JDP Motorsports
View Poll Results: if you definitely want a cylinder please chose V6 or SS. need to figure out how many
I own a V6 20 20.83%
I own a V6 but will wait for a core exchange 7 7.29%
I own a SS 50 52.08%
I own a SS but will wait for a core exchange 21 21.88%
Multiple Choice Poll. Voters: 96. You may not vote on this poll
Old 05-22-2012, 01:41 PM   #477
piticu667
Drives: 2010 Camaro
Originally Posted by Mach View Post
I don't think it should a problem now IdealG. I was freaking out there for a bit.
Thanks. I need to find that fitting/bleeder at the dealer.
Guys be careful when you crack your bleeder open. Spray some nutbuster on there.
Sorry dude I wish you the best of luck.. personally I can't wait to see your results. I am dying to know if it will fix your car too.
piticu667 is offline   Reply With Quote
Old 05-22-2012, 01:51 PM   #478
IDEALG
Chevy's "Rumble" Best!
IDEALG's Avatar
Drives: 2015 ZL1 6 speed
Send a message via AIM to IDEALG
Originally Posted by Whomas View Post
I have a really lazy clutch. It is hard for me to even get the tires to spin. Unless I let the clutch out and wait a few seconds the hit the gas. It is so bad that if I try a hard agressive stat it just revs up and rolls out like a 4 banger. This sounds like what a need to make the clutch do what I want. Not when it feels like it.
sounds like you got a bad clutch or pressure plate.
IDEALG is offline   Reply With Quote
Old 05-22-2012, 06:50 PM   #479
Whomas
Tom
Drives: 2010 SS2
Yea....I thought the same. Even took it to the dealer as I was also having the sticking clutch problem. They replaced the clutch and flywheel. It got a little better. But the clutch is still lazy. That it the only way I can describe it. It just dose not engage firm. But once engaged it dose not slip. I can put it in 4th up a steep hill at 20mph and it just fine. No slip. It kinda sounds like a flow issue on the master?
2010 2SS M6
Whomas is offline   Reply With Quote
Old 05-22-2012, 07:56 PM   #480
IDEALG
IDEALG's Avatar
still sounds like a bad pressure plate to me. did they change the pressure plate? where are you located?
Old 05-22-2012, 08:58 PM   #481
Whomas
Tom
Drives: 2010 SS2
Yes I believe they did change the pressure plate as well. I am in CT. I could try taking it back to the dealer again. But I just don't think they are going to get it right? Not sure.....
2010 2SS M6
Old 05-22-2012, 09:05 PM   #482
IDEALG
IDEALG's Avatar
Maybe you should hit up Jannetty Racing since your in the same state maybe they could pin point the problem for you. Better then driving to me in jersey. Something doesn't sound right though and without having the car in front of me it will be hard to determine.
Old 05-23-2012, 08:02 AM   #483
IDEALG
IDEALG's Avatar
Master Cylinders are ready to ship, get them while they're hott. V6 and SS
Old 05-23-2012, 11:05 AM   #484
Jason@
Drives: 2016 1LT RS Camaro; 72 Chevelle
Send a message via AIM to Jason@ Send a message via MSN to Jason@
Hmmm... I'll have to save up for one of these, as I think it will be my next mod.
Jason@ is offline   Reply With Quote
Old 05-23-2012, 11:06 AM   #485
IDEALG
IDEALG's Avatar
sounds good
Old 05-23-2012, 11:34 PM   #486
Mach
Mach's Avatar
Drives: White M6 1LT RS
The new part came in today... Turns out to buy the breather.. I had to get the entire hose assembly that goes from the reservoir to the transmission. 70 bucks.
I will have this up and running tomorrow!!
Pfadt Sway Bars - FE3 Suspension - Barton Shifter - IdealG's Clutch Master Cylinder - Trifecta - Vmax TB - Vararam Intake - MACE 25mm Insulator - Plenum Insulator - Ported/Gasket Matched Intake Manifold - Rx Catchcan - AAC DRL's - 4 Pack Aux Gauges - Steering Controls - AAC Afterburners - DIY Led Sidemarkers - ZL1 Front End
Next mod: Done!
Mach is offline   Reply With Quote
Old 05-23-2012, 11:43 PM   #487
Blue70SS
Blue70SS's Avatar
Drives: 2010 LS3Camaro2SSRS IOM in/out
Originally Posted by JTRJSS View Post
Had Jerry from Ideal install the clutch cylinder yesterday. So far the results are good. I feel the shifts are much easier. I have done some high RPM shifts with no issue. The clutch does engage higher but not a problem.
Which clutch/RWHP?
Got a local friend with a fairly new ZR1 clutch (2k miles) and shifting problem, looking for some confirmation that high RPM WOT shifts got better with the ZR1 CX Max without having to granny shift (6k to redline). Track test and/or sticky tires best.
LPE Brotherhood
Old 05-24-2012, 07:53 AM   #488
IDEALG
IDEALG's Avatar
well at least it was seperate from the slave.
Old 05-24-2012, 07:58 AM   #489
IDEALG
IDEALG's Avatar
Originally Posted by Blue70SS View Post
Which clutch/RWHP?
I got the Katech LS9 clutch, 465 rwhp, 6000 + RPM shifting no grinding anymore. Haven't had it to the track yet hoping for a clear wednesday next week to run it.
Old 05-24-2012, 09:21 AM   #490
Mach
Mach's Avatar
Yes!!!
Next mod: Done!
Rear End Gears 101 danhr V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 82 08-04-2017 12:38 PM
2nd gear grind issue and updated GM parts (pics) Oxtar41 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 67 03-04-2015 11:11 PM
GTO Clutch Reservoir Install terry_b Camaro DIY & HOW-TO instructions & discussions 68 06-13-2014 08:46 PM
V6 AY6 M6 2nd Gear Problem - Report Your Issue Here CAMAR0 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 1606 10-25-2012 04:18 PM
Street Slayer brought to you by Hendrix Engineering Hendrix-Engineering Transmission / Driveline 2 12-08-2011 03:55 PM
