Old 03-28-2012, 09:00 AM   #1
SLEEPER SS
Banned
Drives: 2010 2SS/RS
What kind of gains with a cam?
Im looking to get a cam. what type of rwhp gains can i expect? i have an auto also. still deciding to do a cam or not
SLEEPER SS is offline   Reply With Quote
Old 03-28-2012, 09:25 AM   #2
geaux_tigerss
geaux_tigerss's Avatar
Drives: 2014 GMC Sierra Denali
That's a very wide open question. My advise is to call a reputable shop to discuss. There a a lot of factors to consider. Usually with cams more HP = harder to drive in normal driving situations. More peak HP usually leads to less low end torque. A big cam will need a big stall converter. You also have to decide if you want to go with a VVT cam or do an LS3 conversion.
2011 2SS/RS M6 CGM Rotofab CAI, Kooks 1 7/8, Corsa (LS3)
geaux_tigerss is offline   Reply With Quote
Old 03-28-2012, 09:41 AM   #3
Bad70supreme
Bad70supreme's Avatar
Drives: 2010 aqua blue SS/RS M6
Even a smaller cam will have great gaines, between a cam and a tune you will have a hole neww beast. You can run something like a 220 230 at 05 with your stock conerter. I love this lunti cam I just installed, keep it small and on a tighter lsa if you want to keep the lowend and stock converter.
10.91 at 122 H/C stock block N/A
Bad70supreme is offline   Reply With Quote
Old 03-28-2012, 09:52 AM   #4
SLEEPER SS
Banned
Drives: 2010 2SS/RS
yeah im going to do the ls3 conversion for sure
Old 03-28-2012, 02:51 PM   #5
SLEEPER SS
Banned
Drives: 2010 2SS/RS
bump
Old 03-28-2012, 03:04 PM   #6
mikeSS
mikeSS's Avatar
Drives: 2015 c7
do not go with a mild cam like what bad70superme did. for his setup and goals it worked. but when you are doing a conversion plus cam install, new lifters, tune, probably having a shop do install. its going to cost a lot of money already. you want to get gains and do it right first time. get a new converter and a decent size cam. so doing all this work will be worth it. i am not sure about l99 gains, but people on LS3 are making 470WHP all day long. going from 410-420WHP headers intake to 470WHP cam. and some even higher
Old 03-28-2012, 03:12 PM   #7
Bildo
Bildo's Avatar
Drives: 2012 2SS/RS LS3
I would look at the dyno threads sticky and see the kind of power people are getting with what mods
Bildo is offline   Reply With Quote
Old 03-28-2012, 03:15 PM   #8
InfernoSS454
InfernoSS454's Avatar
Drives: 2010 camaro ss
It all depends on how big the cam. But generally in an auto you'd be anywhere from 420-460rwhp depending on the cam.
InfernoSS454 is offline   Reply With Quote
Old 03-28-2012, 03:51 PM   #9
brantley847
v It bites.
brantley847's Avatar
Drives: 2011 IBM 2SS/RS
The headers were the best decision I ever made as far as mods go, but Cam is a close second. People are scared to death of this thing man lol... people that know cars are reluctant to test it because they don't know what else you have done and people who aren't gear heads aren't exactly sure what is going on inside, but it makes them feel warm and fuzzy. The sound is just incredible. You have the luxury of having numerous clubs down there, find someone who has one and I promise you one will let you ride shotty with him to feel the ride. Drive ability ONCE you start moving is relatively the same..it is the idle that scares people away.
If you are going to do a full conversion, go somewhat aggressive... don't do that stage 1 or lower stage 2 B.S, you will EASILY drop 3-4k, doing this mod.. go bigger if you are going to have the awesome selection of cams that comes with the conversion.
I believe Mike Norris uses comp cams, and comp labels mine as a Stage 3. I don't quite believe that... I'd say its an aggressive stage II... maybe between 2-3... the cam I run, makes 470-475 on the M6
You will get between 420-440 with the mods you and I have... 400 with a stage 1, 415-430 with S-II, 430-450 with S-III....Even with a stage I, yes 30 hp is a decent gain from LTs, exhaust, intake... but that doesn't justify a 4k price tag to me.
