JDP Motorsports
Old 03-27-2012, 10:34 AM   #1
TonyC
TonyC's Avatar
Drives: 2010 2SS/RS
rocker arm question
hello all,
i had a cam installed last year (custom ground) from a "reputible" shop that i will not name...i have maybe 500 miles on the car since and im getting valve train noise..i dont know the cam specs (its a secret lol) all i know is supposidly 680 lift ,110lsa..i have tried to call the shop and find out and got no response..i would like to replace the rockers (no trunion upgrade) i dont know what to buy brand/ratio...if the lift is as high as the shop claimed i cant run 1.8s right? im gonna do the work myself...i am done with shops after my last experience...any help would be greatly appreciated.
just a side note...the noise developed after a 100 miles or so and i have never gotten a call back since i paid for the job....now that the weather is getting nicer i want to actually use the car a little and enjoy it,
Thank you guys
Tony
2010 camaro 2ss/rs
Afe intake,Ported heads,ported manifold &TB,Big Cam, Arh longtubes w/3",25% underdrive,aluminum flywheel,zr1 clutch, tranzilla 6060, gforce 9" strac 430s...worst tune in the world...dc power 300amp alt, audison/kenwwod/cdt system.pfadt/eibach/hotchkis/bmr susp...vented/drilled rotors, hawk pads,s/s lines
work in progress : Full electric power steering & Airride
TonyC is offline   Reply With Quote
Old 03-27-2012, 10:38 AM   #2
mikeSS
mikeSS's Avatar
Drives: 2015 c7
go into more detail about valve noise. do you hear it at idle ?, certain RPM? when cold or hot ? all the time ?
Old 03-27-2012, 10:45 AM   #3
TonyC
TonyC's Avatar
Drives: 2010 2SS/RS
all the time..cold or hot seems worse when hot...i havent driven the car since and actually moved and had the car flatbedded to the new house cause im afraid to drive it and damage anything...after 8 months of trying to get answers from a shop that doest return calls im fixing it myself..
i have a bad leaking pass side valve cover as well and will be pulling them once my gaskets arrive. i wanted to do the rockers while i was in there...
its a clicking under the valve cover...not like an injecor tick,, more clicking sounds...i can see if i can shoot a vid at idle and post it if that helps....i used a scope and its coming from under drivers side valve cover
2010 camaro 2ss/rs
Old 03-27-2012, 10:51 AM   #4
hypurone
I'm not totally useless..
hypurone's Avatar
Drives: 2010 SIM 2SS/RS A6 SC LPO Rallies
Send a message via AIM to hypurone Send a message via MSN to hypurone Send a message via Yahoo to hypurone
Were the springs changed at the time of install? Singles or doubles? It is quite possible that the lifters aren't handling the higher lift very well. LS3 or L99?
My point being that the trunnions/arms aren't really prone to failure....
"You were really flyin' when I passed you back there!" - Born on 10/05/09 MyCamaroBuildInfo
hypurone is offline   Reply With Quote
Old 03-27-2012, 10:52 AM   #5
mikeSS
mikeSS's Avatar
Drives: 2015 c7
ya its always good to post a vid. might be something else. anyways thats really bad that a shop has not gotten back to you in 8 months ! thats just crazy ! the question i would ask is are they still even in business.
well hopefully someone can help you with your other questions i am just questioning the noise.
Old 03-27-2012, 10:52 AM   #6
Lee123
Lee123's Avatar
Drives: 2012 2SS M6
By " (no trunion upgrade)" do you mean they didn't do the trunion upgrade when they installed the cam? When I got mine they said it should be done if the lift is over .610. If that is accurate, this could be the cause of your noise. Also, how's your oil pressure? Low oil pressure at idle can cause valve train noise with hydraulic lifters.
Have you tried going over to the shop to see if they are even still there or are out of business?
2012 2SS Convertible
Magnuson, Headers, Cam, JRE Tune. 563 HP.
Lee123 is offline   Reply With Quote
Old 03-27-2012, 10:54 AM   #7
TonyC
TonyC's Avatar
Drives: 2010 2SS/RS
they did double springs and did not do a trunion upgrade, i would rather change the rockers rather then the upgrade..oil pressure is solid at low 30s at idle (700-850) or so
2010 camaro 2ss/rs
Old 03-27-2012, 10:55 AM   #8
mlee
www.CamaroFest.org
mlee's Avatar
Drives: 2017 A10 ZL1
680... and you don't know the specs... WoW... dangerous..
Old 03-27-2012, 10:56 AM   #9
TonyC
TonyC's Avatar
Drives: 2010 2SS/RS
pics of parts
springs used
2010 camaro 2ss/rs
Old 03-27-2012, 10:58 AM   #10
TonyC
TonyC's Avatar
Drives: 2010 2SS/RS
i contacted the shop prior to the work saying that i wanted a cam and he told me he knows the "perfect formula" for these cars to make power...ill admit the car is fast as hell..but i need reliable too...the shop is still in business and actually very well known..i refuse to bad mouth them...its my fault for not doing my homework
2010 camaro 2ss/rs
Old 03-27-2012, 11:01 AM   #11
TonyC
TonyC's Avatar
Drives: 2010 2SS/RS
he also locked my computer after the tune...so how can i go get a re tune unless he unlocks it ???? but how can he unlock it if hee doesnt answer calls/messages...lol
2010 camaro 2ss/rs
Old 03-27-2012, 11:06 AM   #12
Lee123
Lee123's Avatar
Drives: 2012 2SS M6
That sucks! How do you know it is locked? Did he just tell you?
Old 03-27-2012, 11:07 AM   #13
TonyC
TonyC's Avatar
Drives: 2010 2SS/RS
after speaking with people (mostly vette owners) and other shops thats what he does...everyone else that has work done from him had to go back to him for any retunes
2010 camaro 2ss/rs
Old 03-27-2012, 11:10 AM   #14
TonyC
TonyC's Avatar
Drives: 2010 2SS/RS
again i am not publicly bashing any company....i personally wouldnt ever go back...i understand crap happens, and maybe a rocker failed or something...understandible..i also understand that if he wants to lock peoples computers so nobody knows the tune then so be it..but his CUSTOMER SERVICE or should i say lack of..is something that made him loose a customer
2010 camaro 2ss/rs
Has anyone broke one of these yet? (Rear Lower Control Arm Endlink Tab) PQ Suspension / Brakes / Chassis 633 09-01-2014 09:43 PM
FS: COMP shaft rocker system Total_Perf_Eng Engine Internals 6 10-17-2011 03:06 PM
BMR Launches New Product - Torque Arm Suspension for 70-73 Camaro/Firebird BMR guy 1st & 2nd Generation Camaros 1 02-24-2011 12:51 AM
Quick Question... regarding front control arm tples69 Suspension / Brakes / Chassis 0 02-23-2010 10:22 AM
