Tuning / Diagnostics -- engine and transmission Tune and diagnostics for engines and auto transmission.
Old 03-30-2012, 10:25 AM   #1
Mkn95u0
Mkn95u0's Avatar
Drives: 2012 2SS Camaro (L99)
Check Eng. Light already? P0442
Car: 2012 2SS Camaro L99 - Auto
Aftermarket AEM COI
Last Fill up: 3/25/12 - 3983 miles - Shell, 91
I just threw a code at 4152 miles,
P0442 EvaporativeEmission Control System Leak Detected (small leak)
I’m, fairly new to "new" car's, still stuck in the 80's era of Camaro's where I could just count the flashes of the check engine light blinking with a paper clip... so any help on what this may relate to would be appreciated, its still under warranty - I only have an AEM intake installed, and wanted to make sure this isn't something that GM will find as the cause the check engine light went off if it needs to be taken in, since i know they're good at that (06' Aveo, they blamed a fuel electrical issue on the after market radio which was put in the car prior to me purchasing it, so wasn't covered)
From my understanding, this should be a fuel system vapor "Small" leak? So maybe me pulling my gas cap off and putting it back on could fix it (unlikely)?
Mkn95u0 is offline   Reply With Quote
Old 03-31-2012, 06:57 PM   #2
Ventmaster
Ventmaster's Avatar
Drives: 2010 Camaro RS 1LT M6
Yup, I bet just re-tightening the gas cap will do it.
May take a couple of drive cycles to drop away.
Airaid CAI, Rx ported TB, Mace ported IM, JBA shorty headers, Richmond 3.73, Borla touring axleback, Hurst short throw, NH-SS fix, IDEALG clutch m/c, SS struts/springs, Spohn trailing arms, Pfadt Racing sways, Pedders radius arm & rear subframe bushing inserts, 2LT gauge pkg.TSW Nurburgs. IPF S/C
Old 04-08-2012, 03:03 AM   #3
KRich2587
KRich2587's Avatar
Drives: 2012 1SS/RS six speed
I had the same fault @ about 3k miles on my 2012. Gas cap would most likely be a large leak.i had a leaking valve on the charcoal canister covered under warranty no issue.the tech told me he has done a few I bet your is leaking too. I dont have acai but I do have a catch can installed they gave me no issues. Also acai install should not cause a evap leak.
KRich2587 is offline   Reply With Quote
Old 05-18-2012, 05:56 PM   #4
brAnd7onX
Team L99
brAnd7onX's Avatar
Drives: 2012 Camaro SS IOM
Hey guys I have a 2012 L99 as well with only 4k miles and my check engine light came on as well for P0442. They said it is the vent solenoid and they special ordered it for me and I have to take it back in and get it fixed. We shall see if it works.
2012 Camaro SS IOM "TigreSS"
Borla "S" Catback
C.A.I. Intake
VMax Ported TB
JRE Tune
brAnd7onX is offline   Reply With Quote
Old 10-18-2012, 04:26 PM   #5
smokeylt
Drives: 2012 camaro SS 45th Aniversary Edit
Angry really at 3000 miles
Same problem with my Camaro. Just turned 3000 miles. Been in to the dealer twice. The first time the replaced the vent solenoid. The second time they did a smoke test and found no issue. Now the light is on again, with the check engine light and they say I have to bring it in again so they can finally call GM's technicians too see if they can figure it out.
Is anyone else having an ongoing issue?
smokeylt is offline   Reply With Quote
Old 10-18-2012, 04:49 PM   #6
Spektrum
Spektrum's Avatar
Drives: 2011 Camaro SS
Gas caps are usually attributed to a Large (Gross) Evap Leak, as someone stated above. Usually small leaks could be related to a bad hose or a solenoid that isn't opening or closing properly. A technician will be able to use a diagnostic tool to operate all the solenoids within the system to make sure they're activating/responding. Also they may run smoke through the system to check for visible leaks.
EVAP codes are the harder of the common CEL codes to diagnose, in my opinion.
If I'm repeating the comments of others, sorry. A lot of the EVAP codes in GM's that run through my shop are related to a faulty vent solenoid. I've even installed new ones that test bad as well.
