| Camaro V6 LLT Engine, Exhaust, and Bolt-Ons Bolt-Ons | Intakes | Exhaust |
Thread Tools |
#26 | |
#27 |
Drives: jealous vendors mad!! HAHA!! Join Date: Jan 2011
I don't think it would matter weather the car is modded or not. If the test was done between two completely different modded cars than that would be inaccurate, but this test was done very fairly, non biased, on the same car, just two different spacers. To me the test clearly show that the ice win up top and mace win at the bottom which in theory it make perfect sense. Both winners in my book and I don't see the need for this to be dragged any longer.
Sent from my POS phone using tapatalk. |
#28 | |
crazier than a coconut
Drives: 2010 2SS/RS LS3 Join Date: Jul 2010
but hey, anybody that wants to continue comparison testing...go for it obviously heat soak of the air intake is an enemy to these motors. i think if they were the same thickness, then the results would have been nearly identical. but runner length has been proven over and over to change the dynamics of TQ/HP. increased runner length and isolation of the IM from engine heat is what creates the difference between these two...modded, heavily modded, or bone stock. and that is why i don't feel that the results will differ much in comparison. but then again, i've been wrong before. just my .02 Black Ice = higher HP up top Mace = higher TQ low-mid range
#29 |
![]() ![]() Join Date: Jul 2009
I agree that it may not make a difference in the amount of mods, but only one way to find out.
I mentioned the main reason I would like to do that testing in that 90% of the folks out there on a budget will only want to do, or only be to afford to do, a VMax TB, intake spacer (Mace or VMax) and some kind of CAI. All in all good info and hope to hear from MACE or one of the US suppliers (If there are any). Mike Norris
Raymonds Performance
Mike Norris Motorsports www.mikenorrismotorsports.com 407-616-2518 thevettedr@aol.com |
#30 |
They see me trollin'...
Drives: 217 ci of fury; Chauffeured by SS Join Date: Jul 2011
Seems like six one way, half-dozen the other to me?
"Never race anything you can't afford to light on fire and push off a cliff." -CamaroSpike
2011 Custom LT/RS: Bella's Build Thread |
#31 |
Always good to get a gals perspective
To be honest, I do not know of anyone that can feel a difference of anything less the 10HP or 10TQ in a 4000 pound car and this is 3HP one way and and 5TQ the other.Mike Norris
#32 |
i don't disagree with seeing what the gains will be on a stockish motor...just not certain that data will be any more conclusive, thats the point im trying to make.
here is my original dyno before/after with MACE's 25mm...mods: Injen CAI, RX TB, 25mm spacer, TUNE (93 octane), and ARK exhaust. since then, i've added a ported IM and run on E85. the difference was noticeable then and still noticeable now...just sayin. if you look closer, you'll see the gain on the TQ gain on the previous dyno does hint around a 10point gain vs 5. 10HP/TQ is noticeable when your in the 200's range. 10HP/TQ difference on a 500HP motor won't be as noticeable on a butt dyno, but at that point your now talking tenth's - thousandths of a second on the 1/4 mile where you'll see the difference. following dyno is for reference purposes only in regards to this conversation. not intended to promote one product or the other. simply as a reference to the shift of HP/TQ and the user (myself) feedback.
#33 | |
#34 |
Bmore you should really start a thread about how you got the 25mm + Vararam to work out with tons of pics!
![]() Not like you're busy with Vince or anything!
