Gen5DIY
Old 03-29-2012, 04:53 PM   #1
jsherm007
Always drop the top
jsherm007's Avatar
Drives: 2014 Stingray Vert 2LT z51
Brake (pedal) shake
So dealer replaced my slave clutch cylinder last week... All that is fine thus far. But they must have had to take off my brake pedal to get to other part.
Now my brake shakes over bumps, and rattles not only pedal but steering column (under dash). So I feel vibrations in wheel while holding it.
Can I fix this safely on my own or do I need to take it back to dealer? I'm rather good with tools but don't want to tighten anything that may prevent brake pedal from doin it job.
jsherm007 is offline   Reply With Quote
Old 03-29-2012, 05:10 PM   #2
Camaro21
Drives: SOLD - 2013 M6 ZL1
They wouldn't have to remove your brake pedal to install the slave cylinder. They had to remove the transmission and might have left something loose. I would definitely take back and test drive with them and show them what it is doing.
Camaro21 is offline   Reply With Quote
Old 03-31-2012, 12:28 PM   #3
jsherm007
Always drop the top
jsherm007's Avatar
Had car at dealer, they said there is nothing to adjust on brake pedal to make it not shake. It can't be normal the gas and clutch pedal are secure. There is about .5-.75" of play either way (left to right) on my pedal. That creates a rattle under dash. If I put foot on pedal, no rattle. S
What should I do find next closest dealer?
Old 03-31-2012, 12:28 PM   #4
jsherm007
Always drop the top
jsherm007's Avatar
They called the pedal normal, how is that possible?
Old 03-31-2012, 10:50 PM   #5
tavo431
Drives: 2010 camaro 2ss
Mine had the same problem.....
They first blamed it on my aftermarket wheels, but later said it was normal. I was like wtf?
I would like to know what is really going on.
tavo431 is offline   Reply With Quote
Old 03-31-2012, 10:50 PM   #6
tavo431
Has*
What do all the abbreviations mean? CrzyGamr2 5th Gen Camaro SS LS LT General Discussions 77 12-07-2012 05:34 AM
Stainless Steel Brake Lines on Sale MTI Racing Kevin Suspension / Chassis / Brakes 17 12-02-2010 01:05 PM
Unbeatable Prices on BC / Eibach / Hawk / Hotchkis / MTI / Racing Brake / SLP / More maperformance Suspension / Chassis / Brakes 10 10-04-2010 03:36 PM
ROTORA BIG BRAKE KITS 4-12 PISTONS/ 15" & 16" ROTORS SPECIAL ADKINS PERFORMANCE Suspension / Chassis / Brakes 0 08-03-2010 01:08 PM
***STILLEN Camaro SS Brake System Upgrade Package*** Team STILLEN Suspension / Brakes / Chassis 14 03-16-2010 02:00 PM
