Gen5DIY
View Poll Results: if you definitely want a cylinder please chose V6 or SS. need to figure out how many
I own a V6 20 20.83%
I own a V6 but will wait for a core exchange 7 7.29%
I own a SS 50 52.08%
I own a SS but will wait for a core exchange 21 21.88%
Multiple Choice Poll. Voters: 96. You may not vote on this poll
Old 04-10-2012, 01:00 PM   #141
IDEALG
Chevy's "Rumble" Best!
IDEALG's Avatar
Drives: 2015 ZL1 6 speed
Send a message via AIM to IDEALG
Originally Posted by blumaro View Post
I dug around and found the link you were referring to:
http://forums.corvetteforum.com/c6-t...ur-clutch.html
Good stuff. IDEALG is correct about this problem afflicting brand new cars. My car just broke 1500 miles. The first time I screamed it up to 6000 rpm it had 800 miles on it...grind. In horror, I pulled into the liquor store to grab some brews and let it cool down a bit. Pulled back onto the road and blasted up to 6000 and grind again. My head was about to explode (glad I grabbed some beers). I tried it one more time and made for-damn-sure that the clutch pedal was slammed onto the floor then I slowed down the 1 -2 shift just a bit and it went right in, no problem. My 4th gen never had this problem. It could take what ever I could dish out including bouncing it off the rev limiter, no-lift-shift style. The new car is very disappointing indeed.
That Vette article has me wondering if the Camaro has forward bell housing panels? Not so much for debris removal, but for added cooling. I haven't had my car long enough to have spent much time under it, so I just don't know. My other thought is, and perhaps IDEALG can chime in, how close is the clutch master cylinder to the exhaust manifold/system? There tends to be a huge amount of heat generated by the exhaust when driving the car hard. Perhaps a well placed heat shield could protect the master cylinder.
A heat shield wouldn't hurt but i dont feel the clutch master cylinder is getting hot especially because its mounted inside the car and not outside. it mounts to your clutch pedal bracket inside the car. However it is possible that the hydraulic lines are getting too hot But i still disbelieve this since i know camaro owners who have the all new hydraulic line from Tick performance which are suppose to help against heat and swelling of the line and they still have problems. This grind is just a nitemare
IDEALG is offline   Reply With Quote
Old 04-10-2012, 01:02 PM   #142
IDEALG
IDEALG's Avatar
Originally Posted by CyberPredator View Post
I too was thinking that. My tranny since new did the 2nd gear grind but what I did notice is that it's smoother around 150° but when it gets to 180° it grinds every high rpm1-2 shifts. Which mine gets hot quick now because of Turbos. I was thinking Turbo bags and exhaust wrap.
Since you have turbos i would assume you are creating more heat then those of us without turbos so in this case i would recommend trying to devert the heat away from hydraulics.
Old 04-10-2012, 04:10 PM   #143
Mach
Mach's Avatar
Drives: White M6 1LT RS
Hey IDEAL.. Did you find a v6 grinder yet?
Pfadt Sway Bars - FE3 Suspension - Barton Shifter - IdealG's Clutch Master Cylinder - Trifecta - Vmax TB - Vararam Intake - MACE 25mm Insulator - Plenum Insulator - Ported/Gasket Matched Intake Manifold - Rx Catchcan - AAC DRL's - 4 Pack Aux Gauges - Steering Controls - AAC Afterburners - DIY Led Sidemarkers - ZL1 Front End
Next mod: Done!
Mach is offline   Reply With Quote
Old 04-10-2012, 04:14 PM   #144
IDEALG
IDEALG's Avatar
Yes i have a V6 grinder lined up for Saturday.
Old 04-10-2012, 04:18 PM   #145
Mach
Mach's Avatar
Looking forward to great results. Thanks!
Next mod: Done!
Old 04-10-2012, 04:28 PM   #146
IDEALG
IDEALG's Avatar
Me too
Old 04-10-2012, 09:51 PM   #147
dekan513
chevy pride
dekan513's Avatar
Drives: 2ss/rs
just reading thru this my car does good on shifting no problems at all stock clutches and all but my pedal does stick sometimes does anyone make like a return spring to put on these to help?
check out ky speeds fb page https://www.facebook.com/kyspeed
dekan513 is offline   Reply With Quote
Old 04-10-2012, 10:34 PM   #148
The 2010 Sin
weaponsinc.com
The 2010 Sin's Avatar
Drives: 2014 Lifted 1500, 2013 2SS CRT
lingenfelter has a return spring. and it helps pull the pedal off the floor. Tick Performance also makes a braided and insulated line that goes from the slave to the master so it doesnt heat up and become pliable.. because if it does what happens is you press the clutch pedal in and the rubber hose expands and doesnt allow enough pressure to activate the slave cyl. Crapppppyyy GM designs here folks.
The 2010 Sin is offline   Reply With Quote
Old 04-11-2012, 12:36 PM   #149
IDEALG
IDEALG's Avatar
I will have the V6 and SS cylinders ready for testing today.
also check out what came in today, 20 SS cylinders now i have to test every one of them ugh.
Old 04-11-2012, 12:51 PM   #150
bcarkle
bcarkle's Avatar
Drives: '11 1SS M6 "SOLD" & '70 Chevelle
Looks like fun. "WHEN" this works I want to be the first one in Washington State Thanks for all your hard work.
2011 1SS "SOLD", 1970 Chevelle Blown Rat
bcarkle is offline   Reply With Quote
Old 04-11-2012, 03:50 PM   #151
VEESIKS
formerly 2011Camaro
Drives: 2011 Camaro LS IBM M6
Hey IDEALG do you have a way of checking to see if the SS clutch line is interchangable with the V6 line in this process? I am wanting to put the stainless line on mine but not sure if it will work. Thanks!
Born on the Island and raised in the sand.
Semper Fidelis
VEESIKS is offline   Reply With Quote
Old 04-11-2012, 03:53 PM   #152
IDEALG
IDEALG's Avatar
where it connects to the master cylinder it will be the same. i used the same line to test the SS and the V6 cylinders using the factory clips and all. I dont know if its the same fitting on the trans though. i haven't had a V6 here in the shop yet.
Old 04-11-2012, 04:13 PM   #153
CyberPredator
50 Shades of Prey
Drives: TT/SS
Gettin excited
Futral Motorsports built and tuned
CyberPredator is offline   Reply With Quote
Old 04-11-2012, 04:45 PM   #154
piticu667
Drives: 2010 Camaro
Guys looks like this weekend we will know if this will fix the v6 issue. Driving to Jersey to test the v6 IDEALG made.
piticu667 is offline   Reply With Quote
Rear End Gears 101 danhr V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 82 08-04-2017 12:38 PM
2nd gear grind issue and updated GM parts (pics) Oxtar41 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 67 03-04-2015 11:11 PM
GTO Clutch Reservoir Install terry_b Camaro DIY & HOW-TO instructions & discussions 68 06-13-2014 08:46 PM
V6 AY6 M6 2nd Gear Problem - Report Your Issue Here CAMAR0 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 1606 10-25-2012 04:18 PM
Street Slayer brought to you by Hendrix Engineering Hendrix-Engineering Transmission / Driveline 2 12-08-2011 03:55 PM
