sjm autoprod
View Poll Results: if you definitely want a cylinder please chose V6 or SS. need to figure out how many
I own a V6 20 20.83%
I own a V6 but will wait for a core exchange 7 7.29%
I own a SS 50 52.08%
I own a SS but will wait for a core exchange 21 21.88%
Multiple Choice Poll. Voters: 96. You may not vote on this poll
Old 06-07-2012, 03:46 PM   #547
z28racer
z28racer's Avatar
Drives: 12 SIM 2SS/ RS Sinergy M6,GMC2500HD
Thank you for the fast reply. I will be ordering one in the next couple of weeks. Where can I order it from?
z28racer is offline   Reply With Quote
Old 06-07-2012, 03:50 PM   #548
IDEALG
Chevy's "Rumble" Best!
IDEALG's Avatar
Drives: 2015 ZL1 6 speed
Send a message via AIM to IDEALG
just use the links at the first page of this thread they tell you what to do.
Thanks
IDEALG is offline   Reply With Quote
Old 06-07-2012, 03:53 PM   #549
z28racer
z28racer's Avatar
Nope thank you.
Old 06-07-2012, 03:57 PM   #550
RogerBzSS
RogerBzSS's Avatar
Drives: 11 IBM n White 2SS/RS M6
Got my Car back from the dealer a few hours ago
and here is what they said
my dealership technicians said my syncro gear pretty much welded to the shaft it was on
they needed to hammer it off to get it replaced, I asked to see the synchro assembly and took it apart for a light inspection, there was blueing on some of the synchro assembly and rings.
new parts installed, with GM trans fluids, "removing the RP Syncromesh" and low and behold it does shift better surely less notchyness from 1 -2, it also floats in to 4th when the skip shift kicks it never ever did that before I was actually supprised, I did jump on it a bit but not a hard pull in to 2nd, but it was a lot better than it was.
June 25th to Jannetty Racing for my other parts, including a Jerry's Master Cylinder..
So I get to drive the car a bit more, I have had it back a few hours but not out on a long drive and time to play hard. so the jury is still out on the replacement parts in the trans for a hard pull 1 - 2 shift IMPO..
Roger
RogerBzSS is offline   Reply With Quote
Old 06-07-2012, 04:12 PM   #551
IDEALG
IDEALG's Avatar
Nope thank you.
here's the link
http://www.camaro5.com/forums/showth...79#post4881079
Old 06-07-2012, 04:13 PM   #552
IDEALG
IDEALG's Avatar
Roger
Good to hear! keep us updated please
Old 06-12-2012, 03:27 PM   #553
IDEALG
IDEALG's Avatar
any updates on installed master cylinders?
Old 06-12-2012, 04:14 PM   #554
R8cerX
R8cerX's Avatar
Drives: 2010 CamaroSS
Just installed mine. Clutch pedal not sinking anymore and engages higher like it's supposed to. Will test the 1-2 shift on the way home. Installing a remote resevoir tomorrow...will post pics.
Frank
10 Camaro Magnacharged- 595rwhp/585rwtq, full exhaust, Pedders Justice/ZL1 sway, Stoptech brakes and 21" 3 Pc. Forgeline wheels
99 Corvette- 497rwhp/490rwtq-402 N/A, 6pis/4pis brakes...fun track car/daily driver
2010 Camaro 2LT/RS...257rwhp/234rwtq SLP CAI and IAT relocated, Eibach springs and Flowmasters
R8cerX is offline   Reply With Quote
Old 06-12-2012, 04:49 PM   #555
IDEALG
IDEALG's Avatar
cool
Old 06-13-2012, 01:03 AM   #556
piticu667
Drives: 2010 Camaro
Mine still works like a charm.. Thanks again.
piticu667 is offline   Reply With Quote
Old 06-13-2012, 01:43 AM   #557
2012-2SS
2012-2SS's Avatar
Drives: 2012 Camaro 2SS/RS
My car is going to the dealer in 2 weeks to have the clutch pedal assembly changed out and a new clutch installed. If my pedal still sticks and/or grinds 2nd I'll definitely be giving you a call for a master cylinder.
Sent from my Nexus S 4G using Tapatalk 2
2012 Camaro 2SS/RS, Hurst Short Throw, IdealG M/C, Pypes Pipe Bomb, LSR Cold Air Intake, LSR Toe Links/Lower Control Arms Clear Image headers, high flows, Slowhawk tune
1974 Chevy K10 Built 355, FAST EZ EFI, 5speed
2000 Chevy Tahoe LT 5.3L, Slowhawk tune
2012-2SS is offline   Reply With Quote
Old 06-13-2012, 06:23 AM   #558
ramon
Lightnin
ramon's Avatar
Drives: Victory Red 2SS Black interior
Please PM for Price... appreciate it!
ramon is offline   Reply With Quote
Old 06-13-2012, 09:03 AM   #559
R8cerX
R8cerX's Avatar
Got up this AM and the clutch pedal did not drop at all...has great pressure feel to it. I am installing a clutch resevoir today and a clutch pedal stop. Will post pics when done. I would highly recommend this master cylinder to anyone with a "stick" car.
Frank
Old 06-13-2012, 12:52 PM   #560
IDEALG
IDEALG's Avatar
Good to hear, keep us posted on how it is after you drive it a bit. Thanks
Rear End Gears 101 danhr V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 82 08-04-2017 12:38 PM
2nd gear grind issue and updated GM parts (pics) Oxtar41 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 67 03-04-2015 11:11 PM
GTO Clutch Reservoir Install terry_b Camaro DIY & HOW-TO instructions & discussions 68 06-13-2014 08:46 PM
V6 AY6 M6 2nd Gear Problem - Report Your Issue Here CAMAR0 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 1606 10-25-2012 04:18 PM
Street Slayer brought to you by Hendrix Engineering Hendrix-Engineering Transmission / Driveline 2 12-08-2011 03:55 PM
