Old 05-04-2009, 05:00 PM   #1
MrGazinya
MrGazinya's Avatar
Drives: Aggressive
New Camaro SS Dyno Pull 384.4 RWH
Originally Posted by Redline Motorsports
Couldn't wait any longer............got 225 miles on the car (mostly to get the 87 octane fuel the dealer put in it out....).
Made two back to back pulls;
Coolant was 190, oil was 200
Here are the results!
http://www.5thgen.org/forum/showthread.php?t=12930
AFR was about 11.5 to 11.7 across the board............nice for the turbos!
Going to play with the tune in the next couple days!
Howard
Black 2SS RS LS3 Inferno Int. Powdercoated 20's {MODS} KOOKS LT: Borla S-Type: Roto-Fab CAI: Hurst ST.: PFADT Stage 2, Trailing arms, Tie Rods: ECS BigBlower Cam: Fast 102mm intake: Brian Tooley racing dual spring kit: TFS pushrod set: Katech C5R timing chain: Mellings high volume oil pump: ATI Balancer: Tuned by Doug Ring at ECS. 472RWHP/445RWTQ.Dynapack Dyno.
MrGazinya is offline   Reply With Quote
Old 05-04-2009, 05:09 PM   #2
Kyle2k
LVL 50 Troll Stomper
Kyle2k's Avatar
Drives: 2010 Camaro
auto or manual?
Kyle2k is offline   Reply With Quote
Old 05-04-2009, 05:15 PM   #3
LosXC451
LosXC451's Avatar
Drives: 2010 SS SIM w/ RS
this car is gonna be fun
LosXC451 is offline   Reply With Quote
Old 05-04-2009, 05:22 PM   #4
D1BADZ
hmmmmm
D1BADZ's Avatar
Drives: 2010 IOM in-n-out 2SS
yes yes, it is quite a joy
"Responsibility is a Heavy Responsibilty" (Cheech)
D1BADZ is offline   Reply With Quote
Old 05-04-2009, 05:22 PM   #5
MrGazinya
MrGazinya's Avatar
Drives: Aggressive
Old 05-04-2009, 05:23 PM   #6
fieldgoal00
Drives: 2010 Chevy Camaro 2SS/RS
it's an ls3 based on the vin spreadsheet
fieldgoal00 is offline   Reply With Quote
Old 05-04-2009, 05:28 PM   #7
Flynbyu
Flynbyu's Avatar
Drives: 2008 Corvette/2001 Tahoe
Wow.
Usually you'll loose 65-70 hp from the flywheel. You only lost 42 hp?
~Brian
Flynbyu is offline   Reply With Quote
Old 05-04-2009, 05:51 PM   #8
fdjizm
Drives: 2008 Mustang GT/CS
What kind of correction was used on the dyno?
seems like before correction numbers.. which would mean 450 plus at the crank unless it's a factory freak.
fdjizm is offline   Reply With Quote
Old 05-04-2009, 06:10 PM   #9
Flynbyu
Flynbyu's Avatar
Kind of what I was thinking.
~Brian
Old 05-04-2009, 06:25 PM   #10
Craig
Drives: '01 Z28
That's comparable to what the LS3 Corvettes are putting down, so I doubt it's a freak. Those are impressive numbers, let's cross our fingers that they will turn out to be the norm.
Craig is offline   Reply With Quote
Old 05-04-2009, 06:26 PM   #11
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
HHHHHEEEELLLLLLOOOOOO!!!!
Nice. That's about what 'Vettes are puttin' down, isn't it? It'd be nice to know the factor, but this sounds pretty good
05 Hummer H2 SUV on OEM Air Ride
Forged 11.4:1 408 LQ4 (K1 crank & rods; Mahle pistons)/CPP LS3 CNC heads/BTR Stage IV LS3 cam/home ported L92 intake manifold/ported 90mm TB/custom Volant CAI/Kooks 1 7/8" LTs and 3" H-pipe/AFE dual 3" CB/Corvette Servo/el cheapo lift/Cognito UCAs/Sphon poly adjustable TA/Sphon adjustable rear LCAs/e'fan conversion/DirtyMax radiator/Moroso catchcan/HPTuners/HID conversion/LED exterior lighting/LED interior accents/Autometer Cobalts/AEM WB/ Pioneer AVH-5600BHS/Pioneer GM-9601/2-Pioneer TS-W310D4s/Obcon Labyrinth dual-12 box/lots of other little stuff
Old 05-04-2009, 06:27 PM   #12
dankss
Contract Killer
dankss's Avatar
Drives: 2010 black 1ss/rs
the dyno this was done on is a dyno dynamics, a little higher reading than the mustang dyno that the 364whp was done on.
dankss is offline   Reply With Quote
Old 05-04-2009, 07:21 PM   #13
Flynbyu
Flynbyu's Avatar
The highest pull on an LS3 Corvette I've seen...392rwhp & 376 rwtrq, bone stock and I thought that was a little high. That's a great pull on the Camaro.....especially if the car is brand new with low miles.
~Brian
Old 05-04-2009, 07:29 PM   #14
Crowley
Okie doke
Crowley's Avatar
Drives: 2012 GT500
Very nice .. that is around where it should be (maybe a bit on the high side).... any info on the correction used etc?
thanks,
Crowley
Crowley is offline   Reply With Quote
V8 Camaro Performance Upgrades List Milk 1027 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 89 02-20-2015 09:43 PM
4 SEMA CAMAROS finally unveiled by GM! (hi-res images & details) FenwickHockey65 Camaro Photos | Spyshots | Video | Media Gallery 237 11-03-2008 11:39 PM
AW: New Camaro a one trick pony? Scotsman 5th Gen Camaro SS LS LT General Discussions 16 09-04-2008 10:07 PM
Camaro Chat 9:30-10:00 jdpickering 5th Gen Camaro SS LS LT General Discussions 25 07-22-2008 03:11 PM