You won't get over 450 without porting heads, unless you want to go with a VERY, VERY! big and aggressive Cam. If you go that high, you will suffer drive ability drastically. 440 was a nice spot for me with the A6 (again, it makes 470 on the M6) and a nice set of ported heads will push me over 450 and that is where I will probably stop with the power adders until I go forced induction.
The more aggressive you go, the more you may want to consider a torque converter and a very reliable tuner. Mike was able to take a rather aggressive cam and keep the drive ability. At red lights, it shakes and rattles like a mother..but that is one of the coolest things I have ever seen because I have never owned a cammed car. Sometimes at idle it feels like riding a damn bronco.. the first two days I was intimidated as hell, but after 2 days it became second nature again.
Here are some supporting mods I did to ensure some reliability as well: Transmission cooler to go along with the FTI converter, Rx Catch can, and Trunnion kit upgrade for your LS7 lifters due to some bearing failures. Be safe, do the trunnion upgrade and transmission cooler regardless... I believe Mike is now selling it on all his cam packages and that kit is only 130 bucks. The transcooler is around 100. The converter is NOT necessary, but damn does it throw this car into the power band and it is soooo smooth/sweet.
If you go back to Torq then will guide you in the right direction, just request the addition of the cooler and trunnion kit.
My labor, parts, tune..everything.. came out to 4700.
2011 2SS/RS
Performance: 439 RWHP A6: 226/236 Comp Cam, Kooks 1-7/8, CAInc, Borla S type, FTI Converter, Vmax TB, Rx Catch Can, Trans cooler, SLP 160 termo, Melling high volume, Eibach Springs/Sways 1" drop, Whiteline complete bushing kit.
Appearance:Smoked side markers and black bowties. Blk / Blue Carbon Fiber interior trim.
Next in order: F14s, 3.70 gears, DSS Axles, End links/Toe rods/trailing arms, Ported heads, S/C.
1100 7/02 Ordered
3800 8/09 Order produced
4200 8/13 Shipped
6000 8/24 HOME!
brantley847 is offline   Reply With Quote
Old 03-28-2012, 04:22 PM   #10
Jason 98 TA
Drives: Camaro
Checkout the VVT-3 on our site. It's made 100 flywheel hp gains!! It will require a larger than stock stall converter though, most camshafts do.
Jason 98 TA is offline   Reply With Quote
Old 03-28-2012, 04:31 PM   #11
SLEEPER SS
Banned
Drives: 2010 2SS/RS
thanks alot for your input. i have the money to cam my car right now. just deciding between a cam or supercharger. right now with my mods im right at 360rwhp. if i can gain another 60 to 70 rwhp with a cam , ill be happy. got to make a decesion
Old 03-28-2012, 09:29 PM   #12
brantley847
v It bites.
Yea, S/C will be down the road for me.. but I don't regret doing cam first AT ALL!
I went from 365-370rwhp with the same basic bolt ons you have up to 439... that was with the torque converter. I have heard the stall will eat up 3-5 hp on the dyno, but boy will you make up for it on a straight away in the power band.
You may want to consider gears before the S/C as well... ride in a A6 with a good set of 3.70 and it will launch you into the back of your seat. I think the torque multiplier is 13%?
2011 2SS/RS
1100 7/02 Ordered
4200 8/13 Shipped
6000 8/24 HOME!
Old 03-29-2012, 08:18 AM   #13
SLEEPER SS
Banned
Drives: 2010 2SS/RS
alot of options to consider. modding these cars is so much fun. once you start you cant stop. ive only had my current mods for 1 month and i already want to go faster lol
Old 03-29-2012, 10:06 AM   #14
jmart53
jmart53's Avatar
Drives: 2012 Cruze LTZ RS
Is it just me or does 360rwhp seem low for the mods you have?! I know it's an automatic but still that seems really low with the mods...
Conservative tune?
jmart53 is offline   Reply With Quote
Cam basics CamaroSpike23 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 76 11-25-2015 12:42 PM
Modifying for " Dummies" Dr Jkel Tuning / Diagnostics -- engine and transmission 209 06-18-2012 12:24 AM
Vengeance Racing Cam Kit Plus And Cam kit Plus Conversion Kevin@V Engine Internals 0 12-08-2011 11:05 PM
Vector Motorsports Stage 2.5 cam kit installed! pics and video topgun1 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 38 12-18-2010 11:28 PM
Most HP/TQ gains from cam? SSinthedesert Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 10 05-13-2010 11:30 PM
