Vivid Superchips
Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection Anything related to keeping your Camaro clean and in good cosmetic condition.
Old 03-30-2012, 11:11 AM   #1
GlennP
Drives: 2011 Camaro 2SS
how often is safe for polishing?
I have a PC and use the adams goodies. Assuming "normal" amount of polishing (one slow pass each direction with both SHR and FMP) how often is TOO often?
Is it too much to do it twice a year? Will I run out of clear coat? Should this only be done when absolutely required?
GlennP is offline   Reply With Quote
Old 03-30-2012, 11:17 AM   #2
SSOOCH
"El Dictator"
SSOOCH's Avatar
Drives: 08 HHR SS, 2010 Camaro SS/RS #16429
It all depends on the condition of your paint. If it needs it do it. But once you polish it and do paint correction and you use proper technique to hand wash and dry your car you shouldn't need to do it but maybe once a year.
Old 03-30-2012, 12:17 PM   #3
Dylan@Adams
Drives: 2009 Avalanche
You only need to polish as often as the paint requires it... with good wash habits and paint care its reasonable to only have to do correction a few times a year. If you do really well often times it won't take anything more than FMP and the white pad to clear up any minor stuff.
The 'material' removed from that fine of a polishing step is so small that it would take tons of passes to ever be at a point of concern for 'too much polishing'
use the code CAMARO5 for 10% off your order at www.AdamsPolishes.com
Dylan@Adams is offline   Reply With Quote
Old 03-30-2012, 01:59 PM   #4
GlennP
So basically once or twice a year is nothing to sweat over, especially if I skip the SHR
Old 03-30-2012, 02:13 PM   #5
Dylan@Adams
Yep.
safe numbers? mropus Forced Induction - V8 2 03-24-2011 09:19 PM
Safe to run 91 octane on a 93 tune? Agent WD-40 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 1 03-15-2011 05:57 PM
Wicked sounding and warranty safe? c-dub Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 6 02-16-2011 01:59 PM
Thanks V6 for safe hard rain commute RubyCamaro 5th Gen Camaro SS LS LT General Discussions 6 09-11-2010 08:20 PM
Are all our GM friends safe from the layoffs? 2010 SS RS General Automotive + Other Cars Discussion 11 04-22-2009 11:25 PM
