Cold Air Inductions
View Poll Results: if you definitely want a cylinder please chose V6 or SS. need to figure out how many
I own a V6 20 20.83%
I own a V6 but will wait for a core exchange 7 7.29%
I own a SS 50 52.08%
I own a SS but will wait for a core exchange 21 21.88%
Multiple Choice Poll. Voters: 96. You may not vote on this poll
Old 06-03-2012, 10:33 AM   #519
IDEALG
Chevy's "Rumble" Best!
IDEALG's Avatar
Drives: 2015 ZL1 6 speed
Send a message via AIM to IDEALG
Originally Posted by h2oplay View Post
I like the separate reservoir, where do I get it and how much? Also, how are you capping off the line to the brake reservoir when using it?
Thanks Jerry
unfortunetly they are on national backorder. I have about three more coming to me but not sure when, maybe in a week or two.
The plug you can get from napa i believe just make sure its epdm rubber
There is a guy on here who has the plugs but i can't remember his memeber name.
IDEALG is offline   Reply With Quote
Old 06-03-2012, 07:28 PM   #520
flht99b
flht99b's Avatar
Drives: 2010 Camaro 2SS/RS RJT
I have the EPDM plug to cap off the brake reservoir. Just trying to figure out a cost effective way to mail them, I'm open to suggestions. Be careful if purchasing these caps from local auto supply firms, most only carry natural rubber which will not hold up to brake fluid. There is a big difference in cost between a rubber and EPDM cap.
Ed M.
RJT 2SS/RS, AAM 3.70's, MTI Sway Bars, Shifter & SS brake lines, ZLI calipers & rotors, BMR Trailing & Toe Arms, full rear cradle & diff bushings, Pedders XA's, Camber/Toe eccentrics, Radius arm inserts, ZL1 Brembo Brake pads, GTO clutch reservoir, LS9 cam, Comp Cam valve springs, Melling 10296 oil pump, CR 5 timing chain, LS2 damper, CAI Cold Air Induction, ARH LT headers w/HF cats, GMPP touring axle back, Elite Engineering Catch Can, Forgeline 20x9.5 & 20x11 DS3 wheels w/Vredestein 275/40/20 & 315/35/20 tires, '11 Convertible spoiler, Lloyd "SS" Floor Mats, GM Camaro Trunk Mat
flht99b is offline   Reply With Quote
Old 06-03-2012, 07:39 PM   #521
The Stig
knows 2 facts about ducks
The Stig's Avatar
Cheapest is USPS parcel post. Takes a little longer, but it's crazy cheap.
Click to view my build thread
Old 06-04-2012, 07:40 AM   #522
IDEALG
IDEALG's Avatar
ZL1 pedal assy
So i recently got my ZL1 clutch pedal assy. as you can see it has an extra spring to help return the pedal. also i want to note something strange, The pedal assy came with a master cylinder but its a V6 master cylinder. weird, maybe someone at the factory screwed up or maybe they use V6 master cylinders lol.
Old 06-04-2012, 10:50 AM   #523
piticu667
Drives: 2010 Camaro
Can I suggest you use IDEALG's modified v6 master cylinder instead of the factory one? Just Kidding... Thanks a lot the v6 master you made for me is working running like a champ...
piticu667 is offline   Reply With Quote
Old 06-04-2012, 11:07 AM   #524
gahammerle
gahammerle's Avatar
Drives: 2010 Camaro LS M6 Inferno Orange
Gordy
Injen CAI / Solo Mach-X LLT / Solo High-flow res-cats / Barton short shifter / RX Catch Can / RPI Gills / 35% tint / LED Footwell Lighting Front & Rear / Pedders Street 1 / Pedders steering rack bushing / SS struts / Pfadt drop springs / VMax Ported Throttle Body / Spohn Toe Rods / Spohn Trailing Arms / Trifecta Tune / MACE 25mm Intake Spacers
Find me on Facebook:
http://www.facebook.com/gahammerle
gahammerle is offline   Reply With Quote
Old 06-04-2012, 11:11 AM   #525
IDEALG
IDEALG's Avatar
yeah i'll have to call him lol
Old 06-05-2012, 07:16 PM   #526
IDEALG
IDEALG's Avatar
anyone else have any feedback yet on their master cylinder install ??
Old 06-05-2012, 08:54 PM   #527
Bad70supreme
Bad70supreme's Avatar
Drives: 2010 aqua blue SS/RS M6
I plan on doing this soon, just came back from the track! I hate this trans... I could not make one pass unless I shifted at 5,900 into 2nd without getting blocked out! Allot good a cam does when this thing needs a 6500 shift and I can't do it! Seems like this has worked for the people that have tried it, it makes sence too. My trans does not do it on the street, but a do a quick burn out on the track and try a 6000+ shift and it's like hitting a brick wall!
10.91 at 122 H/C stock block N/A
Bad70supreme is offline   Reply With Quote
Old 06-05-2012, 09:10 PM   #528
IDEALG
IDEALG's Avatar
I hear ya i've been there, pissed me off thats why i did something about it.
Old 06-06-2012, 03:11 PM   #529
R8cerX
R8cerX's Avatar
Drives: 2010 CamaroSS
Just my luck, the shop has been pretty empty up until last week when i got the master cylinder...don't even have a lift for my own car...hopefully early next week. I'll post results.
Frank
10 Camaro Magnacharged- 595rwhp/585rwtq, full exhaust, Pedders Justice/ZL1 sway, Stoptech brakes and 21" 3 Pc. Forgeline wheels
99 Corvette- 497rwhp/490rwtq-402 N/A, 6pis/4pis brakes...fun track car/daily driver
2010 Camaro 2LT/RS...257rwhp/234rwtq SLP CAI and IAT relocated, Eibach springs and Flowmasters
R8cerX is offline   Reply With Quote
Old 06-06-2012, 03:17 PM   #530
IDEALG
IDEALG's Avatar
Ok keep us posted
Old 06-06-2012, 03:27 PM   #531
strych9
Gone Euro!
strych9's Avatar
Drives: 6spd Manual Mercedes, Daytona 955i
Has it been verified that the extra slave cylinder travel is not over-extending the release fingers of the pressure plate? If they were to bottom out against the fulcrum, the pressure plate fingers could crack and fail prematurely. It sounds like a great product, but just wanted to know if this potential issue has been considered. Thanks.
Bye bye, Bumblebee!
Old 06-06-2012, 03:37 PM   #532
IDEALG
IDEALG's Avatar
We've taken this into consideration and tested over and over again and it does not over extend or push the fingers too far. I've got over 25 cylinders out there with no problems so far. I've said it before and i'll say it again, There are way too many different clutch set ups and pressure plates for me to test them all.
Each master cylinder is tested on a jig set up before being shipped.
Rear End Gears 101 danhr V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 82 08-04-2017 12:38 PM
2nd gear grind issue and updated GM parts (pics) Oxtar41 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 67 03-04-2015 11:11 PM
GTO Clutch Reservoir Install terry_b Camaro DIY & HOW-TO instructions & discussions 68 06-13-2014 08:46 PM
V6 AY6 M6 2nd Gear Problem - Report Your Issue Here CAMAR0 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 1606 10-25-2012 04:18 PM
Street Slayer brought to you by Hendrix Engineering Hendrix-Engineering Transmission / Driveline 2 12-08-2011 03:55 PM
