Old 03-28-2012, 08:48 AM   #1
matthook
matthook's Avatar
Drives: 2012 IBM Camaro 1LT RS
Question Steering Wheel Jerking
Hey guys and gals,
So i've been noticing something different the last 2 weeks. It seems like whenever i hit any sort of bump, my wheels want to shoot off in that direction. What i mean is that when im hitting a bump or part of the road that is uneven, it seems like the car tries to veer off to the side.
At first i thought maybe there was something wrong with my alignment... but it happens on BOTH sides. sometimes the steering wheel moves by itself way to the left, sometimes to the right...
Any ideas whats going on? Or am i just crazy and this is bound to happen because of the fact that the wheel on the ground are turning to either side when they hit an uneven surface?
-Xbox Live: MattCaptainH00K (0s are zeros)-
Team LFX Thread Link: http://www.camaro5.com/forums/showthread.php?t=187109
Team LFX Group: http://www.camaro5.com/forums/group.php?groupid=306
matthook is offline   Reply With Quote
Old 03-28-2012, 08:54 AM   #2
Moorepheus
Drives: 2013 Dodge Charge R/T Plus AWD
Take it to the dealer, should be under warranty.
Moorepheus is offline   Reply With Quote
Old 03-28-2012, 09:33 AM   #3
gorgeous-ss
Drives: 2011 ss/rs
How low are your front tires (tread wise) mine are getting bad and do this now from the tires being bad
Sent from my DROID RAZR using Tapatalk
gorgeous-ss is offline   Reply With Quote
Old 03-28-2012, 09:38 AM   #4
IBM
IBM's Avatar
Drives: '11 2LT/RS IBM
Mine does this all the time, I think it's normal for these cars.
IBM is offline   Reply With Quote
Old 03-28-2012, 09:42 AM   #5
Kevinshawnm
Biggz
Drives: 2010 Camaro 2SS L99 Rally Yellow
Check your tire pressure.
Kevinshawnm is offline   Reply With Quote
Old 03-28-2012, 09:44 AM   #6
BigCarrot
xbox: this is tedious
BigCarrot's Avatar
Drives: 2011 1SS M6 Camaro IOM
Only happens occasionally where one wheel is just riding a series of bumps and it's not like dangerously jerking but you feel the steering wheel want to pull one way or the other.
Big Carrot's Changes - It's a work in progress
Originally Posted by Fiftydriver View Post
Seems like just yesterday I spent $450 for a Roto Fab CAI!!! What the hell happened.
BigCarrot is offline   Reply With Quote
Old 03-28-2012, 09:47 AM   #7
SlingShot
SlingShot's Avatar
Drives: 2012 ZL1 - #670
It,s from the staggered wheel setup of the RS... Normal!!!
Old 03-28-2012, 10:43 AM   #8
matthook
matthook's Avatar
My tires should be fine its a 2012 and ive only put 4,000 KMs on it, mostly with winter tires. The summer tires that are on now only have aboue 800kms on them
Old 03-28-2012, 10:44 AM   #9
matthook
matthook's Avatar
Ah this could make sense, thanks sling
Old 03-28-2012, 12:29 PM   #10
Hannibal
Hannibal's Avatar
Drives: Camaro SS & ZL1
There is a thread about this on here somewhere but the short answer given by SlingShot is correct. The wide tread and staggered setup of the 20 inch wheels is the cause. My SS does this as well.
Hannibal is offline   Reply With Quote
Old 03-28-2012, 01:34 PM   #11
hightower
LS3 Black Widow
hightower's Avatar
Drives: 2012 45th 2SS LS3 and 1968 Mustang
Same experience here. It doesn't happen often, very rarely in fact, so I don't think it's an issue.
hightower is offline   Reply With Quote
Old 03-28-2012, 02:29 PM   #12
mikeinmobile
mikeinmobile's Avatar
Drives: 2011 2ss/rs black on black
I too had this happen and pulled over for a front suspension and lug nut
inspection. The stretch of road I was on was bumpy and uneven. Don't
drive with your wrist on bumpy back roads!
mikeinmobile is offline   Reply With Quote
Old 03-29-2012, 01:16 AM   #13
LimaCharlie
LimaCharlie's Avatar
Drives: 2011 Camaro SS/RS - 2004 Silverado
If tire pressure is good and tire wear is even, I think you are OK. My SS does this too when going over a speed bump at an angle. The grooves/crown in the road will affect the wheel too if they are deep enough.
2011 Summit White Camaro 1SS/RS
-6.2 LS3, TR6060, 3.45, G80
2004 Black Silverado 1500 2WD Regular Cab, Short Bed
-5.3 LM7, 4L60E, 3.42, G80
LimaCharlie is offline   Reply With Quote
Old 03-29-2012, 01:18 PM   #14
cab2g
love. my. car.
cab2g's Avatar
Drives: 2011 2SS/RS
The culprit is the summer tires.... I just switched to my summers this weekend and they grip the road to the point that they follow groves and cracks and feel like they are jumping around more. I'd have thought something was wrong with my steering, but the softer winter tires don't seem to do the same thing, and I have 245's up front and 275 in back just like the stock width. My friend's 04 mustang cobra also did this with his wide summer tires.
cab2g is offline   Reply With Quote
Custom Carbon Fiber/Leather Steering Wheel SS Mike Local Marketplace 3 02-22-2017 12:17 PM
Custom Carbon Fiber/Leather Steering Wheel SS Mike Interior Parts & Accessories 1 04-15-2011 05:31 AM
Ace Custom Steering - Name Your Wheel! SparksAI Interior Parts & Accessories 30 04-13-2011 04:44 PM
Another DSV First! Custom Premium DStyle Steering Wheel For Camaro (Pictures Inside) dsvcustoms Interior Parts & Accessories 38 08-20-2010 12:27 AM
Steering wheel leather cracking!! meliss7567 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 5 09-17-2009 03:13 PM
