Old 03-31-2012, 03:43 AM   #1
aggroalex
Drives: 2011 camaro rs/ss
brand new camaro driver
Hey guys just bought a used/ new 2700 miles 2011 camaro six speed. When I test drove it I had been a way from manual cars for about 5 years so it wasn't unusual that it was a little different but i wanted it so I got it and will never regret it...still it drives alot different then most cars probably because of the hydraulic clutch I suspect, is this correct. I just want any tips and pointers on Good shifting techniques as far as starting at first and so on.....because a couple times i got done driving when I stalled it from a stop going into first I smelled a funny smell like brakes which I think I was probably burning the clutch a little, is that horrible??? Any mechanical info how everything works would be a help, also notice the friction point is really high up which im not used to can or should I adjust it? Thanks a lot
aggroalex is offline   Reply With Quote
Old 03-31-2012, 03:55 AM   #2
Dennis SS
Always Lookin
Dennis SS's Avatar
Drives: 10 SS/RS 6M Blk/Blk Silver Stripes
Hydo clutch...yes. You just need practice, you shouldnt smell burnt brakes your burning up the clutch. Lay off the transition a little quicker, your dragging the clutch, get it in gear then quickly and smoothly release the clutch. When you walk you dont take your time between steps do you? Imagine not or your will fall on your face. Same with the clutch but not to the point where your jerking the car everytime your let off the clutch between gears....smooth and quick enough to not jerk the car...unless your racing!!
-Custom grind Crane Cam with 3 bolt conversion, Lunati springs, harden push rods, SLP oil pump, LS2 tensioner
- Kooks Custom Headers. X-pipe, mufflers, high flow cats,
-Tuned by National Speed in Wilmington N. Carolina, HP Tuner 490rwhp and 483rwtq
-Skip shift eliminator
-RX Catch Can
-CAI intake
-Hurst Shifter, with custom Speed Dawg
Dennis SS is offline   Reply With Quote
CAMARO WIKI Tran Wiki 55 03-28-2017 12:04 PM
Where we are coming from (check inside) ljustin293 2010 Camaro5 Fest (I) 106 05-12-2010 11:31 PM
CLOSED - Driver Signup for the 1st Annual Official Camaro5Fest (April 16-18, 2010) GTAHVIT 2010 Camaro5 Fest (I) 923 03-19-2010 11:56 PM
Pedders Suspension Benchmark Track Testing and New Jersey Track Day Info@PeddersUSA.com USA - NY / NJ / PA 35 10-26-2009 05:20 PM
