Old 03-30-2012, 08:36 AM   #1
Kctarboosh
Drives: 2012 zl1
trailering ?
Hey guys quick question. My dealer is about 70 miles away, is there a certain type of trailer I can use to bring her home? I would like to save the miles I like low miles. I thought I was reading something about some yellow shipping blocks we are suppose to use when moving the car.
Kctarboosh is offline   Reply With Quote
Old 03-30-2012, 08:37 AM   #2
Drake Heminger
Drake Heminger's Avatar
Drives: 2014 Stingray Z51
install the yellow spacers in the front and you should have ground clearance for any standard type trailer
"What a coincidence, Drake returns and brings
brand new ZL1's with him...." - CAM....ZL1
Drake Heminger is offline   Reply With Quote
Old 03-30-2012, 08:38 AM   #3
mlee
www.CamaroFest7.com
mlee's Avatar
Drives: 2017 A10 ZL1
70 miles... WoW... just consider them break in miles... you could do more damage loading and unloading off a trailer than it's worth.
Old 03-30-2012, 08:48 AM   #4
pastohio
Drives: Indy Pace Car
See if the dealer that has a rollback to make some extra cash....maybe they would help you, maybe rent a Uhaul small truck and an open trailer ?? ...call a towing service(with a rollback) and see what they charge sometimes like a dollar per mile ???
pastohio is offline   Reply With Quote
Old 03-30-2012, 09:06 AM   #5
Pgoldston
Drives: 1999 camaro
What are you refering to drake. I have to drive 600 miles to pick up mine and want to trailer it
Patrick
Pgoldston is offline   Reply With Quote
Old 03-30-2012, 09:20 AM   #6
kgilley09
kgilley09's Avatar
Drives: 99 Silverado
Patrick
The car comes with spacers to put in the front suspension to give you extra ground clearance for loading it onto a rollback or trailer. If I recall correctly when the dealership takes them out they are supposed to put them in the glovebox. As far as installation, I would assume you'll have to jack the front end up a little bit to get the weight off the suspension, just put them in place, and let it back down. Or as far as that goes in your case just tell the dealer to leave them in place since you plan to throw it up on the trailer, then just pull them out when you get her home.
kgilley09 is offline   Reply With Quote
Old 03-30-2012, 09:24 AM   #7
2012ZL1
CaRaHoLiC
2012ZL1's Avatar
Drives: '12 ZL1,67 Cam,68 Biscayne 427 4 sp
Depending on the road condition at delivery time a lot of people may trailer. Some roads are still covered in sand and salt, rocks etc.
2012 ZL1
2.55 upper, 10" lower pullies, Innovators west billet hub and sfi balancer, solid blower drive isolator, 50 mm idler kit, full length S/S headers no cats, comp cams custom grind cam, comp roller rocker trunion kit, comp push rods,dual valve springs retainers and locks, Injector dynamics ID850 inectors, Rotofab ZL1 cold air kit, Lingenfelter 160 thermostat, Rotofab intercooler reservoir, stock plugs, LS7 90mm throttle body, GTO clutch reservoir mod, my own custom catch can, Tuning by Jannetty, install by me.
2012ZL1 is offline   Reply With Quote
Old 03-30-2012, 09:26 AM   #8
Drake Heminger
+1
Old 03-30-2012, 09:28 AM   #9
b_williams_82
b_williams_82's Avatar
Drives: 2013 ZL1 #142
Patrick
I'm 1,500 miles from mine!! OUCH!!
b_williams_82 is offline   Reply With Quote
Old 03-31-2012, 01:38 PM   #10
mxkx250
mxkx250's Avatar
Drives: 12 ZL1, 98 Camaro SS, 67 RS/SS
Send a message via Yahoo to mxkx250
That would be a nice time to get some break in miles out of the way.
mxkx250 is offline   Reply With Quote
Old 03-31-2012, 03:21 PM   #11
Happy_Dan
Happy_Dan
Happy_Dan's Avatar
Drives: 2012 IOM Camaro ZL1 #569
Send a message via AIM to Happy_Dan Send a message via Yahoo to Happy_Dan Send a message via Skype™ to Happy_Dan
I can't wait to drive the 600 or 700 miles home in mine!
Happy_Dan is offline   Reply With Quote
Old 03-31-2012, 10:40 PM   #12
ZO6 Bryan
ZO6 Bryan's Avatar
Drives: 02 Z06, 95 Trans Am, 2012 ZL1
Me too! I'm putting 600 miles on mine on day one. I'm buying this to drive it. And taking it to a track event in May. www.fbody-event.org
And I'm going to drive it to get there also.
ZO6 Bryan is offline   Reply With Quote
Old 04-01-2012, 10:20 PM   #13
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
Only have 300 or so....but still...highly anticipating that trip!
Trailering should be relatively easy if using the supplied spacers as others have mentioned.
bmr trailering arms.. brand new!!! blackonblacksls Suspension / Chassis / Brakes 10 03-02-2012 12:34 PM
Trailering a 2010 Camaro SS pacecarguy Camaro DIY & HOW-TO instructions & discussions 13 03-16-2011 07:27 AM
LSR Performance Billet Trailering Arms now available!! Meister@Torq Suspension / Brakes / Chassis 7 12-02-2010 07:32 AM
Trailering question Hall of Fame 5th Gen Camaro SS LS LT General Discussions 2 06-03-2010 08:53 PM
Supplies for Trailering a Car Ject General Automotive + Other Cars Discussion 8 11-03-2009 10:19 PM
