Old 03-30-2012, 02:42 PM   #1
lalo_ss
Drives: 2010 Camaro SS/RS
ls3 and ls9 questions ?
ok i have a 2010 camaro ss/rs so is that an ls3? what makes it an ls3? and and ls9?? i know it has to do with the engine so if i have an ls3 how can i make it to an ls9??
http://www.camaro5.com/forums/showthread.php?t=248695
lalo_ss is offline   Reply With Quote
Old 03-30-2012, 02:44 PM   #2
slick rick
SoCal Mayhem
slick rick's Avatar
Drives: 2010 Camaro 1SS/RS
If you have an automatic transmission SS then you have L99
If you have a manual transmission SS then you have LS3
LS9 is a supercharged engine
Old 03-30-2012, 02:44 PM   #3
spectre_
spectre_'s Avatar
Drives: 2012 45th Anniversary Camaro SS
This..
spectre_ is offline   Reply With Quote
Old 03-30-2012, 02:46 PM   #4
The Stig
knows 2 facts about ducks
The Stig's Avatar
LS3 and LS9 are two different engines. The LS3 is a 376 cubic inch with 426 horse power engine. The LS9 is a 350 cubic inch with 350 horse power and 425 lbs/ft torque.
You can't make an LS3 into an LS9. You'd just have to do an engine swap
Click to view my build thread
Old 03-30-2012, 02:48 PM   #5
lalo_ss
so what are the camaros that have ls9 on them ? and i have an auto 2010 ss/rs
Old 03-30-2012, 02:48 PM   #6
lalo_ss
nevermind i got it just saw the comments !
Old 03-30-2012, 02:49 PM   #7
The Stig
The Stig's Avatar
Not exactly. The original LS9 (used in the 69 and up trucks was N/A. Then later the LS9 got a roots blower thrown on it.
Old 03-30-2012, 02:51 PM   #8
lalo_ss
ok so if i put a supercharger in my l99 its still and l99 right ?
Old 03-30-2012, 03:05 PM   #9
Cpanthers85
Drives: 2011 Camaro 2SS RS
Yup.
Here's what I am doing...
I have an L99 that I am converting to an LS3 (Removing all the active fuel management and variable valve timing). This requiers a new CAM, so I am using the LS9 Cam and Valve Springs. I will add the Edelbrock E-force Supercharger, which is very similar and a lot less expensive as the LS9 Supercharger. Ultimately, I will have a "mock" LS9 (the new one, that is).
The LS9 has:
Dry Sump oil pan
Oil Pump and system so hard cornering wont rob engine of oil.
Oil Squirters under the piston.
Forged Crank and Rods.
High temp valves
From what I was told, the heads, pistons, pushrods, and block are all pretty much the same except for some of oil squirters.
2011 2SS/RS L99
2017 Chevy SS
1979 Z28
Mods: Kooks Long Tube Headers, RotoFaB EForce CAI, American Thunder Catback Exhaust, PFADT Stage 1 Drag Kit + Front Sway Bar, GM Strut Tower Bar. ZL1 Fuel Pump. Nitto NT05R. RX Catch Can.LS9 Cam and Springs.LS3 Conversion.JRE Fuel Rail Upgrade.Edelbrock Eforce.60# Eforce Injectors.Extreme Racing Tune. 523/495
MY BUILD THREAD
Cpanthers85 is offline   Reply With Quote
Old 03-30-2012, 04:17 PM   #10
Stingr69
'69 Owned Since '79
Stingr69's Avatar
Originally Posted by Cpanthers85 View Post
Yup.
The LS9 has:
Dry Sump oil pan
High temp valves
That is what I did too. LS-9 Cam and E-force Supercharger. It makes for a very torquey ride.
-Mark.
Old 03-30-2012, 04:31 PM   #11
slick rick
SoCal Mayhem
slick rick's Avatar
Thanks for the info
Old 03-30-2012, 05:02 PM   #12
Cpanthers85
-Mark.
How are is your rear end holding up? That's my biggest concern.
PS- your 69 Camaro is so amazing. That is my dream Camaro.
2011 2SS/RS L99
2017 Chevy SS
1979 Z28
MY BUILD THREAD
Old 03-31-2012, 04:34 PM   #13
Stingr69
'69 Owned Since '79
Stingr69's Avatar
Glad you like the '69. It has been a part of my family for a long time.
1 year of driving with the E-force and the rear end is still fine. I did loose a driveshaft bolt shortly after the supercharger install but the replacement bolt/nut was installed carefully (by me) according to the GM manual and has held up just fine. It all depends on how you drive your car. If you add slicks and hit the track then all bets are off and I assume the rear end would fail. Drive sanely on the street tires and it should last just fine.
-Mark.
Old 03-31-2012, 08:06 PM   #14
CamanLS3
CamanLS3's Avatar
Drives: 2010 SS
Send a message via AIM to CamanLS3
Am I missing something here? The LS9 is a reworked LS3 with a supercharger. Its 376ci (6.2L) that puts out 638hp. I think youre thinking of the LS9 from the '70s!!
2010 Camaro SS
CamanLS3 is offline   Reply With Quote
Unofficial 1/4 Mile (V8) 2010+ Camaro Fast List Merc Dragstrip and Launch Techniques Discussion 250 04-01-2014 11:40 AM
GMPP releases LS9 Supercharger Kit for Camaro LS3 (and modified L99) Motor !! thecamaroguy Forced Induction - V8 287 03-29-2011 09:49 PM
LS3 engine specifications Tran Wiki 3 10-06-2010 11:56 PM
Advice---Supercharged L99, S/C'd LS3 or LS9? CamaroZR1 Forced Induction - V8 25 09-25-2008 10:21 AM
