Old 03-29-2012, 08:00 PM   #1
mikeSS
mikeSS's Avatar
Drives: 2015 c7
efficiency of high flow cats with a cam?
i have a question about high flow cats, with our cammed camaros.
when i went to pick up my car from the shop after a cam job, i honestly cannot remember exactly what he said. but i know it was something about cams not being emission friendly or something of that nature.
so my question, even with high flow cats plus correct tune our cars still are not emission friendly and would fail a smog test ?
Old 03-29-2012, 08:08 PM   #2
InfernoSS454
InfernoSS454's Avatar
Drives: 2010 camaro ss
Thats an interesting question. Fortunately my area don't check emmissions
InfernoSS454 is offline   Reply With Quote
Old 03-29-2012, 08:13 PM   #3
mikeSS
mikeSS's Avatar
Drives: 2015 c7
ya same with my area, which is why i am not really worried about it. but still something that i rarely seen talked about.
Old 03-29-2012, 08:39 PM   #4
bthibodeaux
bthibodeaux's Avatar
Drives: Black 2011 2SS/RS M6 Vert
You may be asking a simple question to a complicated answer. However, generally speaking a car should pass the smog test as long as there is not a CEL, and the tuner has not turned it off for this particular code. Every car and engine combination has its own CO and CO2 emissions specifications. The CEL should trigger if those specs are exceeded by certain limits. However, I am not sure that all state smog tests allow for the same spec variance that every car's CEL trigger sensors do.
I can say that I have modded plenty of cars in Texas, and always passed the smog test as long as I did not have a CEL.
2011 Black 2SSRS M6 Vert, Nitto Invos on HRE P40s (20X11 rear, 20X9 front), lowered 1" on Pfadt coilovers, Eibach sway bars, American Racing frame brace, Brembo big brakes (16" front, 15" rear), ZR1 dual disc clutch, MGW Shifter, 3.91 gears with Eaton Truetrac and LPW cover, DSS 1000HP axles, DSS 3.5" aluminum drive shaft, Magnacharger with RDS Stage II and 2.8" pulley, Lingenfelter GT9 Cam, GM CNC ported heads, American Racing LT headers with high flow cats, custom 3" exhaust with Magnaflow mufflers and resonator (630 RWHP).
bthibodeaux is offline   Reply With Quote
Old 03-29-2012, 09:12 PM   #5
Lee123
Lee123's Avatar
Drives: 2012 2SS M6
2 or 3 people at the shop told me mine will pass with the cam and high flows and the guy who actually did the work told me if it doesn't he'll fix. On the other hand, I'm going to have to hope the people doing the test have a head cold that day because it doesn't smell like it will pass. We get 4 or 5 years before we have to go, and who knows what the rules will be then. We're not supposed to talk politics here, so I'll just say if the wrong people get elected the whole country could have rules like California in 4 more years.
2012 2SS Convertible
Magnuson, Headers, Cam, JRE Tune. 563 HP.
Lee123 is offline   Reply With Quote
Old 03-29-2012, 11:40 PM   #6
mikeSS
mikeSS's Avatar
Drives: 2015 c7
hahah right.
Old 03-30-2012, 11:07 AM   #7
Nessal
Drives: Exige, Miata, Ghia
In CA, we have the visual, OBD hook up, and sniffer test done when we smog our cars. Yes they check everything. I heard starting in 2013, they are going to stop with the sniffer test and only do the visual and OBD hook up. So I would think that if your tune is good and you're not throwing any codes, then you just have to worry about the visual. Every single shop that I have brought my previous car to are complete dolts. They couldn't tell you the difference between an intake manifold and a door knob. So as long as your readiness codes come back perfect, then you're good. By the way, it has yet to be determined if tunes will some how make you not pass. I heard that they have some sort of stock parameters that they get from the state/manufacturers and if it doesn't match your ECM, then you fail.
Nessal is offline   Reply With Quote
Old 03-30-2012, 12:15 PM   #8
mikeSS
mikeSS's Avatar
Drives: 2015 c7
ya thats what i was talking about the sniffer test. i thought the nature of cams with the valves being open longer its bond to let more gas escape. i watched a movie on cats, they said once cats were warmed up they stop 99% of Co2 gas. i was wonder if high flow cats with a cam would also be 99%.
Old 03-30-2012, 12:22 PM   #9
molsonbrador
molsonbrador's Avatar
Drives: 2010 Camaro SS, 99 Silverado
I thought you were cammed?
molsonbrador is offline   Reply With Quote
Old 03-30-2012, 03:37 PM   #10
SSDan
SSDan's Avatar
Drives: 2016 1SS 6MT NPP
He is and is just wondering how effective his HF cats are at burning off the exhaust vapors. I'm curious too since I have a cam and HF cats as well. I know one thing the cats are doing something because until they heat up I get a lot of tail pipe vapor/odor on a cold start. Once runnning for a few minutes the odor goes away. Odor aside - not sure if they are burning off 99% of the CO2 though.
2010 Camaro 2SS Cam/Headers/CAI/3.91 gears
476 rwhp/440 rwtq (sold)
SSDan is offline   Reply With Quote
Old 03-30-2012, 03:52 PM   #11
Lee123
Lee123's Avatar
Drives: 2012 2SS M6
I'm actually glad to hear that because if I let my car warm up in the garage it gets a bit smelly in there. Smells just like when I used to have a garage that was 10 feet lower than the street and had to warm motorcycles up in the garage before riding up hill to the street. I thought maybe it was something with my tune making it run too rich on cold start but it sounds like that is normal.
Does my LS3 need to be retuned when switching from high flow cats to midpipes? TCAT Tuning / Diagnostics -- engine and transmission 4 12-30-2011 11:08 AM
JBA High Flow Cats + ?axle back exhaust? NORSS426 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 14 02-26-2011 10:28 AM
High flow cats vs no cats steven32708 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 7 02-08-2011 06:36 PM
Help regarding high flow cats and headers Rabamaro Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 6 01-30-2011 09:20 PM
thinking about getting high flow cats , but have some questions mikeSS Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 1 07-22-2010 07:54 AM
