Caryle Racing
Old 03-28-2012, 12:26 PM   #1
skar
skar's Avatar
Drives: 2010 2SSRS headers/CAI/tune/corsa,
Installing a Hurst short throw this weekend
Installing a Hurst this week end any do's or dont's
And will I be happy?
Stainless works headers/cats Roto fab CAI /
Corsa install and tune Livernois
TSW Nuburgring 9 &10" x 20 on Invos (315 & 275 )
JL Audio XD400/4 amp
Pfadt trailing arms & tie rods sway bars.
pedders street 1 package. ,Hurst short throw shifter
With bronze bushings .
skar is offline   Reply With Quote
Old 03-28-2012, 01:19 PM   #2
PAUL SS
The Mark of Excellence
PAUL SS's Avatar
Drives: 2010 ABM 1SS RS LS3
Use a magnet to catch the clips on the change rod when you pop them off. Make sure you have the right driver for installing the screws that hold the shifter in place. Replacing the lower boot should be the most difficult part.
Old 03-28-2012, 06:07 PM   #3
90503
90503's Avatar
Drives: 2011 2SS/RS LS3
Review the Hurst install video....several times...
Try taking the rod clips off by hand if you can...so they don't go flying...
Remove the heat shield (two 10mm nuts) and slide it back out of the way...(for when those clips do go flying (lol)...or you drop something else..
Make sure the flange holes in the housing line up correctly...put them in a few turns by hand first, make sure they don't bind...
Might want to put on the noise reduction tape while you got it apart...some get rattles, some don't...rattle, even slight, bothers some, other it doesn't..
Good luck!...You will love it!
90503 is offline   Reply With Quote
Old 03-28-2012, 09:51 PM   #4
sschevybear11
sschevybear11's Avatar
Drives: 2011 Black 1SS
Teflon tape on shifter ball threads.
2011 Black 1SS M6 12.75@110.91 bone stock
Now: Coated Dynatech LT's/!Cats/Hurst Shifter/Roto-fab/SLP SS badges/JRE 415HP Tune, Scoop & Washer Relocation Bottle,Hurst Stunner 20X9 Wheels, Moroso Catch Can, ASP pulley, Magnaflow X-pipe, GTO remote clutch reservoir
1989 Silver 5.0 Mustang LX Coupe
1999 Pewter Tahoe LT
2011 Blue Camry SE
sschevybear11 is offline   Reply With Quote
Old 03-29-2012, 03:25 AM   #5
Bonemaro
Bonemaro's Avatar
Drives: 2010 RJT 1SS M6
Send a message via AIM to Bonemaro
Hey skar. Had mine put in yesterday @ Rodgers Chevrolet. Lovin it. Lemmie know how you like yours. Any rattle/vibration??
Bonemaro is offline   Reply With Quote
Old 03-29-2012, 06:27 AM   #6
skar
skar's Avatar
Dave The hurst comes with dynmate damping tape to help take vibration out .
I will use it on my install this weekend. Also you can put the stock handle back on it heavy and that may make it stop .
http://www.hurst-shifters.com/wp-con...16030BA-03.pdf
Old 03-29-2012, 10:12 AM   #7
PAUL SS
PAUL SS's Avatar
This is the video....
Old 03-29-2012, 10:51 PM   #8
TBone
Negative Camber Junkie
TBone's Avatar
Drives: 2010 1SS LS3/6MN ABM 1 of 23
Before bolting anything up make sure the change rod slides into shifter pivot housing (3:35-3:38 in the video). The teflon may need to be filed down to make this connection. If you have bolted it up before checking this, filing it while it is in or unbolting it and taking it back out can be a PIA. Don't over file this but some teflon may need to come off to make connection.
Double check the two upper bolts that connect the silver shaft to the lower shaft after a few days as they tend to loosen up.
T.
"Horsepower is something that looks great in a Magazine article, but suspension is what actually gets you around the track fast.." Jack Olsen
The drag strip is like sniffing glue, it's cheap, it's a decent buzz, it doesn't last long and they are all the same.
Road racing is like China White Heroin, the buzz is stronger, the high lasts for hours, it's extremely addictive and they are all different.
I can't wait for my next
Track fix.
DA HAWKS OWN DA CUP!!!!!
TBone is offline   Reply With Quote
Old 03-30-2012, 07:22 AM   #9
Bonemaro
Bonemaro's Avatar
But I don't have rattle or vibration The noise i hear, while minimal are the Pedders street bushings kit i had done the same day the Hurst was installed. The bushings, now that i mention them are the best "bang for your buck" suspension mod i think there is.
Old 03-30-2012, 08:03 AM   #10
newagemuscle
Philippians 4:13
newagemuscle's Avatar
Drives: SLP Supercharged LS3
I broght my laptop in the garage and used this video too. Install was not to bad. Just take your time.
newagemuscle is offline   Reply With Quote
Old 03-30-2012, 08:11 AM   #11
skar
skar's Avatar
Thanks all.
Old 04-01-2012, 08:25 AM   #12
skar
skar's Avatar
Install done and I like it.
A lot harder then the video shows .
No room to work . No vibration or rattles.
The boot was a pain in the ASS.
My thanks to Bee for doing all the work.
Old 04-01-2012, 09:23 PM   #13
Nessal
Drives: Exige, Miata, Ghia
The hurst video says to lower the cross member. I did as the video says and have NO IDEA why they told me to do it. I installed it without any problems without dropping it.
Nessal is offline   Reply With Quote
Old 04-02-2012, 05:29 AM   #14
skar
skar's Avatar
Yep. Now we did move or slide the heat shield back a inch to get that boot back on.
Installing Hurst Billet short throw tomorrow Bay Area SS V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 4 05-29-2011 10:15 PM
Which one? Herritage grill or Hurst short throw CamaroC-17 5th Gen Camaro SS LS LT General Discussions 21 02-17-2011 03:57 PM
Hurst Short Throw YancyJohns Transmission / Driveline 2 01-16-2011 02:37 PM
Phastek Performance - Hurst TRUE Short Throw Shifters!! Sean@Phastek Transmission / Driveline 3 02-15-2010 10:33 AM
Short Throw Hurst Shifter Not Available Matster 5th Gen Camaro SS LS LT General Discussions 51 11-09-2009 11:03 AM
