears as the 1LE
http://www.lingenfelter.com/mm5/merc...gory_Code=C366
Old 03-31-2012, 09:02 AM   #11
1977and2010
Tampa Gulf Coast Family
1977and2010's Avatar
Drives: 1977 Z28, 2SSRS 2010 M6
I'm waiting on prices for these too.
1977and2010 is offline   Reply With Quote
Old 04-01-2012, 02:35 PM   #12
UCI CamaroFan
Zot!
UCI CamaroFan's Avatar
Drives: Toyota 4Runner
I'm hoping for this too.
UCI CamaroFan is offline   Reply With Quote
Old 04-06-2012, 08:50 AM   #13
sizzle06
sizzle06's Avatar
Any updates?
Old 04-06-2012, 09:48 AM   #14
Fiftydriver
Fiftydriver's Avatar
Drives: 2010 Camaro 2SSRS RJT L99
[QUOTE=Avalnch;47314 According to various threads, re-program of the speedo won't be required for our LS3s! Woo-Hoo[/QUOTE]
Not sure how this is possible??? The factory LS3 has 3.45 gears, and your saying you can install 3.91s and not worry about recal. the computer, makes no sense.
I installed 3.73s into my L99 and had to recalibrate for correct speedo readings, they ungraded to 3.91s and had to recal again.......
Not required for performance I guess but if you want your speedo to read accurate highway speeds, it will need to be recalibrated.
Fiftydriver
2010 SSRS, RJTC, L99, Maggie 2300 SC, 3.4" pulley, Roto-Fab CAI, Dynatech Supermaxx LT headers, Dynatech High Flow cats, Corsa Cat back exhaust, Dual Elite Engineering catch can, MSD wires and Jannetty custom tune, JRE custom diff w/ posi mod, 3.91 LPE gears, Pfaht trailing arms, Pfaht trailing arm and Diff bushings, drop springs and sport sway bars front and back, Fesler dual guage pillar pod w/ AM Cobalt Boost and A/F guages.
More to come!!
Fiftydriver is offline   Reply With Quote
3:55 gears for V6 2010 Camaro CAMAROKILLS Transmission / Driveline 1 10-22-2012 11:22 AM
Acouple gears questions Cornflakes'Camaro V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 2 02-15-2012 03:13 AM
3:73 RICHMOND GEARS FOR 2010 V6 CAMARO FOR SALE CAMAROKILLS Transmission / Driveline 0 11-28-2011 06:30 PM
Richmond Rear End Gears - 3.73 & 4.10 Sean@Phastek Transmission / Driveline 0 06-02-2010 11:47 AM
