SDPC
Old 03-30-2012, 03:42 PM   #1
CCM52
Rebirth of muscle
Drives: 2012 ZL1, 2004 Denali, 2001 Jetta
Break-in
Now that the wait is over, for those who will be traveling hundreds of miles to pick-up their ZL1, how are you planning to handle the 1500 mile break-in period?
New Vehicle Break-In
Notice:
Follow these recommended guidelines during the first 2 414 km (1,500 mi) of driving this vehicle. Parts have a break-in period and performance will be better in the long run.
  • For the first 2 414 km (1,500 mi): Avoid full throttle starts and abrupt stops. . Do not exceed 4000 engine rpm.
  • Avoid driving at any one constant speed, fast or slow. Do not drive above 129 km/h (80 mph).
  • Avoid downshifting to brake or slow the vehicle when the engine speed will exceed 4,000 rpm.
  • Do not let the engine labor. Never lug the engine in high gear at low speeds. With a manual transmission, shift to the next lower gear. This rule applies at all times, not just during the break-in period
  • Do not participate in racing events, sport driving schools, or similar activities during this break-in period.
  • Check engine oil with every refueling and add if necessary. Oil and fuel consumption may be higher than normal during the first 2 414 km (1,500 mi)
  • To break in new tires, drive at moderate speeds and avoid hard cornering for the first 322 km (200 mi). New tires do not have maximum traction and may tend to slip
  • New brake linings also need a break-in period. Avoid making hard stops during the first 322 km (200 mi). This is recommended every time brake linings are replaced.
  • Should the vehicle be used for racing or competitive driving (after break-in), the rear axle lubricant must be replaced beforehand.
I personally have 550 miles to travel and plan on taking some back roads but will have to spend the majority of the trip on the interstate driving at a constant speed.
GBE, B92, MN6, CF5
VIN: 2G1FS1EP3C9800455
CCM52 is offline   Reply With Quote
Old 03-30-2012, 04:06 PM   #2
2012ZL1
CaRaHoLiC
2012ZL1's Avatar
Drives: '12 ZL1,67 Cam,68 Biscayne 427 4 sp
Interesting on the diff fluid. I wonder what happens to it in that short of time?
2012 ZL1
2.55 upper, 10" lower pullies, Innovators west billet hub and sfi balancer, solid blower drive isolator, 50 mm idler kit, full length S/S headers no cats, comp cams custom grind cam, comp roller rocker trunion kit, comp push rods,dual valve springs retainers and locks, Injector dynamics ID850 inectors, Rotofab ZL1 cold air kit, Lingenfelter 160 thermostat, Rotofab intercooler reservoir, stock plugs, LS7 90mm throttle body, GTO clutch reservoir mod, my own custom catch can, Tuning by Jannetty, install by me.
2012ZL1 is offline   Reply With Quote
Old 03-30-2012, 04:14 PM   #3
OVRKLL
Drives: Soon 2 B a ZL1
Is that the diff oil or axle lubricant?
OVRKLL is offline   Reply With Quote
Old 03-30-2012, 04:17 PM   #4
Erik@Torq
Erik@Torq's Avatar
Drives: '10 SS + '04 Z16 Z06 S/C
Send a message via MSN to Erik@Torq
I broke in my SS by taking her to the road course 2 days after I picked her up and then did an oil change lol. 45k of extremely hard road racing and 3 x 6000 mile road trips miles later she is still 100%!
Erik@Torq is offline   Reply With Quote
Old 03-30-2012, 04:20 PM   #5
RULK
RULK's Avatar
Drives: 2012 Camaro ZL1 Victory Red M6
I think the car will drive fine if you don't follow the break-in instructions, they only thing would be the life of the engine would not be as long. 150,000K vs 200,000.
RULK is offline   Reply With Quote
Old 03-30-2012, 04:24 PM   #6
adamgl
adamgl's Avatar
Drives: '98 Camaro Z28, '06 Z06
All sound good except for this.
'10 Camaro 2SS/RS A6 Sold :( ARH, FM Super 44's, K&N CAI, ADM scoop, Diablo Tune, RX catch can.
'98 Camaro Z28 M6 TSP headers, true duals, AIR/EGR/AC/muffler delete, CAI, Subframe con.,
shock tower brace, Stg. 2 T56 rebuild. Monster Clutch Stg. 2, Electric Water Pump, TT2 wheels, 315 NT555's
'06 Z06 2LZ, Cam, P/P/M Heads, FAST Intake/TB, ARH, CAI, HP Clutch/FW, C5 Axles,
Pfadt Coilovers/Poly Bushings, Carbon Fiber: Everything, lol. HID's, 360 Forged Spec 5's/Invo's, Custom Interior. 550 RWHP
http://www.camaro5.com/forums/showthread.php?t=235911
adamgl is offline   Reply With Quote
Old 03-30-2012, 04:26 PM   #7
htron50
htron50's Avatar
Drives: 2017 ZL1 (Firm Order) Status 1100
Originally Posted by CCM52 View Post
[*]Should the vehicle be used for racing or competitive driving (after break-in), the rear axle lubricant must be replaced beforehand. [/LIST]
Isn't the rear axle liquid sharing the cooler with the tranny and use the same fluid?
