Emblempros
Old 03-30-2012, 02:05 AM   #1
xavier02832
xavier02832's Avatar
Drives: 13 Camaro ZL1, 13 Shelby GT500-Sold
Will the current 2.9 whipples fit on the ZL1's LSA
Like the title says, anyone know if the 2.9 whipples will fit/work on the new ZL1 LSA motors without modification?
xavier02832 is offline   Reply With Quote
Old 03-30-2012, 06:55 AM   #2
adamgl
adamgl's Avatar
Drives: '98 Camaro Z28, '06 Z06
Hope so. That'd be a great upgrade. With some motor work too.
'10 Camaro 2SS/RS A6 Sold :( ARH, FM Super 44's, K&N CAI, ADM scoop, Diablo Tune, RX catch can.
'98 Camaro Z28 M6 TSP headers, true duals, AIR/EGR/AC/muffler delete, CAI, Subframe con.,
shock tower brace, Stg. 2 T56 rebuild. Monster Clutch Stg. 2, Electric Water Pump, TT2 wheels, 315 NT555's
'06 Z06 2LZ, Cam, P/P/M Heads, FAST Intake/TB, ARH, CAI, HP Clutch/FW, C5 Axles,
Pfadt Coilovers/Poly Bushings, Carbon Fiber: Everything, lol. HID's, 360 Forged Spec 5's/Invo's, Custom Interior. 550 RWHP
http://www.camaro5.com/forums/showthread.php?t=235911
adamgl is offline   Reply With Quote
Old 03-30-2012, 08:20 AM   #3
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
You won't be able to swap the Whipple blower on top of LSA like you could with past Mod'-motors. I believe those 5.4s and 4.6s had lower manifolds that you could reuse from the OEM blower assembly - however - LSA (and LS9) have the SC housing included as part of the entire SC assembly. The rotors and mechanicals are all part of the intake manifold, so in order to get any aftermarket SC onto LSA, one needs an entire assembly, like that used for SS.
Yes - it will work, but will be more expensive than the Ford kits used to be (as far as I remember). If that doesn't matter too much, then you will be just fine .
FWIW - unless you're going to be pushing considerable power - LSA is pretty stout, despite what many are giving it credit for. While it doesn't have the headroom as the Philly from Dearborn, I'm sure most won't push it past reliable limits. JMVHO.
05 Hummer H2 SUV on OEM Air Ride
Forged 11.4:1 408 LQ4 (K1 crank & rods; Mahle pistons)/CPP LS3 CNC heads/BTR Stage IV LS3 cam/home ported L92 intake manifold/ported 90mm TB/custom Volant CAI/mid-length headers/AFE dual 3" CB/Corvette Servo/el cheapo lift/Cognito UCAs/Sphon poly adjustable TA/Sphon adjustable rear LCAs/e'fan conversion/DirtyMax radiator/Moroso catchcan/HPTuners/HID conversion/LED exterior lighting/LED interior accents/Autometer Cobalts/AEM WBPioneer AVH-5600BHS/Pioneer GM-9601/2-Pioneer TS-W310D4s/Obcon Labyrinth dual-12 box/lots of other little stuff
Old 03-30-2012, 08:28 AM   #4
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: 2010 2SS IOM ,2014 Z/28, 66 Nova
Old 03-30-2012, 09:49 AM   #5
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Originally Posted by 2SSRS View Post
AH!!! Spank you very much
Old 03-30-2012, 11:18 AM   #6
adamgl
adamgl's Avatar
Wonder if there are any CTS-V owners who've done this with the LSA?
Old 03-30-2012, 12:33 PM   #7
hognutz
hognutz's Avatar
Drives: 2013 ZL1
I would not spend the money on a compresor swap with without updgrading the internals.
Look at what hennessy does with the CTS-V. they don't add a ton of boost until they upgrade the internals. they can make more power though with ported heads, cam, headers etc. If I remeber there 700hp 11.2 et wagon is still with stock compressor.
2017 zl1 or GT350 hmmmm
2015 Hellcat-sold
2013 ZL1 -sold
2013 Dart
2013 Megacab 8" lift 38"mt's
hognutz is offline   Reply With Quote
Old 03-30-2012, 12:51 PM   #8
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
There is a non-Sponsor who offers a Maggy 2300 kit and KB; I haven't noticed Whipples, but I can't see why they wouldn't apply. I think this company just happens to have used the ones that were available first. You can PM me, if you would like their name, but I can't post it. They are doing a lot of work on LSAs and make some really good power.
The company I mentioned above uses a lot of stock 1900 parts and pushes that little thing to it's max. I believe their highest horsepower 1900 kit uses fuel, exhaust, and a complete top-end (H/C) and still pushes the compressor to 19 psi... I believe it comes in at more than 700 RWHP. I believe that's on a stock shortblock, too!
