Gen5DIY
Old 03-29-2012, 07:27 PM   #1
2012ZL1
CaRaHoLiC
2012ZL1's Avatar
Drives: '12 ZL1,67 Cam,68 Biscayne 427 4 sp
ZL1 Cam Choice
Looking for a camshaft upgrade for my Z when it arrives. I see there are a couple choices out there, LS9, Lingenfelter GT9, the street sweeper etc. Any one else been looking of have any comments or suggestions?
2012 ZL1
2.55 upper, 10" lower pullies, Innovators west billet hub and sfi balancer, solid blower drive isolator, 50 mm idler kit, full length S/S headers no cats, comp cams custom grind cam, comp roller rocker trunion kit, comp push rods,dual valve springs retainers and locks, Injector dynamics ID850 inectors, Rotofab ZL1 cold air kit, Lingenfelter 160 thermostat, Rotofab intercooler reservoir, stock plugs, LS7 90mm throttle body, GTO clutch reservoir mod, my own custom catch can, Tuning by Jannetty, install by me.
2012ZL1 is offline   Reply With Quote
Old 03-29-2012, 08:25 PM   #2
2012ZL1
CaRaHoLiC
2012ZL1's Avatar
ok, well personally, I'm considering the LS9. Its specs are .562/.558 dur @.050 211/230.
These cams are available as cheap as 118.00... so that and the matching springs would be pretty cheap, and a definate upgrade.
The comp cams cams are pretty hairy. The smallest is .624/.624 239/243. 400 bucks
For comparison is Lingenfelters supercharged cam replacement for ZR1.
Its .629/.629 215/247 at about 400 bucks
2012 ZL1
Old 03-30-2012, 02:07 PM   #3
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
IMVHO - if you haven't - establish your goals with the car. If you're looking for "only" 600 RWHP, that LS9 cam should be a great choice with only modest supporting upgrades to the intake and exhaust. Consideration of drivability and emissions might also be worth looking into. If you don't care about either, I say go big or go home! I have to take emissions into consideration (which also means drivability, because they go hand-in-hand). I'm been considering LS9's cam, too, but don't really want to tear into the shortblock. It would allow me to push less boost, and lower IATs, but it would be easier for me to pulley-up, as it were.
I also like LS9 cam because it's a factory cam. It's go gobs of engineering and dyno' time, and goes past GM's 100K durability requirements. Therefore - we know that it's not too extreme on the valvetrain and corresponding assemblies (i.e. valve guides, lifters, etc.). You only have to tickle 6500 RPMs, too - though - honestly - I'm not sure of the RPM-limits for the other cams . You know - I recall stories of borken springs and all that stuff from people running TREX and MS3 or other really hairy cams in LS1s, 6s, 2s, etc. Some reports were from not warming the motors up enough, and others were just because those kinds of cams just beat the piss out of the valvetrain. I recall GM engineers commenting on stock rocker arms really only being effective to about .600"-lift, or something like that, and many people reuse those rockers well into the .650"s...
Regardless - I look forward to what you decide on and see your reports. PLEASE keep is posted. Real-world, internets, and theory are all different things
05 Hummer H2 SUV on OEM Air Ride
Forged 11.4:1 408 LQ4 (K1 crank & rods; Mahle pistons)/CPP LS3 CNC heads/BTR Stage IV LS3 cam/home ported L92 intake manifold/ported 90mm TB/custom Volant CAI/Kooks 1 7/8" LTs and 3" H-pipe/AFE dual 3" CB/Corvette Servo/el cheapo lift/Cognito UCAs/Sphon poly adjustable TA/Sphon adjustable rear LCAs/e'fan conversion/DirtyMax radiator/Moroso catchcan/HPTuners/HID conversion/LED exterior lighting/LED interior accents/Autometer Cobalts/AEM WB/ Pioneer AVH-5600BHS/Pioneer GM-9601/2-Pioneer TS-W310D4s/Obcon Labyrinth dual-12 box/lots of other little stuff
Old 03-30-2012, 03:14 PM   #4
2012ZL1
CaRaHoLiC
2012ZL1's Avatar
The only thing that worries me is the huge lift on the aftermarket cams. I don't believe our pistons are notched for valve reliefs like the ZR1, but they are dished in a reverse dome. I would check for interference of course, but I don't want to open a big can of worms like that.
Its worrysome already cracking into the motor only to have to change pistons etc. I think I am goint to go with the LS9 unless I find a middle of the road cam. I really don't want to go much over .600 lift anyway.
Emissions aren't a concern to me BTW, so if I knew the bigger ones would clear I guess that would be ok. I am going to continue my research over at the caddy sites to see what they are doing.
2012 ZL1
Old 03-30-2012, 03:15 PM   #5
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Originally Posted by 2012ZL1 View Post
The only thing that worries me is the huge lift on the aftermarket cams. I don't believe our pistons are notched for valve reliefs like the ZR1, but they are dished in a reverse dome. I would check for interference of coarse, but I don't want to open a big can of worms like that. Its worrysome already cracking into the motor only to have to change pistons etc. I think I am goint to go with the LS9 unless I find a middle of the road cam. I really don't want to go much over .600 lift anyway.
