JUICEDMOTORSPORTS
View Poll Results: if you definitely want a cylinder please chose V6 or SS. need to figure out how many
I own a V6 20 20.83%
I own a V6 but will wait for a core exchange 7 7.29%
I own a SS 50 52.08%
I own a SS but will wait for a core exchange 21 21.88%
Multiple Choice Poll. Voters: 96. You may not vote on this poll
Old 05-30-2012, 06:45 AM   #505
IDEALG
Chevy's "Rumble" Best!
IDEALG's Avatar
Drives: 2015 ZL1 6 speed
Send a message via AIM to IDEALG
Originally Posted by montej23 View Post
Is this master clutch hard to install and what all is involved?
check out the vid links on the first page of this thread
IDEALG is offline   Reply With Quote
Old 05-31-2012, 12:00 PM   #506
RogerBzSS
RogerBzSS's Avatar
Drives: 11 IBM n White 2SS/RS M6
My Car goes in to the dealership next Monday the Syncro and rings are going in
a few week wait but they are in.. I hope they get this work done with out making things worse..
But we will see..
Then off to Jannetty Racing for the New improved IdealG Master Cylinder and some get gone parts..
Will update once the car is back, not that I expect any improvement with the syncro and rings but worth the warranty work I hope to not make it worse or add new issues.
-Roger
RogerBzSS is offline   Reply With Quote
Old 05-31-2012, 12:08 PM   #507
IDEALG
IDEALG's Avatar
But we will see..
-Roger
cool
Old 05-31-2012, 06:12 PM   #508
Mach
Mach's Avatar
Drives: White M6 1LT RS
Well.. IT WORKS! Finally got back into town to get this thing bled properly. The first time around I didn't get all the bubbles out. The shifting still sucked and I was still grinding.
I hooked up a 1/4 inch clear hose I got from HD. Fed it into a clear bottle. Turns out I did have some air left over. I bled several more times until I got 0 bubbles.
Now the short throw shifter goes like butter. Did some heavy accel with powershift and NO Grind. Lost traction between shifts. I forgot how much fun that was I could never do that with my car before bc of the nasty grind. Money well spent.
Pfadt Sway Bars - FE3 Suspension - Barton Shifter - IdealG's Clutch Master Cylinder - Trifecta - Vmax TB - Vararam Intake - MACE 25mm Insulator - Plenum Insulator - Ported/Gasket Matched Intake Manifold - Rx Catchcan - AAC DRL's - 4 Pack Aux Gauges - Steering Controls - AAC Afterburners - DIY Led Sidemarkers - ZL1 Front End
Next mod: Done!
Mach is offline   Reply With Quote
Old 05-31-2012, 06:58 PM   #509
IDEALG
IDEALG's Avatar
Good news! Glad to hear!
Old 06-01-2012, 04:47 PM   #510
ToddB
Drives: 2011 2SS Convertible Supercharged
Can this be done with car on jack stands?
ToddB is offline   Reply With Quote
Old 06-01-2012, 04:56 PM   #511
Retro69
Retro69's Avatar
Drives: 2018 Camaro ZL1
I did mine on jackstands. Not all that bad if you don't mind the tight quarters getting to the bleeder. Definitely would have been easier with a remote bleeder though. I actually thought changing the master was worse requiring more patience wrenching out the long bolts.
Sent from my DROID BIONIC using Tapatalk 2
Retro69 is offline   Reply With Quote
Old 06-01-2012, 05:16 PM   #512
IDEALG
IDEALG's Avatar
Bleeding it is the hardest part because its hard to get to the bleeder.
yes it can be done but bleeding will be a little more difficult laying on your back.
Old 06-01-2012, 08:37 PM   #513
ToddB
I have the complete 2011 GM service manual and they use a mityvac with 51-68 kpa of vacuum to pull the bubbles out. Is it ok to do it this way. I can get a mityvac for about $100. Thanks
Old 06-01-2012, 08:48 PM   #514
IDEALG
IDEALG's Avatar
Yes sir. You can do it that way. It will suck all the air up and out through the reservoir.
Old 06-01-2012, 09:21 PM   #515
ToddB
Cool .
Old 06-03-2012, 07:13 AM   #516
IDEALG
IDEALG's Avatar
Seperate reservoir mounting
I've installed a Seperate clutch reservoir in Redirish's car. I just want to show everyone where i mounted it so its clean looking and out of the way and you can use your factory epdm hose.
There no need for any brackets anywhere it mounts nicely on the inside of the fender.
Old 06-03-2012, 09:07 AM   #517
h2oplay
Winners find a way
h2oplay's Avatar
Drives: 2010 2LT/RS M6
I like the separate reservoir, where do I get it and how much? Also, how are you capping off the line to the brake reservoir when using it?
Thanks Jerry
Injen LT | Magnaflows | BBK LT & HFC | Mace 25mm & P Spacer |Richmond 3.73 | Trifecta Tune
RX Catch Can & Breather | Pedders Inserts | IDEALG Clutch MC & GTO Reservoir | JDP Colorshift Halos | Drake Bowtie Delete |
h2oplay is offline   Reply With Quote
Old 06-03-2012, 09:32 AM   #518
redirish
redirish's Avatar
Drives: 10' IOM 2SS/RS/M6
Jerry did a great job on my car! He installed the separate reservoir and changed the brake/clutch/rear/tranny fluids. The Trans/clutch feels more responsive and smoother.
redirish is offline   Reply With Quote
Rear End Gears 101 danhr V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 82 08-04-2017 11:38 AM
2nd gear grind issue and updated GM parts (pics) Oxtar41 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 67 03-04-2015 10:11 PM
GTO Clutch Reservoir Install terry_b Camaro DIY & HOW-TO instructions & discussions 68 06-13-2014 07:46 PM
V6 AY6 M6 2nd Gear Problem - Report Your Issue Here CAMAR0 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 1606 10-25-2012 03:18 PM
Street Slayer brought to you by Hendrix Engineering Hendrix-Engineering Transmission / Driveline 2 12-08-2011 02:55 PM