I'm not suggesting these guys are any better than Hennessey, however, Cadillac has used them many times for their SEMA cars, so if that's any indication on their quality, I'd say you are probably in safe hands. They actually manufacture CNC'd pulleys, plenum spacers, HEs, and a bunch of other stuff in-house using military grade materials.
There's definately more than one way to skin a kitty
Personally - my plan takes stealth into consideration (because of my areas considerable law enforcement due to street racing...): upper and lower pulleys, intercooler upgrade, very modest exhaust and intake mods' and probably mid-teens for boost. Considering ADM just showcased their Stage 1 CTS-V package (including the customer's own inlet tube), and produced 590 RWHP on a otherwise completely stock car, my modest 600 RWHP-goal should be pretty easy. I believe I won't be over-rev'ing the SC, and my IATs should be modest. Best of all - I'll enjoy the music of that little 1900 under throttle
A 2.9 Whipple certainly has the potential to go past reasonable OEM LSA power levels. Depending on your goals, that 2.9 will work less than the 1900 and should produce lower IATs at the same boost level. When Eatons 1900 rotors were initially announced, Magnuson said they should be good to about 700 FWHP, or so. Considering the information I posted above, it is easily capable of that at about 13 psi on a stock V'. I bet a Whipple could produce 600 RWHP at only about 10 psi (considering the really tame cam in LSA). I believe really being honest with your goal is paramount in making the best use of your money. A blower too big won't be as effective as a properly sized one.
JMVHO
Old 04-01-2012, 07:56 AM   #9
Meister@Torq
Drives: 2001 Crown Vic
Send a message via AIM to Meister@Torq Send a message via MSN to Meister@Torq
Yes, the blower is capable of being installed but the LSA motor uses a different front cover and a 3 belt system. To make this work you would need to swap a ton of stuff, maybe some hard lines as well but we are up for it :-)
Whipple IS working on a 2.9L and some other blowers for the LSA/LS9 engine setups but it is months out at this time.
The 2.9L has major benefits over the 1.9L. Less boost to make similar HP, broader torque curve because of the discplacement, maximum rpm for future, cooler temperatures because of the efficiency and lower rpm.
We have done CTS-V's and know what they can take, what they cant, what the HP and torque curves look like with every possible combination.
We also do a ton of Ford vehicles with similar setups and I can tell you the 2.9L is a superior upgrade.
Meister@Torq is offline   Reply With Quote
Old 04-01-2012, 01:48 PM   #10
xavier02832
Thanks Paul , not only did you answer my question but you explained the pros and cons of the whole process which is exactly what I was looking for. Goes to show why TORQ is my prefered one stop shop for all my preformance needs. YOU GUYS ROCK
Keep up the good work guys
Old 04-01-2012, 02:32 PM   #11
xx_ED_xx
xx_ED_xx's Avatar
Drives: 04 Silverado
Just pull it off and add turbos. Or do like I have seen on the zr1's and just add turbos...
xx_ED_xx is offline   Reply With Quote
Old 04-01-2012, 02:49 PM   #12
xavier02832
Thats not a bad idea
Old 04-02-2012, 08:57 PM   #13
ADM PERFORMANCE
Drives: 2016 CAMARO SS
You want facts on all your ?
Call me anytime 9-5 M-F
ADM PERFORMANCE is offline   Reply With Quote
Old 04-21-2012, 06:01 PM   #14
2011RS/SS
2011RS/SS's Avatar
Drives: 2016 corvette Z06
my buddy collaborated with whipple on making a 2.9 whipple for the ctsv. It is crazy fast.
He is pushing around 850rwhp with a built stock cubed engine. His partner has a V with head/cam with stock internals and he is pushing around 750rwhp. The LSA engine can take the power but for how long remains the question
2011RS/SS is offline   Reply With Quote
The mighty LSA supercharged V8. Mr. Wyndham Camaro ZL1 Forum - ZL1 Specific Topics 137 05-07-2011 10:05 PM
The ZL1's LSA engine used as marine outboard OldJedi Camaro ZL1 Forum - ZL1 Specific Topics 5 04-12-2011 09:36 AM
So how did they get the LSA intercooler top to fit ?? 2000Firehawk Camaro ZL1 Forum - ZL1 Specific Topics 1 02-10-2011 01:29 PM
2012 Z28 HP Speculation LostInMoscow Camaro ZL1 Forum - ZL1 Specific Topics 145 02-10-2011 02:59 AM
Check your Order here bvonscott Camaro Price | Ordering | Tracking | Dealers Discussions 665 06-29-2009 01:00 PM
