Solo Performance
Old 03-27-2012, 10:22 AM   #1
blake2010ss
blake2010ss's Avatar
Drives: 2010 Camaro 2ss/rs
Send a message via AIM to blake2010ss Send a message via MSN to blake2010ss
pedal return kit question
Anyone running the lingenfelter clutch pedal return kit...question for you. Is it effective? Also, is there much change in the stock pedal feel ? ( for launching at the track mostly)
2010 Camaro 2SS/RS LS3
959/869
416, AGP 6262, E85, Cam
Built by Mayhem Motorsports in Raleigh, NC
blake2010ss is offline   Reply With Quote
Old 03-27-2012, 11:11 PM   #2
blake2010ss
Bump still curious
959/869
Old 03-27-2012, 11:59 PM   #3
1stGM
1stGM's Avatar
Drives: IOM 2SS/RS M6
Effective? Yes.. A bit stiffer, but you will be used to it the first time you drive...
2010 2SS..LS3..Procharger..4l80e..DSS 9"
1stGM is offline   Reply With Quote
Old 03-28-2012, 07:31 AM   #4
blake2010ss
Ok cool.. as long as it doesn't feel like an on/off switch then im good. Riding out on street tires at tge track needs some slip lol
959/869
Old 03-28-2012, 10:10 AM   #5
Heliwrench
Heliwrench's Avatar
Drives: 2010 Black 1SS
Have it... works... stiffer at first but used to it after a day.
2010 Black 1SS LS3 M6
Power: Kook's 1 7/8" Long Tubes and 3" Exhaust, Injen Full Length CAI, Jannetty Tune
Drivetrain: MGW Short Shifter, Street Slayer Twin Clutch, DSS 1 Piece Aluminum Driveshaft, DSS 1000HP Axles, BMR Pro and Delrin Diff Bushings
Suspension: BMR Trailing Arms and Bushings, FE6 Swaybar Conversion With Pedders 27mm Front and 32mm Rear ZL1 Swaybars and Links
Chassis: Hotchkis Chassis Max Brace, BMR Pro Cradle Bushings
Exterior:: Shine by Adam's.
...and plenty more
Heliwrench is offline   Reply With Quote
Old 03-28-2012, 01:38 PM   #6
Ledzepx
Ledzepx's Avatar
Drives: 2010 2SS Camaro 6sp.
Ordered mine over the weekend. Should be here tomorrow.
Also I had a question about the clutch sticking. Here is the thread on that.
http://www.camaro5.com/forums/showthread.php?t=211391
Living the dream!
www.rsconversions.com
Ledzepx is offline   Reply With Quote
Old 03-28-2012, 03:22 PM   #7
Squintz Palladoris
Squintz Palladoris's Avatar
Drives: 2010 IOM 1SS M6
x2
Squintz Palladoris is offline   Reply With Quote
question, lowered with stillen body kit. SoCal Swagger Cosmetics and Lighting Modification Discussions 2 11-07-2011 01:14 PM
clutch pedal repeatedly stuck, minimal load cab2g Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 2 04-26-2011 10:39 AM
GFX Kit Question xLoGiK1 Cosmetics and Lighting Modification Discussions 9 08-10-2010 03:12 PM
Ground Effects Kit question raad Cosmetics and Lighting Modification Discussions 5 09-21-2009 02:19 AM
Dead pedal question for those who were at Indy fastball 5th Gen Camaro SS LS LT General Discussions 21 09-29-2008 01:30 PM