#35 | |
![]() Uhhhh.. you are no good chad LOL! Got everything I need for the dyno, FINALLY, so I should be back on the dyno sometime early next week for my own tuning needs and also to find out if the update is going to happen or not. ![]() As far as the vararam and 25mm spacer...I just don't know if is really even a thread starting subject. You basically have to do a little sculpting and just cut the rear neck to an angle until you are comfortable with the gap at the radiator. I actually used a die grinder with my 80 grit cartridge rolls that I use for porting since I had it next to me at the time of doing this. A dremel would work perfect too. Also note that the angle does not have to perfectly match up with the tip of the throttle body. The rear neck will line up straight with the top and bottom area regardless of the angle due to the red coupler that hold the rear neck and the throttle body together. You just have to focus on the front gap. Just shave off small amount at a time until you are comfortable with the gap. I was going to take some pics for you guys today but I ended up making a mistake and spilled some engine degreaser on my maf and all over my vararam tray and filter . I spent most of the day today cleaning up the mess.I will post up more pics for you guys sometime tomorrow |
#36 | |
#37 |
That pic I uploaded is actually the rear neck cut to a slant by vararam guys their self when we was having fitment issues last year. I asked Steve@vr already about this and he said that it was ok and shouldn't alter performance. I been checking my logs day and night for anything out of ordinary and from my timing, trims, to airflow is all good.
I know, those darn pics:what: I keep forgetting..I believe either Mach or ventmaster actually did a write up on this not to long ago. Sent from my POS phone using tapatalk. |
#38 |
![]() Drives: 2010 1LT RS A6, C&C, Victory Red Join Date: Feb 2010
Is it physically possible to stack one of the shorter MACE (maybe the mid-sized one; I don't remember the size) spacers on top of the Black-ICEolator without causing some sort of air leak? =P
Performance Mods: Injen Powerflow CAI, Doug Thorley Cat-Back Exhaust, Doug Thorley Shorty Headers, Trifecta Tune, TSW Nurburgring Wheels 20x9, 3.45 Ratio LSD Swap, VMax Black Ice-Olator
Appearance Mods: RiderGraphix LS7 Front Fascia Blackout Vinyl, Gill Insert Vinyl, Rear Deck Lid Vinyl (Gloss Black), Gary's Customs Painted Bowties Coming Soon: BMR Trailing Arms |
#39 |
would "probably" work fine as long as you sealed it up good with gasket maker. i did notice after pulling the Black Ice off that it had some minor warping from what i believe was caused by heat stress. i think you could pair it up with the 25mm insulator, which will use all the available space up to the wiper cowl. but the term "keep it simple..." might be one of those things thats plays a role if you get too many moving pieces. guess its worth a shot. the Black Ice is right around 9-10mm think (leaning closer to 9 if i remember correctly).
#40 | |
![]() Drives: Beest Join Date: Aug 2011
#41 |
I agree with hapi, but I wouldn't go pass 25mm, so as long as you can keep mace and vmax under 25mm mated together you should be fine. You guys will find out later why I am saying this
Trust me |
#42 |
Drives: Green Dream Machine Join Date: Mar 2011
Vmax just needs to make a 25 MM Black Ice Plate. But I can't see them doing that to Mace. But what I can see is someone else doing it to both Vmax and Mace. It would be nice if they would combine their products into the Mace\Vmax Performace Heat Isolator.
