Old 03-29-2012, 07:53 PM   #1
streetbeast
streetbeast's Avatar
Drives: 2010 Camaro RS/SS LS3
Tunnel brace exhaust question
Does anyone know if one of those aftermarket tunnel braces give more exhaust clearance than a factory brace with 1/4" spacers? I was looking at the LSR one, Elite engineering, or the UPR. I obviously have 3" exhaust, which is about a 1/4" from the brace. I don't hear it hitting, but i am thinking if the exhaust settles at all, I'm gonna have some contact. Stainless Works recommends 1/2" clearance, but I don't have that.
Stainless Works Retro Catback
streetbeast is offline   Reply With Quote
Old 03-29-2012, 09:29 PM   #2
bthibodeaux
bthibodeaux's Avatar
Drives: Black 2011 2SS/RS M6 Vert
Check out the ARH floor brace. It offers lots of clearance, as well as added stiffness. Do a search for it, here and you will get plenty of info about it. Good luck.
2011 Black 2SSRS M6 Vert, Nitto Invos on HRE P40s (20X11 rear, 20X9 front), lowered 1" on Pfadt coilovers, Eibach sway bars, American Racing frame brace, Brembo big brakes (16" front, 15" rear), ZR1 dual disc clutch, MGW Shifter, 3.91 gears with Eaton Truetrac and LPW cover, DSS 1000HP axles, DSS 3.5" aluminum drive shaft, Magnacharger with RDS Stage II and 2.8" pulley, Lingenfelter GT9 Cam, GM CNC ported heads, American Racing LT headers with high flow cats, custom 3" exhaust with Magnaflow mufflers and resonator (630 RWHP).
bthibodeaux is offline   Reply With Quote
Old 03-29-2012, 10:35 PM   #3
daveagogo1
TRI COUNTY TAMPA
daveagogo1's Avatar
Drives: 2011 1SS/RS VR/BLK A6
I have the 3" Magnaflow comp catback. Ordered a billet notched brace from TORQ. I can slide my hand in between the brace and the pipes now and it's a ton stronger. With stock brace pipes were hitting
Originally Posted by HufferSS View Post
Fast cars have rubber on the quarter panels...you sissies need to knock it off.
daveagogo1 is offline   Reply With Quote
Old 04-01-2012, 09:19 PM   #4
Ronn
Ronn's Avatar
Drives: 2010 Camaro
You could put another 1/4 washer on each corner if it settles again.
1SS / RS / M6 / IOM / Black rally stripes / Polished wheels
It's a high school prom, it's a Springsteen song, it's a ride in a Chevrolet...
Ronn is offline   Reply With Quote
Flowmaster 3" AMT Catback (Aftermarket Tunnel Brace Needed) IronToss Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 11 02-22-2012 12:01 PM
MAGNAFLOW Cat-Back / Axle-Back Exhaust Systems | FREE Shipping Apex Paul V8 Bolt-Ons & Tunes 134 01-24-2011 01:56 AM
Stainless Works V-8 Catback exhaust tunnel brace clearance? Frayles Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 5 09-27-2010 08:36 PM
BMR Fabrication Launches New Product - 2010 Camaro Driveshaft Tunnel Brace (DTB004) BMR Suspension Suspension / Chassis / Brakes 30 10-12-2009 09:15 AM