Totally great points! I forgot about PTV!!! PM'ing you...
Old 03-30-2012, 08:01 PM   #6
69 Rebel
69 Rebel's Avatar
Drives: 2010 IBM 2SS/RS Auto
Also very interested in a cam, will be following this thread closely. Report back your findings guys.
Version I
Jannetty Racing 550 RWHP Street Brawler Package,
Powered by TVS2300 Maggie
http://www.camaro5.com/forums/showthread.php?t=100385
Version II
416ci stroker/4L80e
701rwhp 750rwtq
build and tuned by
SPI-Performance
69 Rebel is offline   Reply With Quote
Old 03-30-2012, 08:08 PM   #7
CyberPredator
50 Shades of Prey
Drives: TT/SS
Are you serious right now. If your that worried don't do a cam. Installation of an ls9 cam isn't worth the 15hp. Just do a pulley intake and headers
Futral Motorsports built and tuned
CyberPredator is offline   Reply With Quote
Old 03-30-2012, 11:28 PM   #8
hognutz
hognutz's Avatar
Drives: 2013 ZL1
I would call a couple places like katech or hennessy or other tunners.
my .02 on cams is the part cost is nothing compared to the labor whether your paying or doing the work yourself. Talk ot people that work onthe engines alot at take all your mods into acount with the grind.
katech uses the Ls9 cam in the CTS-v for the e85 race gas version. henessy uses ported heads and cams for there 700hp version.
I feel like the the ls9 cam alone can't be worth much because they run more boost and only get 40more hp. I think there grind is to get the rpm out of the lighter rods. Cheap part cost but might be a huge gain.
I would look for an aftermaket cam that takes everthing you want to do in account. longtubes etc. even if you not doing the mod now get the cam that will work with it eventually.
2017 zl1 or GT350 hmmmm
2015 Hellcat-sold
2013 ZL1 -sold
2013 Dart
2013 Megacab 8" lift 38"mt's
hognutz is offline   Reply With Quote
Old 03-31-2012, 04:43 AM   #9
2012ZL1
CaRaHoLiC
2012ZL1's Avatar
I have LT headers already, btw the cam is worth more than 15 hp.
2012 ZL1
Old 03-31-2012, 04:46 AM   #10
2012ZL1
CaRaHoLiC
2012ZL1's Avatar
Some good points you make.
I am doing other stuff with the cam though.
pulleys (2)
lt headers
tune
cai
injectors
x pipe
2012 ZL1
Old 12-21-2012, 12:14 PM   #11
ace32x
ace32x's Avatar
Drives: 2013 ZL1
bumping an old thread what size cam did you end up going with? starting research on my own currently and looking for some feed back.
C6Z06 400ci, twin gen 2 promod 88's,th400, Alky car
ace32x is offline   Reply With Quote
Old 12-21-2012, 03:39 PM   #12
DangerZL1
Drives: Future ZL1 Owner
I've looked into cams and really like the KDI TS29 cam. It's larger than the Lingenfelter GT-11, but has less valve lift, so it shouldn't be as hard on the valvetrain. It's supposed to pull hard in the top end and still be mild enough to use with an auto car and the stock converter. Plus, there's a small lope to the sound.
DangerZL1 is offline   Reply With Quote
Old 12-21-2012, 04:31 PM   #13
tsnow
tsnow's Avatar
Drives: 12' ZL1, AGM 6M
Good all around cams that are very compatible with stock valve train, other than springs of course-
220-230 duration at .050 with .580-.600 lift. 114-118 lobe separation.
ADM has a couple choices here.
tsnow is offline   Reply With Quote
Old 12-21-2012, 04:35 PM   #14
ace32x
ace32x's Avatar
Drives: 2013 ZL1
220-230 duration with .580-.600 lift. 114-118 lobe centers.
sweet thanks for the info ill look into thiers, hadnt come across them yet.
DIY: LS3 Camshaft Install (a lot of pictures, may take a moment to load) robertway Camaro DIY & HOW-TO instructions & discussions 290 02-10-2018 10:11 AM
Some info for ZL1 owners R6P Camaro ZL1 Forum - ZL1 Specific Topics 92 12-04-2016 10:00 PM
FE3 to ZL1 Zway Bar UpgradeZ and ZL1 ZuZpenZion PackageZ JusticePete Suspension / Chassis / Brakes 111 05-08-2013 11:38 PM
New Camaro ZL1 Video Feature - Phase Four: Aerodynamic Testing 1BADZL1 Camaro ZL1 Forum - ZL1 Specific Topics 104 11-13-2011 04:24 PM
SLP ZL1 TESTED!!!!! SVT_SRT 5th Gen Camaro SS LS LT General Discussions 5 08-03-2011 09:50 AM