Spektrum is offline   Reply With Quote
Old 10-19-2012, 09:26 AM   #7
wiruth
I have the same problem on my 2012 SS with 9100 miles. Taking it to the dealer on Monday. Will post the findings.
wiruth is offline   Reply With Quote
Old 10-24-2012, 10:11 PM   #8
Coyotekiller
Drives: 2012 AGM 2SS
Mine did this the other day. Went by advance auto, read the code (po442) and cleared them both. Asked the guys inside and they said to check the gas cap. I took it off, double checked it, and retightened it. No light since, but that was only 4 days ago.
Coyotekiller is offline   Reply With Quote
Old 10-25-2012, 02:06 PM   #9
wiruth
It was the vent valve at the rear of the car. They replaced it without removing the rear bumper. It also is running better. with the problem, it ran like it had a slight vacume leak. The low end is stronger and smoother now. They also reprogramed my air bag under a recall.
Old 10-25-2012, 03:13 PM   #10
Coyotekiller
I wonder if this could be why my car idles like its retarded...
Old 10-25-2012, 03:50 PM   #11
GaBoy25
GaBoy25's Avatar
Drives: 2010 SS/RS M6/2500HD Lmm LTZ
Epic post of the week!
FASTER than my SS....for now
2500HD (with a couple parts)
GaBoy25 is offline   Reply With Quote
Old 10-25-2012, 04:09 PM   #12
ROD_SS
ROD_SS's Avatar
Drives: 2013 1SS Camaro/ BMW 328i
Is this for all Camaro SS? Seem like everyone that posted has one
ROD_SS is offline   Reply With Quote
Old 10-26-2012, 05:32 AM   #13
Coyotekiller
Lol
I'm actually curious though too. The idle has always stumbled around on my car and I have tried to fix it a few different ways. Maybe this will help it out. It's just as likely to fix it as the rest of the stuff I tried.
Old 10-26-2012, 08:30 PM   #14
wiruth
Maybe? No doubt, mine is running much better at the low end. Idles much smoother.
Old 10-27-2012, 03:38 PM   #15
Coyotekiller
Have you got a part name or number for this vent valve?
Old 10-29-2012, 09:54 AM   #16
wiruth
The problem was described as "the canister vent valve not sealing properly. vent valve leaking internally." FP Number - 22865590. Description - valve 3.130.
Hope that helps.
Old 04-05-2013, 02:05 PM   #17
tbears13
Drives: 2012 Chevy Camaro SS
I'm so frustrated! I love my Car, but it seems to be in the shop more than I acutally get to drive it.
Now I have the p0442 code on my vehicle 13300 miles. They already replaced my gas cap. I took it to my mechanice for a oil change and the light came on again. He pulled the codes and it was the same one.. So he put it up on the rack and said that I have a radiator leak. I asked was it from a rock or something and he said no, that this is a defect and that I needed to take it back to the dealership!!!
Just wanted to update my post. Took into the dealership today and they had to replace the purge valve in the emissions canister. Hope this helps anyone that might have this issue occur. There is a bulletin about this, but no recall as of yet.
tbears13 is offline   Reply With Quote
Old 04-08-2013, 05:17 PM   #18
Mkn95u0
Mkn95u0's Avatar
I never ended up taking mine to the dealer to get checked out... it came on up through about 8k miles, i'd clear it each time with my reader... then it came on, i decided i would just drive with the CEL on, and one day it just magically went away... never switched gas caps or anything...
i'm at just under 20k miles, and still hasn't come up since, i've tuned it with a programmer a few times with Jet Performance, then got it supercharged and tuned again to adjust for LT headers and what not...
i guess all i can say is good luck, but if you get it fixed, i'm sure it could help others in the future if you post what was done to correct it, as i'm not convinced enough that it's the gas cap.
-RCM
2012 Camaro 2SS (L99) 443rwhp, 455ft lbs torque
check engine light, emission, evaporative, p code, troubleshoot
check eng light 2011 m-6 ss flem 5th Gen Camaro SS LS LT General Discussions 2 04-30-2011 08:51 AM
Check engine light chevyss Tuning / Diagnostics -- engine and transmission 12 04-20-2011 09:39 PM
check engine light. code p0453 stonecoldvenom Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 8 03-23-2011 01:28 PM
Question about Check engine light Alain Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 18 03-11-2011 11:42 AM
Voice Your Comments/Suggestions/Input for Focus Group on 2010 Camaro Mr. Wyndham 5th Gen Camaro SS LS LT General Discussions 236 04-22-2008 12:43 AM
