| Forced Induction - V8 V8 Supercharger, turbo, nitrous discussions |
Thread Tools |
#26 |
![]() Drives: Audi A4 Join Date: Mar 2012
Fabbed up my tanks and started the IC plumbing today.
Some more of my work in this link.
http://www.cardomain.com/ride/280589/1 |
#27 |
Tight fit to say the least...
![]() ![]() ![]() ![]() On to the downpipes, turbo oil supply, and heat protection tomorrow.
#28 |
Drives: 2010 SS, 06 SRT10 Ram Join Date: Nov 2011
![]() I smell another up in a cloud of "explosion" thread coming. |
#29 |
Got started on heat protection.... heads/coils and hood still to get done.
#30 |
Fabricator
Drives: 2011 2SS Summit White Join Date: Jun 2011
Great job. What kind of insulation will you be doing to the headers? Coating, wrap, both?
Roto-fab CAI
Unobtainium Exhaust AR lt's 330whp L99 |
#31 |
need....more....hp
Drives: The Neighbor Hater Join Date: Dec 2010
Love all the custom work you are doing on your car. There aren't many twin turbo builds out there, but yours is def unique. I wish I had the money to do a custom setup. All of your work looks like top notch!
Some people are saying "it'll blow up" but just get the tuning done and enjoy your build!
Mast Motorsports Built LS3 Stroker 418, IPS GT35R Twin Turbos, Exedy GTO4XD Twin Disc Clutch, Aeromotive A1000 Eliminator Stealth Fuel Pump, AEM Meth Injection, DSS 1400hp Axels, BC Coilovers, Pfadt & BMR Suspension, Hawk HPS Pads, Drilled/Slotted Rotors, Hurst Shifter, Custom Roll Cage by Blu808, T3 Ports, 22" Custom Concave Mesh Rims |
#32 |
P90X
Drives: 2000 SLP SS VERT Join Date: Jul 2009
nice job. cant wait for results
2000 Camaro SS/SLP
P90X changed my life. Want to know more, PM me for more info on changing your life for the better |
#33 |
Excellent fabrication work!
2010 Camaro SS Whipple SC, CAI Inc Intake, JRE 4.11 Gears, TSP 1 7/8" LT headers no cats, 3" magnaflow exhaust, HPT, RX Catch Can, LSR Toe Rods, LSR Trailing Arms, ALKY Control Meth, McLeod RXT Twin Disc, DSS 1000HP alxes, DSS aluminum DS, ZL1 fuel pump, Tuned by SLOWHAWK Performance Bridgewater MA 577RWHP
#34 |
![]() Drives: 2010 Camaro SS,2008 Hayabusa Join Date: Jun 2010
What would a set of those headers cost me if you built the and shipped them.
#35 |
These manifolds are made to fit a set of S300 Borg Warner turbos. They are a large frame turbo I do not recommend trying to fit in this engine bay. An eqivelent in a Garrett would be a better fit. IE 2 GT4094 or T4 GT35. There is too much modification needed to make this combo fit effectively and for me to sell in the market as a "kit". I know it would come back to haunt me. ABS/Fuel lines/fuse box/AC/brake lines/ECU/PS reservoir/pump all had to be moved or altered to make it work. The turbos don't fit by the bell housing either, and I'm not fan of remote mount.
Borg sponsored the turbos, so lets give it a rip. I'll be doing a second kit that will be much more executable in your home garage on a relatively stock car. Headers of this nature in 321 stainless usually start at $1600-1800 per bank from me. Im not here to push header sales. I couldn't find a local M16 extention fitting for the oil feed on the turbos, or get one shipped in a resonable time frame, so I made one. Two unions lathed down and welded to fit -4 outlet. ![]()
http://www.cardomain.com/ride/280589/1 Last edited by California Jay; 04-20-2012 at 09:34 PM. |
#36 |
HKS Filters came in and I got some great fittment done on the recirculating dump tubes... I would have liked to get the dump entry down stream further though.
#37 |
![]() ![]() ![]() ![]() ![]() Drives: G5R Join Date: Sep 2010
SICK!!!!
#38 |
Virgil, Satan's Camaro
Drives: White 2010 Camaro SS Join Date: Mar 2010
First I'd like to say your work is amazing. It looks fantastic.
