HeadlightArmor
Old 03-30-2012, 12:59 AM   #1
usnavydoc
usnavydoc's Avatar
Drives: 2012 2SS LS3, 2012 Ford Focus SE
High performance spark plugs?
A friend of mine recommended a mechanic to help me install any parts I need in my Camaro.
The mechanic said I should replace the stock spark plugs and wires with high performance ones, as the stock plugs are design to last 100K miles but not for performance. He said he could replace the spark plugs with high performance ones for $20.
Does a so called high performance spark plug really make any difference? $20 doesn't sound too bad.
Corsa cat backs, K&N CAI, Borla headers, Solo high flow cats, Jannety Racing tune, MGW short throw shifter
usnavydoc is offline   Reply With Quote
Old 03-30-2012, 02:50 AM   #2
Avenging Orange
Avenging Orange's Avatar
Wouldnt waste the money. Stock plugs are very good.
2010 Inferno Orange 2SS/RS M6 Black Leather,Sun Roof, OBX Headers, Haltech CAI , non synthetic fluids, Mike Norris tuned 419/413
2015 Ford Interceptor// 2007 Ford F150 XLT 4X4
Avenging Orange: 40 years of not buying into the Hype........and damn proud of it!!
Old 03-30-2012, 03:40 AM   #3
iHasCamaro
Drives: Silver 2012 1SS
I would only worry about plugs with forced induction, and that's only to play with gaps and temp ranges. Most of the crap they sell as "performance" is really just that...CRAP! If you are doing a track day you might run some copper plugs 1 heat range colder to fight knock, but it's not for horsepower gains. On the street that wouldn't make sense.
iHasCamaro is offline   Reply With Quote
Old 03-30-2012, 01:13 PM   #4
urr2slo
urr2slo's Avatar
Drives: 2010 2ss ss/rs abm, 2016 2ss/rs hbm
Go ahead and replace them, this way you can waste your time and money trying to figure out why it runs like crap with new plugs.
High Performace plugs are B/S. You wont find a better performing spark plug for a stock engine than whats in it. Unless your boosted or using squeeze dont waste your time and money.
URR2SLO - If you're not going fast enough, get out the way......
urr2slo is offline   Reply With Quote
Old 03-30-2012, 05:58 PM   #5
MTI Racing Kevin
MTI Racing Kevin's Avatar
Drives: 2010 Camaro
Plug Wires
You are ok with the stock plugs, but a good wire will benefit your Camaro. Heat kills the effectiveness of plug wires causing them to have more resistance then when cold. So a well insulated wire can improve the performance and horsepower of your car. The materials used in the MTI Racing wires is the same insulating material used in the IRL racing series cars that regularly top 200mph and can generate massive amounts of heat. You will never see a thin uninsulated wire on these cars and why should you have them on your pride and joy. This is a mod any one can do themselves.
Check out the MTI Racing Wires here.
MTI Racing Kevin is offline   Reply With Quote
Old 03-31-2012, 06:04 AM   #6
Sebastian
Sebastian's Avatar
Drives: Camaro 2011, 6.2L 2SS
i gone for Granatelli wires due to the heat effect here ( heat from headers and outside temperature).
My Fat-Lady: Stainless Work Turbo-S Tube Catback, K&N Intake, Dynatech Dynamaxx 1 7/8 Headers with Cats, Tune from Janetty Racing + SCT Tuner, Granatelli Motorsport 0hms Red Ignition Wires (high Temp)
to be continued sooner!!!
Sebastian is offline   Reply With Quote
Old 04-01-2012, 07:11 PM   #7
usnavydoc
usnavydoc's Avatar
Thanks for all the replies. I am going to research what wires I should get...the headers I just installed are pretty hot.
Old 04-01-2012, 08:31 PM   #8
usnavydoc
usnavydoc's Avatar
I did some research and decided to give the Granatellis a try. This video I found made me curious in trying them:
I will do my own dyno testing when I get a chance...my car isn't as modified as the Camaro in the video, which has twin turbos, so I don't expect to gain much hp, if any.
Old 04-01-2012, 09:45 PM   #9
MikeOD
Drives: 2010 M6 2SS
I would actually go with an NGK plug before I'd bother with a new wire. I have found differences in knock tolerance depending on the plug I've run...the stock plugs are ok, but I have had more success tuning for NA power in my own car running NGK plugs. I average about 30K on the car between winters (when I put it away) and I throw a set of plugs at it once a year, it costs like $16 or something total, and these cars are so easy to work on, it takes about 15-20 minutes. If you care enough about the car to put headers on and tune it in the first place, I feel it's worth it.
2010 Camaro SS M6. Heads/Cam/Intake/Headers/Exhaust/Suspension
MikeOD is offline   Reply With Quote
Old 04-02-2012, 11:25 PM   #10
Thyshallsmite
Drives: 2011 Grand sport c6 corvette
Been looking at these http://www.densott.com/ but i really dunno without any 3rd party testing if they actually work, anyone got a dyno i can borrow? lol
Thyshallsmite is offline   Reply With Quote
Old 04-02-2012, 11:49 PM   #11
Predator/2SS
Predator/2SS's Avatar
Drives: 2010 Summit White 2ss/rs M6
I watched a episode of horsepower tv where they put these http://www.e3sparkplugs.com/ to the test and they outperformed the stock plugs.
Predator/2SS is offline   Reply With Quote
Old 04-03-2012, 02:03 AM   #12
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
Gimmicky plugs are just that, gimmicky. They get you to pay $10+ for a spark plug and for your money, you get worse performance.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 04-03-2012, 05:45 AM   #13
Brianskeet
Brianskeet
Brianskeet's Avatar
Drives: RJTC 1SS RS L99
I don't claim to be genius about plugs, but Jannetty is and he will tell you real quick that our stock plugs are very high quality and except in very rare circumstances do not need to be changed.
ARH 1 7/8 coated LT, High flows, Corsa L99 exhaust, Vmax CNC throttle body, Elite Engineering catch can and tunnel brace, C.A.I. Apex Washer relocation and scoop, Janetty Tune, MSD wires, DEI heat shields, RB rotors and pads, Mike the powder coater calipers, pedders lines, Forgestar F14's, Gorilla nutz, MTI spoiler finished by Gary, Gary's Customz Bow Ties, Side Markers and Tails tinted, Bezels matte black, Badges deleted, Windows Tinted, AAC DRL P13W lights, AAC tinted LED reverse lights, AAC LED interior lights, RPI match painted DRL Bezels, Lis plate frame, Lloyds mats
Brianskeet is offline   Reply With Quote
Old 01-26-2014, 10:21 PM   #14
AKA-22
AKA-22's Avatar
Drives: ELLE-1
Sub
AKA-22 is offline   Reply With Quote
2010+ Camaro V8 Hawk HPS Pads | Performance Ceramic Pads | Hawk HP Plus Pads - Pair AutoAgenda Suspension / Chassis / Brakes 13 08-14-2013 01:38 AM
GM Reveals US-Spec 2013 Chevrolet Spark FenwickHockey65 General Automotive + Other Cars Discussion 34 10-08-2012 09:31 PM
Acronyms? KEEP RT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 20 03-11-2011 09:57 PM
4th Annual GM Performance Parts LSX Shootout!! nmcajeff Dragstrip and Launch Techniques Discussion 3 07-30-2010 01:05 PM
