Cold Air Inductions
Old 03-30-2012, 10:21 AM   #1
tpower
DBLCHBY III
tpower's Avatar
Drives: 15 1LE
Ontario ZL1
Is there a way to confirm that my ZL1 was the first Canadian allocated to be built. We cannot access GM connect in Canada
2G1FJ1EP2C9800241
built 02/13/2012
tpower is offline   Reply With Quote
Old 03-30-2012, 10:25 AM   #2
2012ZL1
CaRaHoLiC
2012ZL1's Avatar
Drives: '12 ZL1,67 Cam,68 Biscayne 427 4 sp
?...once there is a registry you will know
2012 ZL1
2.55 upper, 10" lower pullies, Innovators west billet hub and sfi balancer, solid blower drive isolator, 50 mm idler kit, full length S/S headers no cats, comp cams custom grind cam, comp roller rocker trunion kit, comp push rods,dual valve springs retainers and locks, Injector dynamics ID850 inectors, Rotofab ZL1 cold air kit, Lingenfelter 160 thermostat, Rotofab intercooler reservoir, stock plugs, LS7 90mm throttle body, GTO clutch reservoir mod, my own custom catch can, Tuning by Jannetty, install by me.
2012ZL1 is offline   Reply With Quote
Old 03-30-2012, 10:37 AM   #3
tpower
DBLCHBY III
tpower's Avatar
Drives: 15 1LE
2012ZL1 I saw you moved up congrats
Old 03-30-2012, 10:40 AM   #4
2012ZL1
CaRaHoLiC
2012ZL1's Avatar
Thank you sir! I am really happy considering maybe all will not be built this my.
2012 ZL1
Old 03-30-2012, 10:40 AM   #5
2012ZL1
CaRaHoLiC
2012ZL1's Avatar
Where did you see that? The Canada section?
2012 ZL1
Old 03-30-2012, 10:48 AM   #6
tpower
DBLCHBY III
tpower's Avatar
Drives: 15 1LE
I think so
Old 03-30-2012, 10:54 AM   #7
2012ZL1
CaRaHoLiC
2012ZL1's Avatar
You are definately the first on here, and If I had to bet on it I think you are the first Canadian one.
Yours was built pretty early, My dealer had called several times to see why mine wasn't picked up yet, and they said Canadian orders were being picked up later. Then I saw yours filled and that was before others.
The only thing that would mess that up would be someone who's in tight with the brass at GM Canada that we don't know about here or something like that.
2012 ZL1
Old 03-31-2012, 01:08 PM   #8
super60
Built with Pride "Oshawa"
super60's Avatar
Drives: 2011 Chev Silverado Z71 Crew
tpower
Congratulations on being what appears to be the 1st ZL1 delivery to Canada A special honour indeed Thank You from all of us here in Oshawa who had the privilege to be a part of your # 241's build team .
Enjoy the ride my friend , hope to see you driving that beast around Ontario this summer . Best Regards from Oshawa .
Mike Judge
Super60
In Memory of Dawson Ellert .
super60 is offline   Reply With Quote
BREAKING: 2012 CAMARO ZL1 - 6.2L LSA Supercharged - 6MT Revealed! Tran Camaro ZL1 Forum - ZL1 Specific Topics 756 05-01-2013 07:22 AM
CAMARO ZL1 FAQ and INFORMATION radz28 Camaro ZL1 Forum - ZL1 Specific Topics 280 11-04-2011 02:33 PM
Great Motortrend Article - GM’s Reuss: Camaro ZL1 “Wait is Worth it,” IOMZL1 Camaro ZL1 Forum - ZL1 Specific Topics 21 10-10-2011 03:32 AM
Track and Dyno Tested: 750hp SLP ZL1 Camaro Convertible DoggyB22 Camaro Convertible Forum 45 07-19-2011 10:22 AM
Recommend me a dealer for a ZL1 (Ontario preferred) Thorlius Canada 21 04-07-2011 10:25 PM