I do have a question though, about the proper functionality... I've recently had a front mount turbo installed on my 2010 Camaro and have firsthand experience of how hot the headers get as they come forward in the engine bay... looking that the photos you've provided it appears that the headers actually reach a point higher in the engine bay than the intake manifold which would put them within an inch or so of the top of the hood when its closed. Arent you a little concerned about the heat causing damage to the hood? Or at least discoloring the paint/causing the paint to flake off? Or do you intend on installing vents into thd hood at those high points? Just curious how you’re handling the heat up there. Thanks Craig
White 2010 Camaro SS/RS - HPS Front Mount Turbo System, Custom Turbo Cam, ZL1 Fuel Pump, 80lb injectors, Eibach Front/Rear Swaybars, BMR Tower Brace, Eibach 1" Drop Springs, Drilled-Slotted rotors, Foose Legend SS wheels, Bluetooth Module, PDIM and Steering wheel controls, Prosport EVO Pillar Gauges 635rwhp/735rwtq
#39 |
Thanks to all...
I work for a Vibrant Performance, we carry a heat sheilding line that is a multi layer heat protective sheild. I will be riveting it to areas of the hood to deflect heat and protect the hood. Theres close to 2.5" of space at the tightest point, this should be good enough for our 600F or 1400F rated sheilding to do its job in this application. I'll either keep it flat or make it chanelled to surround the manifolds while the hood is closed... also protecting the coils.
#40 |
Man that is freakin awesome.
My car is stock.....ish
#41 | |
![]() ![]() Drives: 2010 SS/RS Twin Turbo Join Date: Feb 2012
![]() Sent from my iPad using Tapatalk HD |
#42 |
Southwestspeed.net
![]() Drives: '10 2SS/RS, '96 Z28 Join Date: May 2009
Wicked Welds! Lemme know if you ever need a job....
Ivan @ Southwest Speed
#43 |
LED god
Drives: 2010 Inferno Orange Camaro SS/RS Join Date: Oct 2010
I hope you don't wrap the turbo headers, they are a work of art!
#44 |
chevy pride
that is just sick .
#45 | |
![]() Drives: 930 Join Date: Apr 2012
dont know how hard your going to push the kit but those filters are going to be its downfall, google "hks green death mushroom" and you will see pleanty of problems with them. hence the name the "green mushroom of death" |
#46 |
![]() ![]() ![]() Drives: 04 Silverado Join Date: Jun 2010
Beautiful fab work. Yeah I aint found of those filters either, but hey if thats what the customer wants... thats what they get
#47 |
I've never had a problem with the filters... we'll have to see I guess. All I have left to do is clutch (triple disc Exedy), brake lines, AC lines, and exhaust. I'll get up some more pics soon. I"ve been a bit delayed due to some other design projects.
#48 |
Update
Here is the car as it stands at PRI this w/e. Now with a 7.1 ltr and just over 1000hp. I had to stop progress due to time line and other projects at Vibrant Performance. The car was brought to this stage at Katech Performance. They have done a great job - hats off to them, this was a tight fit. I wish I was given the time to give it this detail. ![]()
#49 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: a Jet :-) Join Date: May 2009
Jay, you are VERY good. Nothing else to say...
#50 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 SS/RS M6/2500HD Lmm LTZ Join Date: Apr 2012
Thats perfection like ive never seen before and talented doesnt even begin to describe this man.
| Thread Tools | |
| Street Slayer Brought to you by Hendrix Engineering | Hendrix-Engineering | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 2 | 12-08-2011 04:32 PM |
| Vengeance Racing custom Twin Turbo C6 Z06 build | Ron@V | General Automotive + Other Cars Discussion | 6 | 03-31-2011 05:40 AM |
| Camaro 2ss STS Twin Turbo Build | Bowtie Guy | Forced Induction - V8 | 28 | 03-27-2010 10:04 AM |
| STS Twin Turbo Kits Coming Soon!!! | tbyrne | Forced Induction | 18 | 10-19-2009 10:06 AM |
| Check your Order here | bvonscott | Camaro Price | Ordering | Tracking | Dealers Discussions | 665 | 06-29-2009 01:00 PM |