If so, do you therefore replace tranny fluid and rear axle fluid simultaneously?
IE, is it a simultaneous event?
htron50 is offline   Reply With Quote
Old 03-30-2012, 04:41 PM   #8
xx_ED_xx
xx_ED_xx's Avatar
Drives: 04 Silverado
Every engine etc, the break in period is driving it like i normally would. And following severe duty service intervals
xx_ED_xx is offline   Reply With Quote
Old 03-30-2012, 04:45 PM   #9
trademaster
Drives: 12 MP4-12C, 16 Quattroporte
Just don't beat on it and it will be fine!
trademaster is offline   Reply With Quote
Old 03-30-2012, 04:59 PM   #10
Fenderaddict2
Opinionated bugger!
Fenderaddict2's Avatar
Drives: Boss 302, Mazda 2, Praga & Intrepid
I recommend laying down two black stripes as you leave the dealership and keeping the pressure on until you park it in your Garage.
Follow me on forums everywhere as Fenderaddict2 or my kid on the track and Twitter @fastmyles
Fenderaddict2 is offline   Reply With Quote
Old 03-30-2012, 05:18 PM   #11
Sven59
HAMMER PILOT
Sven59's Avatar
Drives: 13 ZL1 #182, 85 AMC Jeep CJ7
Be careful violating the break-in period, I believe that the Chevy Service department can tell if you violated some of their rules and could void your warranty.
Sven59 is offline   Reply With Quote
Old 03-30-2012, 05:39 PM   #12
hognutz
hognutz's Avatar
Drives: 2013 ZL1
this break in puzzels me beyond belief. I work with metals everyday as we operate helicopters.
there are heat cycling and break in issues for cetain metals, gear meshing, etc. 1500 miles is huge.
do not maintain a constant speed for 1500 miles???? good f-ing luck with that one.
I will not follow this proceedure to a T because it is almost impossible. I will follow guidlines of my own though.
the odd thing is just do do a dyno pull on a motor would be behond this break in procedure ha ha.
you have to wear the tires front tires in. rears can be broke in faster ha ha. heat cycle the trans and rear diff a few time. make sure the rings have seated before you redline the car.
I usually dirve to the coast and back ~200-250miles of random driving speed and rpm with multiple stops. then drive it like I stole it.
2017 zl1 or GT350 hmmmm
2015 Hellcat-sold
2013 ZL1 -sold
2013 Dart
2013 Megacab 8" lift 38"mt's
hognutz is offline   Reply With Quote
Old 03-30-2012, 05:51 PM   #13
phantom
phantom
phantom's Avatar
Drives: 2012 ZL1 CRT 6M
This thread was discussed several months ago and the one surprising comment was follow the breadk in period as noted for 250 miles. After that, do starts slow, accelerate hard to 80 MPH and then get off the accelerator, push in the clutch and let the vehicle come to a 5 MPH speed, then do it again. Several pulls like this per day will seat the rings better and allow the engine to develop into a more powerful beast. I'm not following this procedure, but it was discussed in great detail earlier this year. Most of the comments came from individuals that race cars and build engines. Any input!!
phantom is offline   Reply With Quote
Old 03-30-2012, 06:32 PM   #14
ZL1_Alkindi
Mechanical Engineer
ZL1_Alkindi's Avatar
Drives: Camaro ZL1
Send a message via MSN to ZL1_Alkindi
The break in period for cars nowadays isn't as important as it used to be in the past due to improvements in material selection and manufacturing processes... I will probably go easy for the first 200 miles and then let her rip....
Sometimes you just have to show her whos boss....
ZL1_Alkindi is offline   Reply With Quote
How did you break your engine in? DavidCigam Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 39 11-08-2010 08:07 PM
Is there any actual proof whether hard or soft breakin better? jackka Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 46 07-22-2010 04:26 PM
Is there any actual proof? jackka Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 1 07-07-2010 11:59 PM
The BEST Break for a new car. "very long" Darin Morgan General Automotive + Other Cars Discussion 346 02-04-2010 07:49 PM
Letters to Oshawa Hylton 5th Gen Camaro SS LS LT General Discussions 51 10-07-2009 12:42 AM
