| V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) Driveshafts | Differentials | Gears | Rearends | Clutch | Shifters |
| View Poll Results: if you definitely want a cylinder please chose V6 or SS. need to figure out how many | |||
| I own a V6 |
20 | 20.83% |
| I own a V6 but will wait for a core exchange |
7 | 7.29% |
| I own a SS |
50 | 52.08% |
| I own a SS but will wait for a core exchange |
21 | 21.88% |
| Multiple Choice Poll. Voters: 96. You may not vote on this poll | |||
Thread Tools |
#551 |
"Chevy" rumbles best
#552 | |
#553 |
any updates on installed master cylinders?
#554 |
![]() Drives: 2010 CamaroSS Join Date: Aug 2009
Just installed mine. Clutch pedal not sinking anymore and engages higher like it's supposed to. Will test the 1-2 shift on the way home. Installing a remote resevoir tomorrow...will post pics.
Frank
10 Camaro Magnacharged- 595rwhp/585rwtq, full exhaust, Pedders Justice/ZL1 sway, Stoptech brakes and 21" 3 Pc. Forgeline wheels 99 Corvette- 497rwhp/490rwtq-402 N/A, 6pis/4pis brakes...fun track car/daily driver 2010 Camaro 2LT/RS...257rwhp/234rwtq SLP CAI and IAT relocated, Eibach springs and Flowmasters |
#555 | |
cool
#556 |
![]() Drives: 2010 Camaro Join Date: Jun 2010
#557 |
![]() Drives: 2012 Camaro 2SS/RS Join Date: Dec 2011
My car is going to the dealer in 2 weeks to have the clutch pedal assembly changed out and a new clutch installed. If my pedal still sticks and/or grinds 2nd I'll definitely be giving you a call for a master cylinder.
Sent from my Nexus S 4G using Tapatalk 2
2012 Camaro 2SS/RS, Hurst Short Throw, IdealG M/C, Pypes Pipe Bomb, LSR Cold Air Intake, LSR Toe Links/Lower Control Arms - Coming Soon... headers, high flows, Slowhawk tune
1974 Chevy K10 Built 355, FAST EZ EFI, 4speed 2000 Chevy Tahoe LT 5.3L |
#558 |
![]() Drives: Victory Red 2SS Black interior Join Date: Apr 2010
Please PM for Price... appreciate it!
#559 |
Got up this AM and the clutch pedal did not drop at all...has great pressure feel to it. I am installing a clutch resevoir today and a clutch pedal stop. Will post pics when done. I would highly recommend this master cylinder to anyone with a "stick" car.
Frank
#560 | |
Good to hear, keep us posted on how it is after you drive it a bit. Thanks
#561 |
I installed another reservoir today here another pic os my location so you don't need a longer hose
#562 |
Winners find a way
Drives: 2010 2LT/RS M6 Join Date: Jun 2010
Are you selling reservoirs? pm me if so....
Injen LT | Magnaflows | BBK LT & HFC | Mace 25mm & P Spacer |Richmond 3.73 | Trifecta Tune
RX Catch Can & Breather | Pedders Inserts | IDEALG Clutch MC & GTO Reservoir | JDP Colorshift Halos | Drake Bowtie Delete | |
#563 |
no i haven't gotten anymore in yet. He brought his own
#564 |
Here's a picture of the pedal stop I'm using. I found it on the Corvette forums a couple of years ago. Works great. Sorry about the blurry picture.
Frank
#565 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 aqua blue SS/RS M6 Join Date: Feb 2010
Very interested in the clutch stop! Will this make the 2nd gear grind worse, I wanted to build my own to speed up my shifts... I need some help there
I was thinking it might even help with the grind issue.
#566 |
Since installing the new master cylinder...no issues with 1-2 shifts. I tried to find the supplier for the pedal stop and had no luck, but shouldn't be to hard to mock something up.
Frank
#567 |
Has is help with shifting speed? Funny thing is because of the 2nd gear issue... thats my slowest shift! I wait untill I feel the car go into gear before I let the clutch go! My 2-3 shift is fast because I never have a issue, so bang that shift pretty fast.
#568 | |
Think a little air popped up in the system last night...pedal felt good initially this AM, but about the 3rd time I pressed the clutch pedal it sunk...had to drop into neutral and pump the pedal several times to get it to come back. Don't think it's an issue at all with the master cylinder...just some air. Will know as soon as I get a chance to put the extra resevoir in and re-bleed. Hopefully today.
Frank
#569 | |
I'm just curious, what clutch are you running?
#570 |
Still have the stock clutch. For now...car only has 16K miles....s/c been on for about 8K of that.
Frank
#571 |
wow ok, cool keep us posted on that master cylinder.
#572 |
Will do...hopefully the EPDM rubber caps come in today so i can put the extra resevoir in.
Whats your opinion on using the pedal stop?
Frank
#573 | |
It's not needed unless you race the car frequently. There is a pedal stop built into the the pedal assy now But i don't think the pedal hits it. The master cylinder bottoms out first and stops the pedal, so your pedal stop adjusted properly will save the master cylinder over time especially for poeple who race and are hard on the pedal.
#574 | |
Frank
#575 | |
The way I've modified the cylinder you want it to travel all the way to get the most out of it. using the pedal stop so the master doesn't bottom out when your hard on the pedal is a good thing. I don't know why GM made it so the master cylinder stops the pedal. I beat the hell out of my car and I haven't broke it yet so I guess they are pretty strong
| Thread Tools | |
| Rear End Gears 101 | danhr | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 63 | 12-26-2012 11:02 AM |
| GTO Clutch Reservoir Install | terry_b | Camaro DIY & HOW-TO instructions & discussions | 56 | 12-13-2012 02:50 PM |
| V6 AY6 M6 2nd Gear Problem - Report Your Issue Here | CAMAR0 | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 1606 | 10-25-2012 03:18 PM |
| 2nd gear grind issue and updated GM parts (pics) | Oxtar41 | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 51 | 01-10-2012 08:43 PM |
| Street Slayer brought to you by Hendrix Engineering | Hendrix-Engineering | Transmission / Driveline | 2 | 12-08-2011 02:55 PM |