#43 |
||||Tuners Impression||||
Drives: Fairlady Z/LLT/LS3 Join Date: Sep 2011
Some peoples take vendor love to whole another level that is almost scary
black ice infidelity![]()
(2011 LLT) MRT V2//MACE 25MM INSULATOR//BMORECAMS STG-3 INTAKE MANIFOLD//VARARAM//HPT or NOTHING!! (2010 LS3) OTR INTAKE//HPT VIA TUNER IMPRESSION//KOOKS STEPPED//MUFFLER DELETE --FAIRLADY Z-- 12.9 1/4 MILE |
#44 | |
too funny
#45 | |||||
--WORLDWIDE DEALER--
![]() Drives: LLT Machine Join Date: Nov 2011
Hapisok,
Well done on the review/testing, it basically validates what we’ve been saying all alone and that is it’s the runner length and not so much the cooler manifold that give the gains Quote:
To elaborate what Tracy has mentioned there is no right or wrong product here in this context, it just depends on your driving requirements as I’ve mentioned many times over Quote:
If anything the 25mm manifold insulator would work better on a stock car then the thinner varieties. I say this as with aftermarket gear such as an exhaust system, better intake etc, they tend to work best in the upper rev range. This is in contrast to the factory stuff which is restrictive higher in the rev range. Therefore putting on an insulator which is more biased towards gains top end on a restrictive factory setup is counterproductive, unlike a thicker insulator which is more efficient down low being more compatible with the restrictive factory gear as it still flows relatively well in the lower to mid RPM ranges. As for testing, I’m easy ![]() The only catch is now days are that we need a bond for parts, which is refunded once the results are in. Why? Well early on in the piece I actually sent a C5 member 3 sets of our insulators for testing (6, 12 and 25mm) for free. Claimed financial hardship, I offered to pay to on forward these items onto another enthusiast for testing, never heard from them again, then found out there were SELLING these insulator kit for $150 each!!!!!! And no I never saw a single dime from these sales. Who knows what the future may bring I guess, honorable people are a rarity these days :( . All I can say in the present is that the heat transfer/reduction difference between the two products at the same thickness is negligible. Unless you wrap the manifold around with an insulated collar, you still have a noticeable amount of heat transfer due to convection and radiation. You just have to look at the surface area of the manifold which is still exposed, to appreciate where I’m coming from. |
#46 |
So I stand corrected. The insulator will make even more of a drastic increase. And for those who aren't as heavily modded as myself...win win
#47 |
From MACE_ENG "Mike, If anything the 25mm manifold insulator would work better on a stock car then the thinner varieties. I say this as with aftermarket gear such as an exhaust system, better intake etc, they tend to work best in the upper rev range. This is in contrast to the factory stuff which is restrictive higher in the rev range.
Therefore putting on an insulator which is more biased towards gains top end on a restrictive factory setup is counterproductive, unlike a thicker insulator which is more efficient down low being more compatible with the restrictive factory gear as it still flows relatively well in the lower to mid RPM ranges. As for testing, I’m easy The only catch is now days are that we need a bond for parts, which is refunded once the results are in. Why? Well early on in the piece I actually sent a C5 member 3 sets of our insulators for testing (6, 12 and 25mm) for free. Claimed financial hardship, I offered to pay to on forward these items onto another enthusiast for testing, never heard from them again, then found out there were SELLING these insulator kit for $150 each!!!!!! And no I never saw a single dime from these sales." I understand about trusting folks for sure and that is why I said I would buy a set if need be. I only mentioned a free set as Tracy sent one of the VMax items out no problem. I am only looking into getting a 25mm version right now as that what was tested here. If you want to make me a deal on all three I will consider it for sure. Feel free to PM me if you want. I am not looking into proving anything one way or the other, just curious as. Let me know and thanks. Mike Norris
#48 |
Mike,
Are you planning to do back to back pulls or provide ECU relearn time? I don't recall the process in which you tested the black ice...just curious about your plan of attack to compare these. There has been discussion before about the gains from the various sizes but nothing has been shown yet due to the issue Steve mentioned earlier. Can't wait to see what you come up with...
#49 | |
#50 | |
Waiting to hear back from MACE and we will go from there Mike Norris
| Thread Tools | |
| 2LT IOM, IO interior, black stripes, documenting my changes | rtcat600man | Member Car Journals | 172 | 05-07-2013 08:54 PM |
| Cadillac Reveals Black Diamond Edition CTS-V | FenwickHockey65 | General Automotive + Other Cars Discussion | 36 | 02-07-2011 11:21 AM |
| DSV/*********** Black Friday Blowout-Best Prices Of The Year 24 Hours Only!!!!! | Indpowr | Interior Parts & Accessories | 23 | 11-27-2010 11:26 AM |
| HELPPP can i use the ICE Wax on flat black stripes | Gavros 4 Life | Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection | 16 | 06-29-2010 08:30 AM |
