BeckyD @ James Martin Chevy
View Poll Results: if you definitely want a cylinder please chose V6 or SS. need to figure out how many
I own a V6 20 20.83%
I own a V6 but will wait for a core exchange 7 7.29%
I own a SS 50 52.08%
I own a SS but will wait for a core exchange 21 21.88%
Multiple Choice Poll. Voters: 96. You may not vote on this poll
Old 05-24-2012, 12:56 PM   #491
piticu667
Drives: 2010 Camaro
Originally Posted by Mach View Post
Yes!!!
Best of luck ... I can't wait it looks like it is going to be just you and me with the v6 fix...
piticu667 is offline   Reply With Quote
Old 05-24-2012, 06:28 PM   #492
Mach
Mach's Avatar
Drives: White M6 1LT RS
Well IT WORKS so far!! I've been cured by Dr. Grind. The shifting feels smoother. I did one 6.5k rpm shift from 1st to 2nd and no grind.
Pfadt Sway Bars - FE3 Suspension - Barton Shifter - IdealG's Clutch Master Cylinder - Trifecta - Vmax TB - Vararam Intake - MACE 25mm Insulator - Plenum Insulator - Ported/Gasket Matched Intake Manifold - Rx Catchcan - AAC DRL's - 4 Pack Aux Gauges - Steering Controls - AAC Afterburners - DIY Led Sidemarkers - ZL1 Front End
Next mod: Done!
Mach is offline   Reply With Quote
Old 05-24-2012, 06:35 PM   #493
IDEALG
Chevy's "Rumble" Best!
IDEALG's Avatar
Drives: 2015 ZL1 6 speed
Send a message via AIM to IDEALG
Glad you got it back together, keep us posted.
IDEALG is offline   Reply With Quote
Old 05-24-2012, 11:47 PM   #494
piticu667
Drives: 2010 Camaro
Cool dude happy to hear... Now there is two of us with the v6 fix..
Old 05-24-2012, 11:53 PM   #495
ponbigi
ponbigi's Avatar
Drives: 2011 CAMARO LS
Tranny getting fixed.. I may order this soon
ponbigi is offline   Reply With Quote
Old 05-25-2012, 07:29 AM   #496
IDEALG
IDEALG's Avatar
good luck, let us know how everything goes
Old 05-25-2012, 02:38 PM   #497
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
Good news and congratulations!! Now please keep us posted as you get more opportunities to test it.
I'm hoping for success, but each time I've changed my tranny gear oil, I thought things were better- only to be disappointed.
Hopefully this is the fix .
Old 05-25-2012, 09:35 PM   #498
piticu667
Drives: 2010 Camaro
Works fine for me I think I am close to 7000 km on the new master cylinder and yes I have an lt
Old 05-27-2012, 12:33 AM   #499
Ventmaster
Ventmaster's Avatar
So the 1-2 shift at redline doesn't produce a grind anymore as in never?
Old 05-27-2012, 01:36 AM   #500
piticu667
Drives: 2010 Camaro
I have not had a grind since I changed the master to the one made by IDEALG... and I reved the crap out the car for about a week once I got the new master I posted the videos so you guys can see..
I have 7000 km or about 4400mi since IDEALG installed mine... No issues since..
Old 05-28-2012, 11:05 AM   #501
Ventmaster
Ventmaster's Avatar
Thank-you for posting the vid- very impressive. Wish I was a little closer to Jersey, I'd go for the install as well.
I can't find the You-tube videos I was referred to for some "how-to".
Anyone have any DIY posts on this or can help me find those U-tubes?
Thanks again piticu667 .
Old 05-28-2012, 11:13 AM   #502
IDEALG
IDEALG's Avatar
Go to the first page of this thread and you will see the links posted at the top. Click on them they should work
Old 05-28-2012, 01:32 PM   #503
Ventmaster
Ventmaster's Avatar
Got it- Thanks!
Old 05-29-2012, 10:59 PM   #504
montej23
montej23's Avatar
Drives: 2011 VR Camaro
Is this master clutch hard to install and what all is involved?
montej23 is offline   Reply With Quote
Rear End Gears 101 danhr V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 82 08-04-2017 12:38 PM
2nd gear grind issue and updated GM parts (pics) Oxtar41 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 67 03-04-2015 11:11 PM
GTO Clutch Reservoir Install terry_b Camaro DIY & HOW-TO instructions & discussions 68 06-13-2014 08:46 PM
V6 AY6 M6 2nd Gear Problem - Report Your Issue Here CAMAR0 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 1606 10-25-2012 04:18 PM
Street Slayer brought to you by Hendrix Engineering Hendrix-Engineering Transmission / Driveline 2 12-08-2011 03:55 PM
