Old 03-29-2012, 01:05 AM   #1
OVRKLL
Drives: Soon 2 B a ZL1
Question ZL1 is Happy at what RPM range
Ok, I know people haven't driven their ZL1 YET, but for those that are in the know with the LSA motor, what RPM range is this motor happy at?
I never owned a vehicle with a SC or Turbo, so I have no idea what is a safe range to cruse in.
In my previous cars I would cruse between 3000 - 4000, then step on it and shift at 6000 with a redline of 7000.
I know the mpg won't be pretty, but then again it's not pretty to begin with.
Thanks!
OVRKLL is offline   Reply With Quote
Old 03-29-2012, 06:51 AM   #2
SlingShot
SlingShot's Avatar
Drives: 2012 ZL1 - #670
If your talking about a cruising RPM, based off my LS3 I'd say 2K. The power band comes in around 4K.
Old 03-29-2012, 07:02 AM   #3
KLR ZL1
H-Town Camaro Club Member
KLR ZL1's Avatar
Drives: 17 Hyper Blue Metallic KLR-ZL1
With the supercharger I would think the tork would come in alot lower than 3-4K rpm. So cruising around at about 2000-2500 rpm is probably good.
KLR ZL1 is offline   Reply With Quote
Old 03-29-2012, 08:03 AM   #4
garfin
Resident Disciple
garfin's Avatar
Drives: 2010 CTS-V 6MN '98 Camaro SS (Sold)
Maximum grunt (torque peak) occurs at 3800 rpm on my CTS-V (manual).
Best regards,
Elie
2010 Cadillac CTS-V 6MN Thunder Gray
1998 Camaro SS # C079 SOLD
garfin is offline   Reply With Quote
Old 03-29-2012, 09:06 AM   #5
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
What's happy? LSA should be able to lope around on the freeway at less than 2K. Fuel cut-off is about 6200 or so, and it is making power right up to it. I think you're going to have to give circumstances before anyone can comment more, like racing, just driving, or whatever.
05 Hummer H2 SUV on OEM Air Ride
Forged 11.4:1 408 LQ4 (K1 crank & rods; Mahle pistons)/CPP LS3 CNC heads/BTR Stage IV LS3 cam/home ported L92 intake manifold/ported 90mm TB/custom Volant CAI/Kooks 1 7/8" LTs and 3" H-pipe/AFE dual 3" CB/Corvette Servo/el cheapo lift/Cognito UCAs/Sphon poly adjustable TA/Sphon adjustable rear LCAs/e'fan conversion/DirtyMax radiator/Moroso catchcan/HPTuners/HID conversion/LED exterior lighting/LED interior accents/Autometer Cobalts/AEM WB/ Pioneer AVH-5600BHS/Pioneer GM-9601/2-Pioneer TS-W310D4s/Obcon Labyrinth dual-12 box/lots of other little stuff
Old 03-29-2012, 12:05 PM   #6
hognutz
hognutz's Avatar
Drives: 2013 ZL1
the correct answere is about 800-6200. anything below and it start to feel a little melancholy and anything above that it and starts to get a bit pissed off.
2017 zl1 or GT350 hmmmm
2015 Hellcat-sold
2013 ZL1 -sold
2013 Dart
2013 Megacab 8" lift 38"mt's
hognutz is offline   Reply With Quote
Old 03-29-2012, 12:24 PM   #7
DangerZL1
Drives: Future ZL1 Owner
That's a high rpm to be crusing at with a V8, unless you're traveling at pretty high speeds, or have a really low rear end ratio. I'd expect the LSA in ZL1 not to be much different than the LS3. The supercharger wouldn't affect the speed the engine is comfortable crusing at.
DangerZL1 is offline   Reply With Quote
Old 03-29-2012, 12:54 PM   #8
OVRKLL
Happy would be driving down the freeway...i.e. 60 mph...would you be in 6th gear, 5th, 4th etc. I know the lower gear will cause higher gas consumption, but then again you don't want to be lugging the engine either....So Happy would be the point between lugging the engine - overly revving the engine in the higher RPM range while driving down the freeway, blvd, back road etc.
I guess a better way to ask this is:
If I'm driving at 35mph what would be the appropriate gear to be in?
If I'm driving at 60mph what would be the appropriate gear to be in?
etc. etc. etc.
Key word being "appropriate".
Thank you!
Old 03-29-2012, 12:56 PM   #9
OVRKLL
Yeah that's what I thought hence my question.
Sorry I wasn't clear on this...those rpm ranges were in a 4cyl bimmer and a 6cyl porsche.
Old 03-29-2012, 01:05 PM   #10
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
etc. etc. etc.
Thank you!
In my '95 with a T56, I'd cruise at those speeds in 5th and 6th, respectively. The gear ratios were the same, but I had OEM 3.42s (not 3.73s) and shorter tires, at 26" (not +28").
I'd say, if you're maintaining the same speed, keeping RPMs from LSA between 1600-1800 should be great for MPG and putting-along. GM small-blocks make great low-end power. 1800 is not lugging at all for these motors. Don't expect to pass anyone at those RPMs, but I've taken a lot of mountain grades at high elevations in my '95, with considerably LESS power (and weight, lol) so I suspect ZL1 isn't going to be too different
JMVHO - obviously - I don't have one, so these are just educated guesses only
Old 03-29-2012, 01:53 PM   #11
OVRKLL
Thank you very much...your educated guess is better than mine at this point. I hear you on the weight...oh sorry, you were talking about the car's weight...
Old 03-29-2012, 02:14 PM   #12
hognutz
hognutz's Avatar
Drives: 2013 ZL1
61mph is 1700 in 6th
36mph is 1600 in 4th
35mph is 2000 is 3rd
with the torque this car will have any highway cruise should be in 6th. www.f-body.org/gears/
1st 2.66
2nd 1.76
3rd 1.3
4th 1
5th .8
6th .63
3.73 gear
305/35-20 tire size.
2015 Hellcat-sold
2013 ZL1 -sold
2013 Dart
Old 03-29-2012, 02:24 PM   #13
OVRKLL
with the torque this car will have any highway cruise should be in 6th. www.f-body.com/gears/
1st 2.66
2nd 1.76
3rd 1.3
4th 1
5th .8
6th .63
3.73 gear
Mahalo for the info...the link doesn't work though...:(
Yeah this is going to be a Torquey one!
Old 03-29-2012, 04:46 PM   #14
hognutz
hognutz's Avatar
Drives: 2013 ZL1
fixed it.
2015 Hellcat-sold
2013 ZL1 -sold
2013 Dart
List ZL1 Option Codes OldJedi Camaro ZL1 Forum - ZL1 Specific Topics 103 11-30-2011 07:25 AM
happy happy joy joy happy happy joy some ZL1 stuff for me! 1BADZL1 Camaro ZL1 Forum - ZL1 Specific Topics 5 09-16-2011 04:03 PM
PWA "The Lounge" DGthe3 Off-topic Discussions 143773 11-06-2010 11:00 AM
Torque Converters Explained tbyrne V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 0 01-07-2010 12:38 PM
ProTorque Converters - FREE Shipping! tbyrne Transmission / Driveline 0 01-07-2010 12:36 PM
