Emblempros
Old 03-28-2012, 12:08 PM   #1
ULTRAZLS1
ULTRAZLS1's Avatar
Drives: 14 Silverado LTZ Z71, 16 Camaro SS
Beware stock timing chain tensioner!
As some of you may have heard some people have reported problems or breakage with the stock ls3 timing chain tensioner.
It is a good thing that I ended up doing a heads and cam install this year. The shop who is doing my install called me today and said that the spring had popped out of the tensioner!!! They are currently trying to fish it out of the oil pan!
I had heard of this problem and supplied the correct parts for them to install (ls2 dampener).
I just cant believe how lucky I got with this. I wonder how long I was driving it around like this...and I run the thing to redline almost every time I drive it...wow
btw...forgot to mention...car has 9900 miles on it.
Black 2016 1SS A8 NPP
Drag Pack, CAI, Headers, Mamo Ported MSD Intake, Pray Ported TB, Shrader RSD, E85
Best ET- 10.85
Best Trap- 125.39
ULTRAZLS1 is offline   Reply With Quote
Old 03-28-2012, 12:49 PM   #2
ITGuy11
Burning up tires
ITGuy11's Avatar
Drives: 2010 Camaro 1SS/RS
Good thing you caught it in time before and serious damage occurred. This is why I also switched to the LS2 dampner setup when I did my cam install as well...
Blower, cam, supporting mods 644RWHP 615RWTQ
My Build Thread COTW 11/19/12
Detroit 5th Gen Camaro Club
ITGuy11 is offline   Reply With Quote
Old 03-29-2012, 10:50 AM   #3
MikeOD
Drives: 2010 M6 2SS
Mine was ok when I opened it up, but it just seemed like such a cheesy setup, it has an LS2 damper and C5-R chain now.
2010 Camaro SS M6. Heads/Cam/Intake/Headers/Exhaust/Suspension
MikeOD is offline   Reply With Quote
Old 03-29-2012, 11:21 AM   #4
ULTRAZLS1
ULTRAZLS1's Avatar
I went with the same.
Best ET- 10.85
Best Trap- 125.39
Old 03-29-2012, 01:23 PM   #5
urr2slo
urr2slo's Avatar
Drives: 2010 2ss ss/rs abm, 2016 2ss/rs hbm
Another problem thats starting to surface on a few LS3's has been a broken timing chain. It tends to happen more on the manual trans Corvettes but a couple Camaros as well. When mixed with with sticky tires if the axles, driveshaft or trans input shaft has not broken the timing chain has let go on a clutch drop.
I did an Iwis timing chain upgrade and chucked the LS3 tensioner for an LS9 dampner 2 years ago. Over 30k with alot hard miles on it now with no problems.
I work at Midway Chevrolet in Phoenix, we have a Performance center here and we currently upgrade all our timing chains with this when we do a Cam Package just to be safe.
URR2SLO - If you're not going fast enough, get out the way......
urr2slo is offline   Reply With Quote
Old 03-29-2012, 02:38 PM   #6
Fiftydriver
Fiftydriver's Avatar
Drives: 2010 Camaro 2SSRS RJT L99
Good information to have, will be doing a cam upgraded here later this summer and will not upgrade the chain and dampener as well.
Thanks guys.
Fiftydriver
2010 SSRS, RJTC, L99, Maggie 2300 SC, 3.4" pulley, Roto-Fab CAI, Dynatech Supermaxx LT headers, Dynatech High Flow cats, Corsa Cat back exhaust, Dual Elite Engineering catch can, MSD wires and Jannetty custom tune, JRE custom diff w/ posi mod, 3.91 LPE gears, Pfaht trailing arms, Pfaht trailing arm and Diff bushings, drop springs and sport sway bars front and back, Fesler dual guage pillar pod w/ AM Cobalt Boost and A/F guages.
More to come!!
Fiftydriver is offline   Reply With Quote
Old 03-29-2012, 03:42 PM   #7
ULTRAZLS1
ULTRAZLS1's Avatar
Thanks guys.
You mean will upgrade?
Best ET- 10.85
Best Trap- 125.39
Old 03-29-2012, 04:36 PM   #8
Fiftydriver
Thinking faster then I can type!!!! Yep, will upgrade!!
Fiftydriver
More to come!!
Old 03-29-2012, 04:37 PM   #9
Fiftydriver
Is a dual timing chain a good idea?
Fiftydriver
More to come!!
Old 03-29-2012, 05:17 PM   #10
ULTRAZLS1
ULTRAZLS1's Avatar
Yes except you cant use the melling 10296 high volume oil pump. Might be a problem with other pumps as well. Their is not enough clearance with the double chain in their.
It can be made to fit but I forget the details. Seemed like a headache...combined with the fact that the single katech c5r chain has never been broken even in racing aps was enough for me to forget about the double roller.
Best ET- 10.85
Best Trap- 125.39
Old 03-29-2012, 06:16 PM   #11
H4rm0n1'c
Drives: 10 camaro
I used to run my cam wiht the OEM timing chain 3 months ago up to date without any problems
my g6x3 come with single katech c5r chain but some of the part came later that's why I ran the OEM timing chain
H4rm0n1'c is offline   Reply With Quote
Old 03-29-2012, 06:39 PM   #12
buzzy56
buzzy56
buzzy56's Avatar
Drives: 2ss summit white L99
What about the L99 timing chain ?
What about the L99 timing chain ? I assume the chain is different ? But if so, is it suspect for durability also ?
OLD SCHOOL / NEW SCHOOL COOL
buzzy56 is offline   Reply With Quote
Old 03-29-2012, 07:01 PM   #13
ULTRAZLS1
ULTRAZLS1's Avatar
I am not sufficiently educated on the L99 to know that for sure....sorry.
Best ET- 10.85
Best Trap- 125.39
Old 03-29-2012, 10:00 PM   #14
CamaroFemme
CamaroFemme's Avatar
Drives: 2010 Black Camaro 2SS/RS
http://www.camaro5.com/forums/showth...9+timing+chain
^This thread mentions "the yellow plastic bit can get brittle" and that is the problem - do we have this same bit?
My boyfriend don't mind it.
CamaroFemme is offline   Reply With Quote
DIY: LS3 Camshaft Install (a lot of pictures, may take a moment to load) robertway Camaro DIY & HOW-TO instructions & discussions 290 02-10-2018 10:11 AM
First Ever DOUBLE DIN (monitor / screen) NO LONGER AVAILABLE**** Hess RS Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 992 06-13-2013 12:13 AM
New timing chain tensioner necessary? yotaman96 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 3 05-03-2011 05:40 AM
timing chain tensioner sspaul Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 25 12-30-2010 10:18 PM
