Old 03-27-2012, 09:49 AM   #1
ITGuy11
Burning up tires
ITGuy11's Avatar
Drives: 2010 Camaro 1SS/RS
Question for Cammed guys
Since I installed my JRE 470 cam package, I no longer get the decel pop. Before the cam install she popped like a angry bitch
Is this a function of the cam changing the valve timing or a function of the tune?
Blower, cam, supporting mods 644RWHP 615RWTQ
My Build Thread COTW 11/19/12
Detroit 5th Gen Camaro Club
ITGuy11 is offline   Reply With Quote
Old 03-27-2012, 09:55 AM   #2
Lee123
Lee123's Avatar
Drives: 2012 2SS M6
Pretty sure it's the tune. Mine pops about as much with the cam as it did before.
2012 2SS Convertible
Magnuson, Headers, Cam, JRE Tune. 563 HP.
Lee123 is offline   Reply With Quote
Old 03-27-2012, 09:56 AM   #3
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
It's the tune.
SUX2BU is offline   Reply With Quote
Old 03-27-2012, 10:00 AM   #4
mikeSS
mikeSS's Avatar
Drives: 2015 c7
mine is not there also. wonder why they tuned it out. i see a lot of people saying the same thing.
Old 03-27-2012, 10:07 AM   #5
LDHitman23
LDHitman23's Avatar
Mine has left me as well. I can get it sometimes but not all the time like I did when I first got my headers. Kind of missing it.
Texas Speed LT Headers (no cats), LS3 Monster blower cam, Muffler Delete, Stage 3 Spec 3 Clutch,102mm F.A.S.T Intake Manifold, Comp Cam Push Rods, Comp Cam Dual Springs, D1-SC Procharger, ID850cc Injectors, Stealth Fuel Pump, F.A.S.T Fuel Rails, Tune by Brett Seaburg, Nitto Street Radials, Amber Halos and Fog Lights, Window Tint (5%) Nightshade Tail Lights, Interior Amber Dome Light and Trunk.
LDHitman23 is offline   Reply With Quote
Old 03-27-2012, 10:10 AM   #6
Lee123
Lee123's Avatar
Drives: 2012 2SS M6
I'm curious about that, too. I'm wondering if there is a reason to have it gone and something got missed on mine or if they just tune it out it because a lot of folks don't like the popping. I like it myself and I'm glad it's still there.
Old 03-27-2012, 11:15 AM   #7
SSDan
SSDan's Avatar
Drives: 2016 1SS 6MT NPP
I dunno what my tuner did - forgot to ask. Next time I talk to him I'll ask. However, mine still crackles and pops at times under decel - coast down situations but more like my older muscle cars did back in the day. I liked the stock engine decel pop but it aways sounded more artificial - not natural and the popping I get now sounds more normal/natural if that makes sense.
2010 Camaro 2SS Cam/Headers/CAI/3.91 gears
476 rwhp/440 rwtq (sold)
SSDan is offline   Reply With Quote
Old 03-27-2012, 12:07 PM   #8
Fast Motorsports
Drives: Camaro
It is a function of the tune. The popping is from a lean condition from Decel fuel cutoff. Now with the new parts and the way the tune is setup it is either turned off or you are not hitting the correct condition to go into DFCO anymore. Some tuners turn it off especially in cam'd vehicles since owners have complained that it is not a sound they like. Shoot an email over to your tuner and we are sure they will explain what they did in your tune for you.
Fast Motorsports is offline   Reply With Quote
Old 03-27-2012, 12:18 PM   #9
Lee123
Lee123's Avatar
Drives: 2012 2SS M6
Is the popping or the lean condition that causes it in any way harmful? I know being lean under a load will burn valves or worse. My AFR is right at 12 at higher RPM's on the dyno and a bit leaner in the in the midrange, around 12.5, so it's sure not lean. Now that SSDan mentioned it, the popping is a bit different than stock but sounds good to me.
Old 03-27-2012, 12:22 PM   #10
Bad70supreme
Bad70supreme's Avatar
Drives: 2010 aqua blue SS/RS M6
I have to dissagree... I have my cam and been driving it on the 2nd week no tune. ( not untill the 4th ) and my decel popping is also gone!
10.91 at 122 H/C stock block N/A
Bad70supreme is offline   Reply With Quote
Old 03-27-2012, 01:42 PM   #11
Fast Motorsports
Drives: Camaro
It is not harmful. Basically under no load conditions the injectors are shut down to help save a little fuel economy.
Sounds like your current AFR's are well in the safe range.
Then you are in the second case of no longer reaching the factory parameters to go into DFCO. You have to be within a certain ECT, RPM, Speed, TPS and Load. Seeing that you have a cam and no tune your load reading are currently off slightly and keeping you outside of the factory limits.
Old 03-27-2012, 02:45 PM   #12
Bad70supreme
Car will tuned next week, it actaully drives very good just the idle is to low with a little hunting on a slow down. Cant wait to get it tuned.
Old 03-28-2012, 09:32 PM   #13
NC-V
NC-V's Avatar
Drives: cts-v
Many tuners will turn it off and leave it off because you have to turn it off anyways when tuning fuel trims and many people find the sound annoying. If they do turn it back on and leave it at factory settings, (depending on cam) all the conditions to activate DFCO (what makes the popping noise) may not be met. If you would like it activated, ask your tuner to street tune it with you in the car so they can set the aggressiveness and conditions to your liking/driving style.
NC-V is offline   Reply With Quote
AEM boost gauge question Whipple guys MA2010SS Forced Induction - V8 4 03-23-2012 10:01 AM
got a question to all you guys that mod alot dshep214 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 36 12-19-2011 06:44 PM
Question for the V6 guys 'n gals... Revenant 5th Gen Camaro SS LS LT General Discussions 12 06-26-2011 12:36 PM
Guys with Upgraded Clutch Setups.....Have a question HufferSS Forced Induction - V8 5 06-01-2011 07:07 PM
got a question for the Diablosport guys... fastscout Tuning / Diagnostics -- engine and transmission 9 04-22-2010 07:31 PM
